Visitor Agreement.
Also - I had my front brake pads replaced at Sears and the Honda folks informed me that they were rubbing too hard into the rotors and the rotors would have to be resurfaced! Is this possible??? What should I do? Thank you very much!
Sure you can check alignment. Alignment is always done when you add new tires so if you rotated badly worn ones, that might also apply.
I'm not sure what they mean by "rubbing too hard into the rotors"...I mean, that's what brake pads are supposed to do. If they mean DRAGGING pads, well then you'd have red hot rotors.
So I'd say unless they verify dragging brakes by using a pyrometer (needle thermometer I mean) on the rotors to show excessive heat, or at least jack up the car and spin each wheel and demonstrate that one is really not rolling free, then it sounds like dealer blabber to me.
I have to say though I'm not keen on having brake work done at large chain-stores.
About a month ago I first noticed a short squeak coming from my front driver-side wheel area only when going in reverse and I having the steering wheel turned completely to the right. It has progressed from a ....squeak...., to a .squeak.squeak.squeak... and its gotten louder.
Today I noticed when the steering wheel was turned fully to the left and I am going forward I get the same sound, same wheel. There is nothing from the passenger side.
I was thinking wheel bearing, but reading some descriptions it sounds like the wheel bearing doesn't squeak, but is more of a grind. Just to be sure I'm going to jack the wheel off the ground and see if I can move it as suggested elsewhere to test the wheel bearing.
Any ideas?
Seth
The same national chain store long ago was balancing my Sears Road Handler tires made by Michelin before they were available at area tire dealers... and told me my new Mustang needed new front ball joints because there was a 1/4 in play in them while jacked up replacing the wheels. I drove the 2 miles to the local Ford dealer where they probably were still laughing at quitting time; the air arms had to be supported to check the lower ball joints. No load means lots of play in the joint.
I'll bet Sears had a special on ball joint replacement that week too!!! Hehe. Not mine.
Find a good local individual shop for brakes that doesn't push the latest 200000 mile brake pad or lifetime replacement. Use original equipment and you'll get a much better feel in the brakes after the service.
My friends don't understand that horsepower is not useful if you need over 5000rpm to get it! Unless you're a drag racer.
Why don't you try posting here first, and if that doesn't work, e-mail me and I'll think of another place to try:
Pontiac Grand Prix Topic
MrShiftright
Maintenance & Repair Forum
Presuming you did that or something equally certain, I'd take a test light and see if any current is going to the bulb circuits...if you get no "pulse" from the flasher, and you are quite certain that fuses and bulbs are good, then I'd have to say your multi-function switch on the steering stalk is bad or a wire has pulled loose from the switch.
Thanks, Mike
http://en.allexperts.com/q/Toyota-Repair-832/cabin-air-filter-replacement.htm
yes, charge the battery.
probably i'd check the brake fluid and maybe have it flushed and i'd definitely have the oil changed if it hadn't before the period it wasn't driven.
tires? dunno.
I'd take the battery to a local store that does a free recharge as a check to see if it needs replacing. It probably has drained and if you're in a cold climate the battery may have frozen during the time it sat. Or you may be lucky... I think Advanced Auto does a free charge and check.
Look for glovebox light staying on? Trunk light? Open them quickly and touch the bulb and socket around to see if they're warm from being on rather than just warming from having turned on when you opened the door.
Was the replacement battery fully charged? Was the car driven for a hour or so to charge it?
ps: fan works ok
well... I don't know the car, but its going to depend on how the vents work. It most likely has some sort of controller, whether it be vacuum or electric, that controls the opening and closing of vents. This controller has probably failed.
Usually a failure leaes the air coming out the defrost. If there's no vacuum the defrost is the mode that lets the windshield clear for safety reasons. Check for a small black rubber or plstic tube that comes out of the intake manifold and goes to a storage tank for storing vacuum when you have the gas pedal flooreed. From there the line will go to the inside of the car through the fireway. Usually it goes along with other electrical wires in a bundle.
Often taht tube gets pulled off. I pulled one off of my 98 LeSabre each time I worked on the back spark plugs.
The tanks that store the vacuum often can crack and leak so there's no vacuum buildup in the storage tank.
Thanx.
The value in changing out transmission fluid is that the contaminants are suspended in the fluid. By draining at 30K mi, e.g., you are taking out half and replacing half the fluid with new fluid with fresh additives for dissolving and suspending said contaminants. By doing this repeatedly you keep fresher fluid and keep your transmission's parts cleaner.
This is what my service manager for my car's brand recommended. I change the fluid in the coolant also every two years. Cheap insurance. Same for tranny.
