front of the air intake for the air filter & installing a flow through muffler and 4"
exhaust from the cat. back?
I know. A Bronco is not an F-250. I did have an '84 F-250 with a 300 c.i. straight 6. Great truck.Would still have it if someone had been paying attention & not come head on in my lane.Totaled both vehicles. Thank God that Ford knows how to make seat belts that work...and a tough truck.
Folks with manual tranny, smaller/lighter versions of Superduty and/or 2WD get 1 or 2 mpg more. 6.8L V10 has an easier time moving all that mass around than 5.4L V8 - so even though you're feeding two more cylinders, there isn't all that much difference in the mileage.
Unfortunately, I ran my tank down and had to do a major fillup the other day - $83! Ouch!!
Luckily, this truck is not my daily driver......
at Barranca and the 10 Fwy in Covina there is a Chevron about 1/2 mile north of the fwy and it's $2.55..cheapest I've seen.
I used to own an Expedition with the 5.4 liter engine to tow my boat. The F250 is a far better tow vehicle for the combined "wet" weight of 9000 pounds of boat, trailer and fuel. Ford did a nice job on this redesign. I think the only improvements I would suggest would be to dress up the interior somewhat and add some amenities like they have done on the F150.
I also drove the Dodge Cummins 2500. It is an impressive diesel but I picked the Ford for its better transmission, and the better back seat leg room in the crew cab. Just one person's opinion, but I really am enjoying my F250.
Tom
Will gas get to 3.00 this summer? I sure hope not,but I'm betting it does.
Hey, usmc03, California was a great place to go 'off-roadin' many years ago.There were plenty of undeveloped areas in the mountains around Orange County & deserts East of there. Enjoy it while your there if you get the chance. Just don't go draggin' the bottom of that new super duty on the the rocks.
Later~
I would suggest researching them and stick with those companies that specialize in diesel applications. Another website, that I can't mention due to site rules, did a test on a Powerstroke using a chassis dyno. While that one test was inconclusive as to which chip/tuner was best, one thing seemed to stand out. The chips/tuners made by companies that started out offering tuners for gassers seemed to have higher Exhaust Gas Temperatures. Those companies that offer only diesel engine chips/tuners seemed to run lower EGT's.
With that said, I recommend getting one of the lower HP chips/tuners that is programmed for towing. A lower HP chip, say around 75hp, won't raise your EGT's too much. A higher HP chip/tuner will run higher EGT's and a pyrometer(gauge that measures EGT's) is a neccessity. That way you'll know it if you start to cook your turbo. Also, with a higher HP chip/tuner, install a tranny temp gauge if you have an auto. I recently sold my truck because I didn't need it anymore. It had over 165k miles on it running a 75hp/150ftlbs chip with no problems whatsoever. So running a mild chip/tuner, IMO, shouldn't affect the longevity of your engine.
Any chip/tuner should be covered under the Magnusson-Moss Act. However, I've heard stories of dealers not honoring a waranty simply because the truck was chipped. I've also heard stories of dealers that support the use of chips/tuners. My local dealership happens to be one of those. Infact, the diesel guru at this dealership told me I should chip it, along with some other mods, when I first got it. What a guy!!!
Just go to one of the search engines on the internet and do a search on something like "Powerstroke tuner" and look at what comes up. Also, try that large online auction site.
My wife use to have a '95 Cougar with the 4.6L. It didn't even have 5k miles on it when it developed a small oil leak around the timing belt cover. When I took it in, they told me that I must be spilling oil everywhere when I change the oil. I KNOW BETTER THAN THAT. I asked them to look at it and the service tech flat out told me that he wasn't going to spend all day looking for a non-existant leak. I went and got the head salesman, who sold us the car, and he told them that they WERE going to find and fix the leak. I told them all they had to do was put some UV dye in the oil, let me drive it for a day or two, and I'd bring it back in. Pretty simple I thought. Well, they finally did just that, and two days later showed up with an engine covered in UV dye!! Don't ya just love it when things work out like that. BTW: They fixed it and that motor never did leak any more oil in 8 years that we owned it.
over the weekend east of L.A., the best price in this town..
to breathe..you don't need any chips, the thing has too much power in my opinion.
They should de-tune them, that would help on the fuel mileage...when you are on
a trip find your power band, mine is at 71 mph. This will let the engine run easy and
use less fuel..I get 19 mpg on a trip once it made it to 20 mpg. Putting a 4"
exhaust from the turbo back will also help it breathe. Besure they attach the cat.
when this is done...one last thing I did is open up the wall in front of the air intake
alittle a 3" square hole to let more air in....the wall is there to keep the noise down,
it isn't that much louder..around town is 17 mpg. Use your CC on the long runs.
PROBLEM: On cold mornings an intermittent electrical problem occurs in which none of the gauges function and the throttle response is absent for the first few minutes, then first the throttle responds, then the gauges come in. What’s up?????????????
2. The automatic door locks on my truck have quit working, you hear a "thud" sound whenever you try to lock or unlock the doors, but no action. Does anyone know about a similar problem? Is this a actuator problem? (sp)
Appreciate any replies.
not...Ford started do this on the 6.0 engines. If you have a 4X4 that's about what
you will be getting. A friend of mine has a'03 and that's what he still gets.
what you get.
4X4. It had 77K miles at purchase and the automatic mpg guage consistently says it's getting 14.3 mpg. Even when towing our 9000 lb horse trailer, the mpg doesn't change on the guage. Sounds like this engine is not getting the best mileage, according to other posts I've read today. No owner's manual included with truck. Your post #25 mentions an on-line place which may offer oil, filters, etc. for much less than could be purchased off the shelf. Could you e-mail me that address? Also, any tips on increasing mileage would be appreciated. I've read thru all postings regarding starting, stopping, no water in tank, buying at reputed truck stops, etc and appreciate all the good advice.
to add the "Clean Diesel" to the catagory of those electric cars which could be a
good thing if we get a tax break of some kind..if that's the case they will be looking
at those trucks and checking for the cat. converter....I'm going to add a 4" exhaust
and flow through muffler to help it breathe better..the cat will be left on and I know
that doesn't help matters.
If you can use a wrench, change it yourself.... Ford ripped me off for $125 in labor charges for less than 20 minutes of work. I didn't know where the solenoid was located......
was 2 yrs old...2001. It had 40K on it, but was in excellent shape. We added
lighted stepsides to it so I could get my short, fat fanny up INTO it. Got ripped
off by the dealer, whose salesman had assured us it was ready to tow the
5th wheel we were also preparing to buy. Turns out, the towing pkg on it was
for the purpose of hauling FARM EQUIPMENT.... and of course, the salesman
denied having told us it was ready to pull a 5th wheel, so we ended up spending
another $1300 for a towing package. aaarrrggghhh....
Which leads me to the current problem..... finding an HONEST, ETHICAL
repair shop in order to have the truck inspected and diagnosed. Last week,
hubby was driving it when he smelled a strong odor of burnt diesel inside the
cab... popped the hood, and found diesel fuel all over the engine. He took it
to the NEAREST Ford dealership (not knowing what I know, having lived here
forever.... that this dealership & its service dept have about the WORST rep
in Western WA!).... where he asked them to inspect THAT problem, diagnose,
and get back to him. Monday, they presented us with a ''diagnosis'' and an
''estimate'' of nearly $3000.... a little more than 1/10 of it related to the problem
for which hubby TOOK it to them.
The problem with the diesel spill was due to Jiffy Lube having either put the
wrong cap back in OR having put NO cap in when they did a lube job 2 weeks
prior. (They DID ultimately put that in writing, so we have some recourse
against JL) Diagnosing this, steam-cleaning the engine, and replacing the
cap cost us $336., which we paid.
But we told them we'd have to ''think'' about the rest of it, since NONE of it
had to do with the problem for which we TOOK the truck to them in the first
place: Labor
@$101
Diagnose Fuel Leak and Repair, Steam-clean engine**................. $274.13 2.0
Front Brake Reline.................................................................... $299.98 2.5
Rear Brake Reline..................................................................... $305.66 2.5
Replace Exhaust Back Pressure Sensor and Replace tube.......... $395.49 1.5
Replace Torque Converter (''T/C iss rattling and will come
apart causing transmission failure'')......................................$1023.77 5.5
Reseal Intake System and clean out Air Intake System............... #368.57 3.5
Disposal of fuel..................................................................... $ 64.00
Tax...................................................................................... $240.36
_________
TOTAL.................................................................................... $2971.70
MINUS 1st on list (what we had done).................................... $335.62
__________
BALANCE if we GO for this line of padooky............................ $2636.08
This vehicle NOW has nearly 100,000 miles on it, so I know it is probably
due for some brake work, though I can't see it taking 5 hours to replace
FOUR brake pads.... but prior to this ''diagnosis'', the worst problem I
thought we had was a broken cup holder. NOW I don't know WHAT to
think, nor who to go to for an HONEST assessment of the problems, if
any. What do you suggest? Anyone live in the Seattle area, and know
a good mech?
soogie
The spilled diesel fuel problem: Did JL replace the fuel filter? Did they not put the fuel filter cap back on properly? They had to have put in on, otherwise the fuel system would never pressurize and gallons of diesel fuel would begin pouring onto the ground almost immediately. They wouldn't have been able to pull it out of their shop with no cap on.
The brakes: Those can be done by any reputable brake shop. There's no difference in your's and 1/2 ton trucks, just size and weight. I'd check around.
I don't know about the exhaust back pressure sensor. I've never heard of that one.
The faulty torque convertors on '99 models are a known problem. I'm kinda surprised that your's has made it to 100k if it has been rattling all this time. Since it's out of warranty and it's made it this far, I'd be tempted to keep driving it until it craps out. Of course it could take your tranny out as well if it dumps a lot of debris into the fluid. There is a transmission rebuilder somewhere in Arkansas by the name of Brian's Truck Shop. He has a reputation as building an absolutely bullet proof torque convertor. In fact, he's so confident in his work, he offers a two year unlimited, unconditional, unlimited mileage, "he doesn't care what you do to it" warranty. If it breaks for any reason, he'll replace it. To find his site, go to a search engine and type in the name just like I typed it above. You should find it no problem.
Resealing the intake system: Interesting. These Powerstrokes use a crankcase ventilation system similar to what's used on gassers. What that means is that all oil vapors created in the engine are sucked into the intake to be burned, rather than released into the atmosphere. This oil vapor will coat the interior of your intake tract with a thin film of engine oil. The major problem with this setup is that the oil film will cause your intercooler tubes to blow apart from their rubber connectors under high boost conditions. You'll know it when it happens as there is a sound similar to a distance explosion under your hood and the truck will fall flat on its face. You'll think you just blew the motor. If that happens, all you have to do is clean the rubber boots really well and reattch them to the cooler tubes. No big deal really. Unless you have this problem, I wouldn't touch it!!!
I would forgo this dealer and find someone else. Of course, that was the point of your post in the first place. I wish I could help you on that. But maybe I gave you a little info and insight to help you make a decision. Good luck.
kcram - Pickups Host
