Visitor Agreement.
http://www.autozone.com/images/cds/gif/large/0900823d801156c4.gif
when I road tested with mechanic he thought the whir was from the transmission.
I am trying to connect with other stratus owners to see if anyone has a similar experience. so far no luck.
any advice would be appreciated. I can't see driving this car around with the whirring noise and hope I'm not stuck without any options or help.
sincerely,
don sandri (zinn) as username
As for the popping noise, see the TSB below.
Body/Suspension - Clunk/Pop Sound From Vehicle Front
NUMBER: 23-039-04
GROUP: Body
DATE: September 24, 2004
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 23-012-03, DATED May 23, 2003, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES AN ADDITIONAL MODEL YEAR.
SUBJECT:
Pop/Clunk Sound From Front Of Vehicle
OVERVIEW:
This bulletin involves installing two rivets in each front shock tower/wheel well area.
MODELS:
2001 - **2005** (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan
SYMPTOM/CONDITION:
Vehicle produces an intermittent front end popping or clunk type sound while driving over road inputs that cause the body to come under a twisting load. This sound may also be produced when in park & idle by turning the steering wheel quickly, 90 degrees, to the left and back to the right.
Any advice very appreciated.
Jeff
Randy
Thanks Gary
mine occurs only from a standing start and accelerating. the strange thing is my previous 99 stratus made the exact same noise under exact same circumstances. i am wondering if it may be a body desgn flaw..
Only thing I could think of, the inside of the service station gas pump hose was coming apart on the inside and pumping little square pellets into the truck tank.
Of course, if a station has caused fuel problems several different times for you, I would think there would be a lot of people complaints. If you fuel at the same place, I would go in there and ask if they have had compliants about problems with their diesel fuel.
Thanks in advance for your feedback!
Tires are all sized same, wheels balanced, nothing appears out of round (no change to rotate the tires around). No codes. Fresh service to transaxles and tranny.
Suspecting Tourque Converter as it seems to happen at speeds and acceleration rates where the TCC should be locking up. How to confirm? Any other suspects?
Thanks much !
I have a '98 Explorer, 89k miles that I just bought. I got an oil change this morning where a transaxle leak was brought to my attention by the mechanic. They want $200 and say if it dries out it'll be even more.
1. Should I just wait until the schedules maint. says to take care of this at 120k miles or whatever.
2. Is it as EZ as removing the cover and changing the gasket? How do you put the fluid in though? Thanks
Please help, $3500.00 for new engine
Anyway, getting back to the case. I think i can check it if I can find it.Thanks
I was under the car today looking at the transfer box ('98 explorer) and it looks like they just sawed-off about a foot of the fuel line and attached a piece of rubber hose between the filter and old fuel line. Should I go back or what?
If in fact it used to be an all steel line (this is my assumption from what you said), then my question to the shop is:
"If the Ford engineers wanted an all steel line, how exactly is your flexible line a proper repair"?
It's my presumption that a vehicle capable of off road use would not want flexible fuel lines that could be snagged.
Now if there used to be flex line and they just extended it a bit, well, then maybe it is a proper repair.
Even today's hot rodders use sheathed air-tex fuel line if it needs to be flexible.
I was under there again checking the transfer box oil level. (It's good at least). The other crook I took it to for an oil change, had me worried about the "transaxle leak" and how it would fry the rear axle if the fluid is dry, unless of course I paid him $200 to change the gasket - crooks.
By the way, do I have to change that fluid at 90k like it says in the manual? What's that stuff supposed to look like dirty? Mine looked pretty clear and felt awful slippery.
How am I supposed to get that stuff outta there, with no drain plug anyway? Thanks.
Can anyone provide their car response over a range of mph vs rpms. Also their highway mpg would be appreciated.
I believe my car is underperforming (fuel consumption high and seems higher revs)
Cheers
Max
Here's the problem. My wife will be driving at hwy speed and she'll all of a sudden lose power. I've been doing a little research online and think it might be the crank position sensor. Would I be correct and if I am, where is this part located under the hood? Any info you may have is dearly appreciated.
Chad
So I called Firestone back and they're like "did they even look at it?" And in all fairness they didn't. I even offered to by the fuel line if they just put it in and they said "no." They assure me it's a good repair, and they're not getting involved with my truck again.
So now what should I do? Ford wants $150 for the line - with the labor it's like $450. I asked them for the estimate, so they didn't have dollar signs in there eyes.
Or you could just tell Firestone you are going to do this, go to Small Claims, in three days, in writing-- they should at LEAST refund your money.
So naturally, to make up for this lost HP, you press on the gas more and use more fuel.
You are only losing 10-12%---that's pretty darn good. Count your blessings.
What should I look for there? I gather if the van were modified someohow, I might have changed this angle (say with bigger wheels and tires), but that's not the case.
:confuse:
I'm wondering about this because I don't like taking my car to the Honda dealership for regular maintenance but then I wondered that maybe the "Honda recommendations" are not followed by the average mechanic....I don't want to end up with damage to my oil pan.
Please offer any advice. :confuse:
I can look in up in my 93 manual for LeSabre/PA. It will take a while to find the books.
