If you have solved your problem could you email me at my address :nemo9980@yahoo.com
jodi
Bruce
The loud humming noise sounds like i'm driving with mud terrain tires. I've owned alot of truck. I've owned many different types of All Terrains and mud terrains. there's no reason i could think of that there should be so much noise. I'm hoping that's all it is. The salesman said his 07 titan has road noise like that but good grief, this is crazy. I can accept that fact that it could be road noise if i had some other tire on but this is silly.
It's this common for these trucks or tire type?
Thanks for your reply.
I have a 1993 Nissan Pickup with the 4cyl KA24E engine in it. It ran very well for 100-Thousand miles but then the plastic timing chain tension guide broke (the long one on the right side of the upper timing chain as your looking from the front of the engine) and needs to be replaced. The engine will still start and run but it is rough and obviously out of time.
Question is: Do I have to pull the engine out of the truck body to repair this or can it be done with the engine still mounted in the truck?
The Haynes Repair Manual I got shows what I believe to be a Nissan car with the engine in a horizontal mounting position so I can see by that that the engine would have to be removed for servicing the timing chain components but I am not sure with the inline mounting of the pickup. If I remove the radiator and the hardware on the front of the engine, can this be repaired easily without removing the engine????
THANKS for ANY input!!!!!
GBABCOCK
The shot bed has bedliner, do I still need to buy a bed mat in order to carry some hard stuff (like paver)?
I have a '93 Nissan Pickup (just turned 150,000 miles) and it has original alternator. I check the output at oil changes (3000 mile intervals) and it is still putting out 13.5 vdc. It has a 5 speed manual transmission and still has original clutch. The only work I have had to do to it besides PM is brakes (twice), change a relay for a start problem (twice), tires (twice), replace the tailgate latch, and replace the left tail light assembly because I rolled back on a hill and hit a tree.
I do have a front end shimmy that recently developed and I think the ball joints may need replacing. That's what brought me to this forum.
I bought it used in '95 from a friend and use it as a truck, if you know what I mean. No babying this vehicle. It looks a little rough but it is mechanically sound because I do regular PM.
Cheers,
Airmech
kcram - Pickups Host
A Nissan technician told me that the solution was to use a genuine Nissan Oil Filter when I change the oil since these contain a special valve that maintains a certain amount of oil pressure even after the engine is turned off. My first thought was that requirements for "Genuine Nissan" (most things) are a bunch of hooey, but since I was having service done at the Nissan garage anyway, I added an oil change to my bill and was pleased to discover that the startup rattle problem went away.
Some time later, I did my own oil change. I used an after market filter that claimed to have the proper pressure valve required by Nissan, but the rattle came back. So my advice is - try a Genuine Nissan Oil Filter. And if it solves the problem, don't mess with anything else. It gives me indegestion every time I hear that rattle and wonder if this is the morning when the timing chain will finally be so loose that it will slip a tooth.
The symptoms are somewhat contradictory. The problem started a few months ago and it first, it would occasionally not work for a minute or two when I first started driving, and then it would start working. Then the problem became more frequent (as in, almost every day instead of just once every week or two) and then the problem started to occur not just when I first started out, but also if I'd stopped for a few minutes or more. The contradictory part: if I tap the dashboard a half dozen times, it starts working (suggests to me a problem in the speedometer itself or in the dashboard wiring) but at one point, it set a code and turned on the MIL (check engine light) which suggests to me a problem in the speed sensor instead of the dashboard wiring - I'm told there's a speed sensor in the transfer case but I haven't investigated.
Anyone have experience with this? How do I test to figure it out? What do I look for? I took out the instrument cluster, and followed someones advice that I should clean the contacts with an eraser from a #2 pencil. I wasn't impressed that this was effective, but was reluctant to try sandpaper on those contacts on the back of the instrument cluster because they're pretty flimsy. Is there a better way to clean those contacts? Any kind of measurements I can take with a multimeter to diagnose this?
:sick:
http://www.courtesyparts.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=CP&Pr- oduct_Code=D21-TCKIT
not cherging under load then tighten the belt.
or a new belt is needed.
also check bearing and pulley tightness on alt...
Scenario: Start up truck & let engine warm a few minutes to 10min.. then run across the street to coffe shop(maybe let it warm a bit listening to radio). Come back out-(always starts up fine) start driving out of the parking lot and it starts running rough, and shudders at the stoplight like it's going to die(just for a few minutes)-I keep it reved to keep it going, after a minute down the street it goes away. I live in Wash. state,..not thaT cold yet- 40's/30's
Did oil change & breather filter inside air cleaner housing(cleaner is good), couldn't find my pvc valve to change(internal?) Replaced battery to Diehard.
Is this a cold start valve, or EGR, or sensor type problem? it feels air more related,....but could it possibly be electrical?....
Alternator of sensor?
I turned my 5 speed into a 1 speed real quick. Downshifted from 3rd to 2nd pretty quick, now all I have is 4th. Previous owner replaced complete tranny little over 1 year ago,not a lot of hard miles on it. love the truck,has a little over268k on it,looks and performs well,but the thought of spending 1,500+ really isn't what I want to do,would rather put that $$ into my 02' VTX 1800c. Good chance I will be selling the truck if it is in need of a new tranny. Any expierence or suggestions about the tranny? Doesn't make any wierd noises or anything just have 4th gear. :confuse:
