Visitor Agreement.
I'm not sure how many languages I can say it in. The mechanic told you and now I told you.
Oi.
no, just get the O2 sensor to start with. The catalytic is just a possible end result of driving around with a failed O2 sensor. Odds are its fine.
Once again ... O2 sensor... get it, replace it, and I would even go so far as to disconnect the battery for a half hour to reset the computer after replacing the sensor.
Exactly, if he chooses to continue to run it (possibly) rich he'll be looking at a more expensive repair.
An air filter fillling up with oil could in fact be the result of "blow-by"---combustion gases get past worn piston rings and form pressure in the crankcase...this "locomotive effect" pumps combustion gases out of any hole it can find. I bet you have a few oil leaks too?
Anyway, the PCV (Positive Crankcase Ventilation) valve is a thumb sized plastic thingie with a little ball and spring inside of it. It usually rattles when you shake it.
Here's a great description of what might be your problem:
http://www.misterfixit.com/blow-by.htm
But the 'thing' inside the air cleaner is a temperature sensitive vacumn control valve. One of the rubber hoses goes to 'engine vacumn', a vacumn source. When the air inside the air cleaner is cold, the control valve opens, allowing vacumn through to the other rubber hose, which goes to a vacumn diaphram that opens a diverter valve in the main air intake of the air cleaner. When opened, this diverter valve pulls air into the air cleaner from around the exhaust manifold - hotter air to allow the motor to run better when cold. There is usually a very flexible metal tube from this valve to a metal housing around part of the exhaust manifold. When the air coming into the air cleaner warms up, the control valve closes, cutting off vacumn to the diverter valve, which then pulls air into the air cleaner directly from 'outside'.
Of course, all the above info might be 'reversed' and wrong. In other words vacumn/no vacumn, open/close valves, etc might be backward depending on how the diverter valve is set up in default mode -open or closed.
But in general, this is what is happening. It allows a carborated motor to warm up, run smoother, etc when started cold by providing heated air from around the exhaust manifold which heats up very quickly after the motor is started. As a motor warms up, the heat from the motor migrates up thru the carb or thru an exhaust bypass passage across the base of the carb. This then has the carb warm, and the heated air is no longer needed as much.
There is a lot of 'balancing' going on in a carb with choke closing, air heating, and carb base warming to get a car to start easily, run immediately, then also run after it is warmed up. In temps from 110 down to zero.
I always hated to see a motor that someone had 'desmogged'. Which usually meant cutting, plugging (with screws, yea a great 'plug', one with threads), or just removing rubber hoses under the hood. What they were doing in many cases was just messing up a car so it would never run smoothly again.
<a href="
Three months ago mileage dropped suddenly from 21 to 12. No sensor lite or warning. After several cans of injector and fuel cleaner and new air filter went back up to about 16-17 and has stayed there. Shop not sure replacing front oxygen sensors will help.
Would those sensors ordinarily be replaced by now? What should I do? I will try to attach the four 02 wave forms.
I am back in Greece and car is running well thanks to you guys. I noticed an accumulation of oil on the intake manifold right around the shelf and close to where the ignition wires meet. I asked the mechanic and he said that is nothing to worry about.
I checked the oil level and noticed that I was about 200 ml down after 3000 miles and a lot of high speed 80-100 mph driving.Does a anyone think this is anything to be concerned about? I am trying to be very preventative in the maintenance of the car . It has 57 K miles on it and is a 94 4 cyclinder auto.
My merecedes never gathers any soot or oil on it, and I wonder if the mechanic is correct in his assumption that all is well. I have wiped the manifold clean and a little oil reappears.Remember this is Greece and there are a lot of filthy diesels etc spitting out filthy fumes that I am driving behind.
Aside from this car drives fine.
Thx
Peter
Amen. And some people who claim their car uses no oil at all are actually driving in a way that it's accumulating a small volume of contaminants in the oil that replaces the volume of oil actually being consumed.
The test is that instead of driving primarily in city type driving when they go on a highway trip the contaminants are burned from the oil due to the continual heating and flowing through the hotter areas of the motor and the owner finds the car "uses on in highway driving." In reality it just cleaned up the oil some and they saw the results of their earlier driving pattern and its accumulation of contaminants.
I was concenred about where I see it accumulating on the manifold. Do you think this a leaky gasket or anything, or just healthy burning and incidental grease from fans, radiators etc ?
Peter
Now my only question is about the small amount that accumulates on the intake manifold shelf by the ignition wires and whether this is any sign of a future problem?Gasket leak etc . I am trying to stay ahead of the maintenance on this car.Again 94 4 banger with 57k miles.
Thx Again
Peter
Thats a relief.I will buy the gasket and wait for it to get worse if and when it does and then replace it
Thx again
Peter
I have a 2001 Nissan Pathfinder and may need one.Are they expensive?
I believe that when they are tightened by running one up and then going in a circle is when you get uneven torques when I undo them.
Sears has been especially bad. NTB was excellent, but they were closed after Sears bought them because another area Sears auto store was struggling. I tried them but never again.
Have been trying lots of rentals though thru Enterprise on the dealers dime. Swapped out a Galant today and got a V6 Sonata. Nice ride actually!
The Sandman
Civics down here in South Florida are gone within 2 days at most dealerships, yet that's really the only car I'd really want right now. I think the Volvo S40 is a bit pricey for what one gets & the reliability issue bothers me. Also, the mileage ain't that great.
The wife doesn't want me to spend the $ on anything and just keep the Sentra. Seems like every hour or so she comes up with reasons why I should wait. Now she's pissed because eventhough she chose her Mazda 3s, it wasn't what she really wanted. I guess the logic here is I shouldn't get what I really want or I should take her Mazda.
Women...sheesh! She can't understand us car lovers and the pleasure we get from going to dealerships and seeing all the new models.
The Sandman
I HAVE A 1990 ACURA INTEGRA ON THE CONSOLE THERE IS A S3 LIGHT THAT BLINKS AND THE CAR WILL NOT CRANK. IT WILL SPIN OVER BUT WILL NOT CRANK. HAD COMPUTER TESTED AND NOT THE PROBLEM. SOMETIMES WHEN IT DOES CRANK THE S3 JUST BLINKS . A REPLY WILL BE VERY HELPFUL. THANK YOU
DENISE
THANKS,
MATT
THANKS,
MATT
