Visitor Agreement.
Question 1: Do you know of any shops where they identify the problem and give an estimate "free"? I live in Raleigh, North Carolina.
Question 2: If there are leaks in the compressor, how much does it cost to fix the leaks? Do they have to change the compressor entirely or is there an easy way to fix the leaks?
Question 3: How much does it cost to fix leaks in the tubes/hoses?
I really appreciate your help on this. I am in a big dilemma about this expensive A/C repair. Please help.
If not, try a wrecking yard (or "used car parts emporium" or whatever they are called now). Maybe you can pull one off of a junker.
A Honda specialist suspected oil in the spark plugs. There was indeed oil in the plugs. Said some things to reduce HC would cause NO to increase, which would also cause failure on the smog test.
He ran down possible things:
- Replacing those gaskets
- Tune up
- Possibly replacing catalytic converter, which may have been hurt by the leaking oil and possibly by MTBE in the gas.
If catalytic converter is replaced along with the other suggested repairs, that's $600 to begin with.
Under CA CAPS program, I could apply for up to $500 aid to do repairs after I pay first $100.
Or I could have the car dismantled and they would pay me $1000, which is about what the car might fetch if I sold it.
Is the car worth rescuing?
I priced a new one at a parts store and it's cost is $275.
Someone mentioned to me that a universal converter may work and would cost me $80.
Can anyone give a poor girl direction?
Well, unless you plan on doing the work yourself, it only matters what your mechanic says, right? Did you ask him/her if this universal converter would work AND if they would install it if it does? Heck, since you're not sure of that price, maybe that $300 price IS a cheap converter plus labor.
Oh, dang, I just noticed you have a 4.9, not a Northstar. All I've had - a 95 and a 97 have been Northstars. Yours might not have the line in the same place......
Is it that simple? How do you replace just the regulator arms and not the motor?
I am not a real car know it all...so if anyone knows and has some basics- that would help a lot.
How much trouble you will have kind of depends on the car and also on accessibility. Usually it's pretty tight in those door panels so while the job isn't too complicated it can be very tedious. Sometimes it really helps to have someone else holding things in place for you.
I'm not sure how a rock can damage a window regulator---that seems very odd to me.
But here's the problem. Took it to get it inspected since that's an annual requirement in our state. It passed emissions with flying colors, but the mechanic said we needed new front headlight assemblies because there was "barely any reflection," (the lens are very cloudy) the same thing for the right rear headlight assembly, and a side marker light assembly. For all of this he wanted to charge $1,300.00.
Isn't that something that we could buy the parts for and do ourselves for much less by roping in her older sister's auto savvy fiance. Is this a reasonable quote?
Thanks in advance!
It's too bad because 132k for a 17-year old car doesn't seem that much and the engine runs fine, aside from the emissions issue and the check engine light.
But it's probably just as well that it's dismantled and not polluting.
http://www.lincolnsonline.com/article19.html
In many cases, the haze can be polished off. If you can find a plastic polish, and with a lot of hand rubbing, you can bring the lens back to life. Check a motorcycle shop, they carry plastic polish for the cycle windshields. If you can't find this, regular auto polish might help.
If you, or this fiance, know how to use a power buffer, it would be much less work and much quicker.
With my buffer skills, I would probably melt a hole in a lens.....
I also agree that I would get a 2nd opinion on the repair - they bill sounds excessively high.
Last night on the way home it started to over heat, i felt the hot air blowing out of the vents. Once tha was happening we noticed the water temp gauge rising very quickly. We ended up pulling over in a lot and notice it was POURING coolant out of the L shaped house at the back of the engine housing area (firewall).
Less than 2 weeks ago we had teh water pump replaced.
Any Ideas? The sooner the better...
As i was trying to open the hood, the cable snapped. Temporary fix for it is pliers, but i want to know what would be involved in replacing the cable, am I able to just pull that cable out and string a new one through the sheath thats there?
thank you.
Pull the battery and take it to Autozone, etc, they can load test the battery. And sell you a new one.
IqalAm
I have no idea if your car has such a resistor pack or not. Or exactly where it would be found.
What pressure do Goodyear recommend for their 305 x 70 Wrangler ATS?
Roy.
See Tires, tires, tires for various threads about this.
Lastly, check your fan/serpentine belt to be sure it is snug against the alternator pulley...if it is loose, you may have a perfect battery and alternator, but the alternator won't charge because the belt is slipping and the alt is not spinning...
While you're at it, clean out your ashtrays and vacuum the carpets... :P :shades:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/14/46/b7/09- 00823d801446b7.jsp
I bought my Cavalier in Sept. 04. I haven't put on 500 miles and have had a new crank shaft, ignigion gasket, spark plugs, spark plug wires, muffler, tires, battery, serpentine belt (3x) idler tensioner (3x) a motor mount, you name it. The lastest thing I had done was have a new compressor put in. The first one wasn't a rebuilt and for the price ($900) I had him redo and put in a "new" compressor. Since this compressor is in when I turn on the air conditioning OR heat, the car makes a click click noise, and shimmies. It does now however do EITHER (no noise, no shimmying) when the heat or air is not on. I returned it to the mechanic yesterday that put in the compressor and was told "it's because it's a small car, 4 cylinder, etc. ) I can't imagine that Chevy when they built the car didn't allow for the fact that people would use air conditioning and heat and not expect it to totally "disrupt" the functioning of the car. The mechanic says the compressor is fine. I'm totally confused here, as I don't drive much but each time I have, I've had another problem and it is very distressing. I've put nearly as much money in repairs into this car as I paid for it. Mileage is 28,195. Body is excellent and a carfax was done to check that the mileage was new. Can Mr. Shiftright or any knowledgeable person tell me how to proceed and what you think might be causing the click click and shimmying witht the AC or heat on. Thanks so much. I'm ready to SCREAM.
Candie :mad:
