Visitor Agreement.
Thanks!!!!!!!
Thanks!!!!!
I just bought a '92 Dodge Dakota 3.9 2wd. The ABS and Brake lights remain on all the time. I have changed the differential "abs" sensor on top of the rear differential to no effect. Fluid is not leaking, pedal is OK. Vehicle stops OK. I would like to pull the ABS code to see what else it might be. Instructions elsewhere say "pull ABS codes by grounding connector" I think I have located the two terminal black plastic connector under the steering column. My question is: which one of the terminals do I ground? Or do I ground both?
Thanks for any help.
Bill
Only slitghly kidding, but unless you are real handy, this probably won't be a simple swap. In the long run, wouldn't it be much cheaper to just buy a VR6 model and sell the old one?
http://www.autozone.com/images/cds/gif/large/0900823d800ff8ee.gif
This is the code list:
http://www.autozone.com/images/cds/gif/large/0900823d800ffb0e.gif
I'll try to pull the code tomorrow.
Bill
Candy
I tried to install a remote starter on my 2000 Ford Windstar. When it did not work (later found the brake switch was unplugged) I disconnected everything only to find out my transponder keys will not start the car. Anti-theft is flashing, no starter crank, which leads me to believe the passive anti-theft system is locking me out. Dealer says once this happens only they can correct by reprograming the anti-theft system. If that were true, believe more people would be discussing.
Keith
Advise....
Thanks to all who reply!!
No. I don't even have a clue about it's make, model, year, mileage, or service history.
Any ideas?
if you put the key to the position just before it engages the starter and you still have no lights, then i might suspect a bad ignition switch. i would think you'd have indication then, but if the starter is having problems, i think with the ignition in the start position (rotated totally clockwise towards the dash), i would think everything else would be inhibited to provide maximal current to the starter.
when you say "turn over and start", is the starter turning the engine, or is nothing happening the first 20 tries?
Any Suggestions? Is there a sensor on the engine that tells the climate controller when it is up to 65 degrees
in order to let the fan come on as that is the lowest setting on the controller?
I can direct jump the blower to power and it runs.
like bent valves and the like. That is if your car has one.
hard to say with engine noises as they transmit through metal so easily...
It is my belief that one sensor can cause a range of bad codes and MAF is the most likely.
PGP
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1- b/d9/85/0900823d801bd985.jsp
Is the air/fuel ratio sensor the same as the bank 1 and 2 sensors or is it different. If it is different were is it located on the engine.
Also I was told that in order to ensure that the parts you by are correct you need to specify wether or not your vehicle is california spec or non-california spec. I have no idea if my vehicle is or not. How do I know.
ANY HELP WOULD BE GREATLY APPRECIATED
I bled the brakes and then found the cause of the air - a loose line nut into the dump valve. Got that tightened, now all is good.
Thank you very much.
The scan tool has not been invented yet that will indicate specifically that a component is defective. All they say is that there's a problem with the circuit or that data is out of range.
What code #'s were retrieved? There are close to 30 of them which refer to O2 sensor circuits.
Old codes stay in memory and should be cleared. Maybe car is driving better than you realize and the CEL is tainting your impression. Also a wild thought, but old codes in memory might influence the PCM.
I have had similar experience in my 94 Mazda 626 which were resolved and 4 previous codes vanished by changing just the MAf when codes pointed to MAF, O2 , and ECT. Again I had to clear the codes after
Good Luck
PGP
