I have replace the oxygen sensor, mass air flow sensor, had a major problem with my spark plugs. Now I have this problem. When I try and drive it I have gas spewing out all over underneath so had to park it. (again) this truck only has about 62,000 miles on it and the body is in excellent shape. Need to get this thing back on the raod. So if anyone can tell me where to find the sending unit located ontop of the gas tank for less than 340.00 I would greatly appreciate it.
http://www.autopartsfair.com/
my truck runs like a top till about 2600 r.p.m.s, then bogs and hesitates there, replaced, fuel filter, t.p. sensor, and fuel pressure regulator. still haven't replaced the fuel pump, nor the injectors. and while i was at it, any info for cheap fun upgrades would be appreciated......danny
i would like to know if a d.o.h.c. head is a direct bolt on to the s.o.h.c bottom end.
and anyone with turbo knowledge on how to install, a Frankenstein turbo on my truck, and hoping to find out how and what upgrades will be necessary for this to be an equivalent to a turbo 240sx drift motor. any and all help will be much appreciated..... Danny
email me ..
i can help you with parts you need for nissan trucks..
Frank
1000 mile trip in one weekend with no problems. then I had it shipped to an island, when I went to the island 2 weeks later the 30a fuse was blown and when I relaced it, it blew right away, when the fuse was blown the windows,horn, turn signals and a few other things didnt work. but the alt light never came on, I drove it about 50 miles and the battery died, I charged the battery and ran tests, the fuses would usually blow after starting, but if I replaced it while running it would last until I turned it off again. the ammeter would sometimes show a high charge (15 v) a voltmeter across the battery showed no change in voltage after starting, a voltmeter across the 'batt' terminal of the alternator and ground while running showed nothing.
and while the alt light on the dash comes on when the ign is on it goes out when the engine is started, I removed the alt and bought it back with me, I took it to 2 auto parts stores for testing , the first one said it passed the second one said it worked but was only putting out 11 volts. Its not possible for me to try anything else untill I go back to the island, when I do I want to be fully armed! Anyone got a clue?
