Visitor Agreement.
Unfortunately, it usually takes replacing the starter to fix it.
One thing you can check to make sure it is the problem, is to take a test light, touch it to the small wire on the starter solenoid [should be blak with yellow stripe, according to my info] and turn the key to start when it won't start. If the test light lights up, then you have confirmed it is the starter that is the problem.
It may be tough to get at. I'm not sure on that vehicle.
Bookmark | Reply | E-mail Msg
I have a '95 Caprice Classic Wagon w/level ride and having an "up problem".
The level ride will fill the shocks when i have a load, but will not let the car down when i unload the back. I have to dis-connect the air line to lower the rear. Chevrolet dealer can't pinpoint the problem, could be the $900 pump or the $300 controller. question is, is a tool available to determine which one could be faulty, and the manuel says that neither part is servicable. sorry, but someone made it orginally, so it should be able to be fixed. I own a small radiator shop/garage and am looking for some help. Is this the right place? thanks, hess1
Replies to this message:
• Mr_Shiftright (Jun 20, 2005 10:21 am)
Some components can't be serviced because of either the way they are manufactured or because they are too precise for disassembly in a shop e.g. injection pumps, etc.
I bet if you could get ahold of a schematic on how the system works you can at least pinpoint the component that is failing and maybe scrounge up a used one.
Thanks! /Brian
While the solenoid may be the problem [often it is the starter windings], it is always best to replace them as a unit.
The starter assembly, with solenoid is about $120, the solenoid by itself is about $85.
While I realize it sounds expensive, trust me, if you replace one portion or the other, you will later wish you had replaced the entire unit.
Also, check your local yellow pages for Auto Electric Service.
Auto electric shops usually rebuild starters or have an exchange program that is far less than buying a new unit.
They may be able to rebuild your unit, but be sure to explain to them that the starter has a hot start problem.
Personally, I would opt for a NAPA unit.
The problem with alot of chain parts store starters and alternators is that they sometimes are mass reconditioned and the quality may not be that great.
Hope this helps.
Trouble code info
It is in a pdf file, so you will need adobe acrobat reader.
The file will be removed after a few days.
My question is about a GMC full size van (the large white work vans often used for transport as a sort of mini bus). The van has dent on the passenger side on a panel just in front of the last wheel. It is about (all numbers approx.) 12 inches off the ground, 13 inches long, not very deep, and at its widest (it varies from top/bottom to middle of dent) about 4 inches wide. The van was backed into, in a parking lot, by the corner of a minivan on an angle, luckily at a very slow speed. Can anyone offer a approximation of a what a repair will cost? I know it varies by place to place, but can anyone make an educated guess? Thanks in advance!
I bought a 1998 Honda Civic EX which has like 140000 miles. Recently did a oil change, fuel filter change , oil filter change and spark plugs too.
I also got checked my timing belts, and looks like it needs to be changed in a month. My question is how by looking at the timing belts a technician can say that it needs to be changed in a month. I am not sure whether it needs to be changed immediately. Does it needs a change since it has high mileage.
Please advice.
Thank You
Aj
I'm not sure if your engine is an "interference fit"---which means that if the timing belt breaks, your pistons smash into your valves....not good. If it's a non-interference engine, then if your timing belt breaks the only thing that happens is you stop dead in your tracks, but no engine damage.
So this is also a factor in considering the urgency of doing it
to be recalibrated, since the battery was disconnected. (Still ended up costing me
$100). The mechanic told me Mitsubishi's are notorious for that. If so - wouldn't
the dealership have told me that when I called about my problem?
Anyhow - is there any way I can do this calibration myself instead of spending
a hundred bucks extra every time I change my battery?
(Ps - this happened last time I changed the battery, but reset itself after a few
hours).
Thanks in advance!
Brian
I havnt heard the whirring noise....yet.
Also, never got back into the forum to thank you for help on changing an O2 sensor on a 00 Impala. I changed it; the problem was solved. Thanks for that.
The images are now large enough to read properly.
The problem is that it requires a scantool to properly diagnose that trouble code.
But check all the vacuum hoses and conenctions to the EVAP system and see if any have come loose or are broken.
Is this engine prone to problems due to intake manifold caskets disintergrating or the use of a plastic intake? I am considerating purchasing an 2005 box truck for my business, but am now skeptical??
If there is not power to the starter when the key is turned to start...
Check Park/neutral switch. That has a yellow wire with power when cranking and purple comes out of there to go to starter.
If there is no power on yellow wire when crank requested, there is a starter enable relay that's under the dash. That has yellow in and yellow out from ignition switch which is on top of steering column about brake pedal. The starter enable relay gets signal from starter enable relay control which is a small computer box that checks the passkey resistor chip. Do you have a security light come on when you try to crank the car? If the chip is wrong or the wires to the reader in the key cylinder at the top are broken (like my 1993 LeSabre did), the wrong reading tells the computer that someone has a wrong key. So the starter enable relay does not pull on to connect the yellow wires to send power to the starter.
The starter enable relay looks like it requires the whole dash and speedo cluster to be removed to get to it. It's buried so the thief can't bypass it easily if they have a rwrong resistor key.
Does the security light on the driver information center come on when the key is first turned to "on" to show the bulb is working. Does it come on when trying to crank if the bulb is working? It allows 3 tries to crank with bad resistor reading and then disables for 4-5 minutes before it will read another key... I've had dirt on key cause a wrong reading.
If it resets after driving the car, you have other problems.
Are you sure this is your problem? On GM/Ford autos, these seldom go bad. I would carefully check vacuum lines for leaks that 'drive' the EGR valve. On some cars, the EGR valve may 'carbon up', and they can be cleaned, without replacing.
Ok now for water or oil... on the left side of the motor, between the valley cover & valve cover when it builds pressure, it bubbles. I don't want to get burned trying to find out whether it is oil or water. So far, it's just in that one spot. I know it needs gaskets galore, but I was just wondering if it might be more serious than just replacing gaskets.
Thanks, Rene'
After the truck gets warmed up real good.. It begins to shudder at about 45 -50 mph. It sort of lurches/lopes when I come to a stop sign & I get a loud knocking noise. Anyone have any ideas on where it might be coming from? It was suggested to me that it might be a main bearing. After the oil gets hot it gets thin & things get loose. I myself was thinking either a piston arm pin, or rod knock.
I also wanted to say that this site ROCKS!! Thanks to everyone for your help & input. It's priceless for a beginning mechanic such as myself.
That sounds like a mechanical problem. The bulbs usually ahve little prongs that have to go in channels to the bottom of the socket and then the bulb is rotated to follow the channels and lock the bulb into place. It sounds like part of that process isn't working. Take a look at the bulb, prongs, and channels to see if you can tell what's not right.
The grease won't fill space and make the bulb stay in place. It would slow down corrosion and keep water out of the space.
Here are a couple of products you might be interested in:
http://www.permatex.com/products/prodidx.asp?automotive=yes&f_call=get_item&item_no=21351
http://www.permatex.com/products/prodidx.asp?automotive=yes&f_call=get_item&item_no=15067
