does your AT have a dipstick for checking the ATF? if so, you can get some indication of the need to replace the ATF by its color and any contaminants as seen on a white paper towel.
google.
i drive 2 hondas. i think the recommendation is 60K, but i have the fluid changed at 30K. i have had one dealership and one independant both say 30K, and if you google on the web, you'll find other's recommending 30K.
i can only tell you that when i had my accord's ATF changed at 30K, the shifting of the AT was notably better.
The rods have threads on both sides. The outers install on one side and the other side threads into the rack and pinion shaft.
I can't get the inner tie rod from either side to break loose for my life.
Am I missing something?
help please!
now i'm older and a honda fan. i wonder how the two vehicles compared up to someone like yourself. the GTI looks pretty torquey, but it's heavier than the honda by about 1 passenger.
I have not done it... but I have bought the torx bit. It's an E-10, but I may ahve the wrong size so verify.
Unless your setup is different, you do not need to remove motor mounts. You remove only the sleeve on a minor component of a three-point support braket.
Take a close look first. My dealer did it in about 15 minutes with dead time in there. They had done it before of course.
so they admit to messing up your car, but won't buy it off you so you can get a new one? i mean, they have insurance right?
On the other hand, your car might be okay. Mishaps like this happen and if you catch it in time, there's no reason to suspect permanent damage. Problem is, there's a big ???? over the whole thing.
How someone takes the BIG GREEN HANDLE with the funny sized nozzle and pumps it into a Focus....well, that's talent.
Has anyone ever done this successfully? Or is the mechanic stretched??? TIA
BELTS--try another brand of belt.
Thanks for the previous tip. I definetally don't want to rush. It's my wifes car, and she's out of town. They are soaking as I type....and will continue to soak through the night.
Saturate some cloth, cotton balls, etc and duct tape it around the item, then let it set for a day or so.
any advice would help alot!..........is their a way to bypass the egr valve? or atleast check to see if it is the cause of my nightmare? its just a work car but im used to driving it! im not a mechanic so please keep it simple.....thanks
i can't imagine the wrong fuel in either vehicle either way would be a good thing.
one would think at a minimum, replacement of the fuel filter and plugs in a gas vehicle that took on diesel by mistake would be required (after draining the tank). i don't think you'd want to keep burning the stuff once the mistake was realized..
