Chevy Silverado - Continued V
You have the classic dual use problem. The 2500 w/6.0L would be your better choice for your towing application. Everything is beefier. But the 1500 is all you need the rest of the time. You didn't say what your trailer will weigh. The 1500 can only go to 8700lbs I believe. If you can afford the extra cost I would go with the 2500. There is a posting elsewhere on this board about MPG.
ok, let us know which one you approve of:
selection 1 (limiting freedom of speech):
"Only 4 door talk should be that someone ACTUALLY has one in there driveway. Besides it is getting boring in here no one has anything good to say anymore."
or selection 2 (endorsing freedom of speech):
"I dont care what we talk about its a
free country you know"
if you could clarify that, we'll all sleep better tonight...thanks
kyle
ps. ryan, i'm just pulling your chain, bud. trying to get you torqued up a bit to make the time pass a little quicker...no hard feelings, eh?
What did i win????
Ryan
Kyle
It just rides better even when not hauling.
Think this way....You can't buy too much truck...(if you feel you do...at least what you need is there!)
..but you CAN buy too little...(and there is no cheap way to make the power and capacity you need be there!)
You will sacrifice MPG by about 3 mpg...but is it worth it for how much heavy towing you do?
You have to be the judge of that...
For the price difference...get a 2500 if you are unsure....and if you can handle the loss of mileage
Go drive them both...if you can find a 3/4...
Good Luck
Check other topics devoted to this comparison...and the 6.0 MPG
- Tim
Good Luck,
AFS
My Dad pulls a 25' trailer with a mid 80's Jimmy (the full size 1/2 ton one) with a 350 and he says it does fine. Now his "fine" and mine may be different but it gets him there.
To make this decision you must drive both. They ride differently, look different, and have slightly different options.
Basically, if you need the capacity, get a 2500.
If not, your choice.
5.3 15-20 mpg
6.0 11-15 mpg
The 2500 has a heavier frame, heavier suspension and brakes, HD transmission, heavier axles, etc. It weighs about 800 lbs more than the 1500.
Mike L
Ryan
Now That's a first...
Who cares?
We are having discussion here.
Anyone care besides Ryan?...I don't...
Roc?
Quad?
GW?
TP?
Rwag?
Anybody??
- Tim
What I really want is a 3/4 diesel. I don't mind spending the extra dinero for the better (for lack of a better word) engine. In return I get more torque, better mileage, etc. etc. A big plus is that in my neck of the woods diesels are in high demand. Resale on them is huge. But, the dodge looks stupid in short box and the long box won't fit in my garage. Ditto with fords. I just can't see spending 33K for a truck that I have to leave outside all winter (it gets cold here) and all summer (it gets hot here). Who knows when the new diesel chevy is going to get here and I'm not real comfortable with first run vehicles anyway. So, the most logical option is to buy a 1500, use it for a few years, and then trade up for the diesel. That 5300 will do everything I want it to and give me better mileage as well. A lease may be an option but 500 a month and no equity don't seem right either.
Any comments?
Let's not pick on Ryan TOO much.
I had a chance to look closer at a Tundra the other day. I still can't figure out why they lift the bed off the fram like that. It DOES indeed seem to give aslight bit more tire clearance, but I can't figure out why they did it that way. Funny, though, that it just looks so small after driving my vastly superior (is it ok to say that) Silverado. With three doors. Actually four, if you count the hood. Five if you also count the tailgate. SIX if you also include my shell door. SEVEN if you count the center console door. You know where this is going ...
Richard
kyle
ps. tim, i'm offended you didn't ask if i care.
pps. no, i don't care...i just like rattling ryan's cage.
Ryan: Don't let 'em get you, Chief!
Tim and Rwag: You guys kill me! Too funny!
Scottay: A Beetle? A Silverado? huh?
What happened to codename "planejane"?
Now... about those fender flares!
Later - It's WAY past beer-thirty in Atlanta.
Bryan
turbo
I don't think the fuse block counts, though. It actually pulls completely off...
Ryan
Any comments?
Keeping this in mind, how different could the programs be for the 4.8 and 5.3 litre engines? Given, it's a vette and it's probably tuned hot, but oth engines have aluminum cylinder heads and composite intakes, both blocks are dimensionally alike with the exception of bore size and what the block is made of. Both have powder metal rods and six bolt main bearing caps, coil over cylinder ignition and I think are within 30 or 40 hp of each other.
So, my question to all of you out there who bought a HPPIII for enhancing engine performance, has it worked? Because I can't see buying a $300 computer for maybe 10-15 hp. Maybe for speedo recal or relocating a shift point, but not fractional gains in hp like that.
OK....You care??
As for list kit....yeah the dealer is going to say you can't....but yes...he has to prove it was the cause of X problem.
And for doors....ALL the ones mentioned are STILL bigger than ANY door on the tundra!!
LOL
(Even the fuel door!)
...There is a cover like that opens for the air filter....kinda like a door??....and how about that Brake reservoir?....
HOLD ON!
There is the ashtray too!
...and all these people want only a 4 door?
What's with that??
- Tim
They will never be exactly what you want to talk about..
If not...stay silent and it will change..
Speak up and cry...and people will dog you all day..
Now...
...Last time people whined..(Trucklover/Zbad..etc)
I guess they couldn't take it and are long gone..
..although Zbad may be in disguise?
Hopefully you stick around.....Just kick back and relax....enjoy the scenery....
..and how many more days until you place the order!!????
heheheheeeeeee
HOW MANY DAYS??? Well hmmm Its dec 18 today and i plan to order March 18 so do the math itll give u something to do. Thats the last time i am talking about this seriously.
Ok i have a real question.
For all the people who have a reg truck with the P265's what brand tire came with your truck?
For all the people who have an ext cab truck with the P265's what brand tire did ur truck come with?
My theory i have noticed is that reg cab's come with good year and ext cabs come with firestone any input on this?
Ryan
Ryan
I really want the center console and the extended overhead console, but do not need the tape player and like the floor space in front of the console where the tape player would go. If someone has this combination, I would like to know. My dealer just gives me a blank stare and say's "we don't order them that way".
Thanks in advance for an info, Evan
Kevin
Kevin
Kevin
turbo
Thanks for all the comments and answers you all have given me. I love my truck, no problems at all and it is sooo Badass!
Chevrolet Silverado LS Reg Cab Sportside 5.3 liter
Locking Diff Indigo Blue...
absolutely love it... Engine is so powerful especially in my reg cab truck.
Ryan... I never answered your question about where i live... im in florida no need for the 4wd
if I was in the snow i would get 4wd but everything here is flat and i rarely go off road.
To all considering buying a Chevy...Do it!
~Teaboy~
Tape Deck- The tape deck is now in the floor (u know what i mean not the floor but the middle console). Oh this sucks we need to elaborate does the CD player still come in the center if you get the LT or is the cassete there.
Finally someone (Evan) brought up something new about the silverados thank you very much.
Ryan
Now, both cars I've owned since I've had my license have been stick shifts, and I've always been a firm believer in "rowing my own gears" for many reasons. 1). It's fun as hell 2)Better gas mileage 3)Slightly better performance, etc. etc.
I had planned on ordering a 5-speed Silverado at first, but I figured I'd cruise the lots and see if any were around. I've been to over 10 dealerships multiple times in various areas and have seen all of 3 stickshift Silverado's. I drove 2 of the 3, one was the 4.8l reg. cab longbed base model, and the other was the 6.0l 3/4 ton reg. cab longbed base model.
I wasn't thrilled with either of them. Shifting is not quick, like it is in your F-body, the synchros seem to take their time in engaging the gears. Both transmissions had a whine to them, and in my opinion, a good word to describe the shift feel is "rickety". I've also heard bad things about the light duty 5-spd from this site and a dealer mechanic.
Then I drove a 2000 5.3l auto trans reg. cab stepside Z-71, and I was really impressed. Plenty of power, whenever you need it, as well as silky smooth shifting.
So I'm sitting at a stoplight with a car in front of me and the salesman sitting next to me. The light turns green, the car in front of me starts to move, I pressed the pedal down less than 1/2 inch (more like 1/4") and I barked the rear tires. Suprised the hell out of me, I had no intention of doing it.
I figured, well, it must not have a locking diff.
It did.
Anyway, turbo I suggest you drive both manual and auto before you make that decision.
I never thought I'd drive an automatic until I hit atleast 40, if ever....
Yeah..I agree...6.5 is the shortest I'd want a box too in a truck. These new crewcab type short boxes will be so popular...perhaps it will speed up getting my next ext.cab?....or slow it down more cuz the crews will be all they want to make?
leavy,
"rowing your own gears" sucks in a truck. What's the throw of a truck shifter?.....2...3...4 feet?
(Just kidding)....but yes...it sucks.
Todays autos are fine. For a performance car..yeah...I have one...but for a truck or other car...Automatic for me!...(even way before 40!)
It sucks sitting in traffic with one for a while...first..second..third..Oops!..gotta slow down..clutch..coast...stop...first second...stop..first second..third...WOW!..we got into fourth!...oops...traffic is slowing down...clutch..coast....second...hope for faster speed..nope!!....traffic slows....clutch..first..
You get the idea....and forget about enjoying eating/drinking/or answering the phone comfortably.
Only time I really like a stick...is in a performance car...under wide open throttle..feels fun controling that that way...every day when not racing...hell...I just might get an auto next time.
In case you didn't notice....I think Manuals Suck!
...I'd had my share of using them....and that's why I form this opinion....I drive it fine...just hate them to death.....
There is no need for them.
Gotta run
- Tim
i can only speak to the 1500's as i did no research into buying a 2500. i believe the reason you cannot buy a 5.3L manual is that the torque generated by the 5.3 manual would damage either the frame or driveshaft (or both, i can't remember which) remember, this is on the 1500. i agree with the other posts here reference the auto vs. manual also. i've driven nothing but manual trannies in the 10 years i've been driving and thought that'd never change. but like tim said, it gets to be a pain to chow down a burger or drink a cup of coffee, etc - especially in traffic - and have to shift also. god knows how many wrecks i've come close to causing trying to slam a cup of coffee into a cup holder without looking (in the process burning myself) while watching traffic and trying to downshift rapidly too. bottom line, thanks, but i'll just rely on putting my foot on the brake to stop from now on. plus, the auto trans has all the get-up and go you should need with the 5.3L. if you need more, you might want to consider getting a sports car instead of a truck. exclusive tow/haul feature on the stem creates higher shifting rpm's also, so loaded down passing shouldn't prove to be a challenge.
radios -
all i know is that i got a credit for telling them i wanted a cd player with the head unit and no tape deck at all. o/w, if you order both the cd player and the tape deck, they give you the "remotely located" cd player. i don't have any tapes anymore anyways, so i decided to keep that extra couple hundred $.
kyle
Werking- Did you get an LT with out the tape deck? I have no use for it and would rather have another cubby hole for stuff. Let me know if this is possible since the dual media is standard on the LT.
Kevin
I haven’t ordered another, I’m not sure I will. Maybe I’ll wait for the 2001 models. I told the dealer if he could find one exactly like the one I ordered I would take it, they’re scrambling to find one. I don’t expect they’ll have much luck, I ordered a loaded LS without the AutoTrac – I don’t think they make too many of those.
I asked the salesman what kind of quality problems would take so long to correct. He said there were any number of things that could go wrong, but he said the most common problem was having Chevrolets built with some GMC parts (evidently they’re built on the same line) and that was most likely the problem. The second most common problem (in his opinion) was trucks that had serious engine malfunctions. Whatever the reason, I would prefer the one I buy to be right the first time.
And yes Tim my dads 2000 blazer has the autotrac thats how i know, i used it in the rain and it worked great havent tried it in the snow yet but i assume itll work great. Im still shaking my head thinking why a person wouldnt get the push button 4x4. I havent even seen a truck on the lot with the manual 4x4 to tell you the truth last one i seen was at the chicago autoshow 2 of them had it. Your spending almost 30 grand for a truck why not spend the extra couple hundred dollars. That is more confusing than calculus.
Ryan
Comments:?
Not only that, but AutoTrac hasn’t been around that long and I’m not sure of it’s reliability over the long term. I’ll bet it could be very expensive to repair.
Sorry. I couldn't resist.
The point I’m trying to make with the above story is: If the seat belts were attached to the seat (as in the Silverado) he wouldn’t have been able to pull himself up and could have been hit head-on by a car coming from the opposite direction.
The thing to hope for is that Chevrolet has considered all the possibilities and has built sturdier seats.
In real-world conditions, the integral belts stay out of the way far better and are generally easier to reach. That is actually a valid selling point.
Richard
