Lincoln Town Car Maintenance & Repair
Problems with your Town Car? Post them here and share any solutions with other TH members.
1
Henry
Any suggestions what may be causing this?
Have ya considered moving to Nevada or Arizona?
I'm digging and if I come up with anything I'll let you know. You do the same please!
You will probably be able to gain access to it by taking out the stop in the glove box that keeps it from falling down on your knees and dumping its contents on your lap. Check to make sure the vaccume line is well attatched.
One problem with that problem though, is that the vaccume line is iether on or off. It really can't be in between, and if its off, you will get heat only.
Another item that you could check is the heater control valve, which is under the dash pad in '80's models, and I would assume the same is with your 98. If yours is still a vaccume powered unit, which i doubt, it could be bad (those things had a tendacy to crap out in '80's machines). Again, the problem with that has a different failure mode than what you have mentioned. When the vaccume powered heater control valve fails, you usually only get luke warm or ambient temperature air from both the heater and the air, since a bad unit will only provide a range of low-mid vaccume to high-mid vaccume.
That said, I think your unit is electronic servo operated. In that case, the servo on the heater door could be failing, overheating when in use and shutting off, causing the heater door to return to its home position, which is wide open. That servo would be my first suspect.
just picked up a new Town car and because of the following design characteristics I find this luxury car to be extremely dangerous -
the brake and gas are so close
I have almost driven thru my garage door and
rear wall
it is almost impossible not to hit the gas and brake together
the metal strip on the dash reflects thru to both side view mirrors creating a double line in each mirror thus distorting the view on both sides and limiting the viewing area
the defroster vent is so far away from the window (closer to the driver) that it also reflects into the windshield decreasing visibility by 25% in the front windshield
the green LED lights from inside at night also reflect in the left side view mirror that that also distracts and limits the viewing space
if anyone has noticed any of these please reply asap
I have a '95 TC. When I turn off the windshield wipers, the wipers go to the "up" position and stay that way, instead of going to the "down" (concealed) position.
Any help appreciated!
-Gary K
If you will look at posts in "Lincoln Town Car" at numbers 1040, 1045, 1049 (diagnostics) and 1052 they will relate my experience with a faulty blend air door motor.
-GASKET BETWEEN AC BOX & BODY LEAKING INTO BOX & ONTO CARPET BELOW GLOVE BOX ON PASSENGER SIDE--REMOVED SCREWS--LIFTED PLASTIC--APPLIED SILICONE SEALANT TO GASKET & REPLACED ALL---LEAK GONE---GUD LUK---RUDY IN LA.3-17-05
It took many cycles (90-60 then 60-90, moving the temp 1 degree at a time with a couple of times with 2 degree movement. When it hit 86 Degrees it jumped to 103, but when the car was shut off and restarted I was back to square one. I was assuming that the blend door was sticking but I thought why is it defaulting to the air conditioner side. Also I thought there was a safety function in case this happened that would let you go to defrost and you would get heat. This doesn't work, I get cool air out of the defroster too. This happen last summer but the situation was reverse. I drove down to Las Vegas using the heater and when I switched to air conditioning, the air was maybe 72 degrees; just guessing. I stopped at a shop and the guy told me I could do a self test by pushing the OFF & FLOOR buttons at the same time and then within 2 seconds push AUTO. The temp window displayed a clock hand rotating and finally stopped with zero codes. I then pushed the BLUE button. When I tried the air it blew cold air. On the way home the heater also worked when I needed it. The car was driven about 500 more miles before being parked. I have also disconnected the battery with the problem still there.Any advice would be appreciated.
He also told me that the 4.6 engine was called a romeo engine, that the heads were finished to a glass like finish when new, and during assembly, it was not uncommon for metal flakes from the assembly process to get in between the heads, gasket, and block, and that with the expansion and contraction it is fairly common for them to develope leaks.
Of course, the car is now out of warranty. I'm just wondering if anyone else has encountered this problem?
Thanks to all,
Also, the dealer may never find this problem if its not happening while he has it.
Charles Nelson
I have not tried it yet, but it sounds like it will work. Sunroof may still be your particular problem, but I don't have one, and still have the same leak. Food for thought.
This happened on my TC two days after purchase. Replacing the driver switch panel and harness fixed it. If the other doors do not work, then try tracing the current as best you can from the fuse box back to the doors. If memory serves me right, the rear driverside door connects to the front door control. Passenger may be the same. You try running a continuity test
Testing for continuity, you will need to disconnect the battery. Email me if you need to , Bradmcooper@hotmail.com
