if anyone can shed some light please advise..it seems it would have a bypass for now..i don't want the wifey stranded!!
is there not a button near the shifter that allows you to bypass the switch? (usually very small) I'm not familiar with your particular vehicle, but you can find such a button on several different vehicles.
I am the second owner of a 1998 ES 300 with approximately 86k miles. I purchased the car 12/01 when it was 4 years old and had 35k miles on it so I've had it a little over 5 years. So, the car is 9 years old as of last December.
I have never taken the car to the dealer for service because the dealer has always been quite far from my house and have moved so much I don't have a regular mechanic.
My "check engine" light has come on three separate times, starting in May of 2005. The first mechanic said it was the O2 sensor and he reset it.
Later it came back on.
The second mechanic replaced that sensor.
The engine light came back on but the same mechanic said it was the "knock sensor" - P-330 and he reset that because the "condition wasn't present at that time."
Now the engine light is back on and I am aware that in addition my engine has a significant sludge problem. I've changed the oil every 3-5k miles.
Unfortunately, neither of the mechanics mentioned the sludge problem to me.
My question is this- is the oxygen and/or knock sensor possibly related to the sludge?
I ask because I have a claim with Lexus/Toyota re: sludge only if I can show that the sludge problem existed within 8 years of purchase (the car is nine years old). If the engine light reoccurance will demonstrate that (it started within 6-7 years of purchase) it may help my case.
I need to know soon because my rights to further the claim expire next week. If I have to get a new engine it could be more than 10,000 dollars.
Thanks so much!
I do realize the first owner may not have changed the oil regularly for the first 35k miles.
However, the oil was "clean" when I purchased it and the car was originally leased. I would assume the chance a person never changed the oil on a leased car for four years is remote.
I need to prove two things
1. "reasonable maintanance"
and
2. the problem occurred within 8 years of original sale- which is my big hurdle. I am hoping the engine light issue may demonstrate that.
I hope somebody can help me with this problem. On my Grand Prix, cd player suddenly stopped working. I can not even put cd in. It seems like two metal thing is not letting cd in. any ideas?
You can get universal tools at most auto parts, and actually, I've made my own out of hardwood blocks.
I didn't know where to post this question, but I am sure many here can answer.
With an automatic transmission is it wise to shift to a lower gear when going down a hill to hold the car back and not have to use the brakes as much?
For example: going down a 2 mile hill with 35 mph limit I shift my Scion xb with four speed automatic into 2nd gear. It will coast at just about 35 down the hill and I don't have to use the brakes. My brother says I will wear out the transmission -- I say they are designed for that -- who is right?
Bill
If I had a heavy vehicle in a lot of mountain passes I would consider it to keep from overheating the brakes (did this w/Suburban pulling a trailer), but normally you should just leave it in drive and use the brakes.
Many years ago, I used to have an old SAAB V4 manual transmission, of which the transmission actually allowed the vehicle to overrun the engine (ie. no slowing the vehicle). I think it was called free-wheeling, IIRC. You actualy would just take your foot off the gas and the car would coast going down hill....then just put foot back on the gas to go up the next one. This enabled better mpg, and lower engine/transmission wear. That was one of the few good things that car did, but that is a whole another story.
I'd check your owners manual. The manual on my 99 Buick Regal states not to drive in second gear for more than 25 miles or at speeds over 55mph. So, 35 mph should be safe.
I know there are many things involved. What I'd like to know is which engine can produce more HP and torque, if I can also assume most other configuration are very similar.
In addition, I guess V8 should be a little smoother than V6?
you've got 2 engines that are identical in every way except for number of cylinders. WELL, I'm going to go out on a limb here and say you may get more torque out of the V6 and more HP out of the V8. Why? Because a bigger combustion chamber makes for a bigger bang. However, more, smaller chambers typically makes for higher revving.
I could be totally off base. I mean, with more chambers, you get more bangs per revolution ... but that's the problem with theories. They aren't always right.
oh, and I'll also say I think the V8 could theoretically get better highway mileage because you can put in taller gearing because, again, more bangs per revolution makes it easier to maintain speed with lower revs.
And, yes, the v8 COULD be a little smoother.
Did I answer which is better? not really. ;b
I am not a DIY on cars but I like to read about car stuff. Engine configuration is one of them.
By the way, due to their nature, I4 is never as smooth as V6, correct? To come back to theory, if I4 has perfectly designed counter balance (Forgot the name of the part), why can't it be as smooth?
For a 4cycle, 6 cylinder engine, you will have 3 total power thrusts in a revolution, the power thrusts spaced at 120 degrees apart.
For a 4 cycle, 8 cylinder engine, you will have 4 total power thrusts for each revolution, the power thrusts spaced at 90 degrees apart.
Hence there are more evenly spaced power thrusts for an 8 cylinder car, and therefore smoother.
Torque is usually related more to how far off center the crank arm is. The pistons attach to the end of the crank arm. If the arms are longer, the piston has more leverage or power over the crank, and it has more torque. It also means that the piston travel up and down is further. However, the longer the arms, the harder it is to spin it fast.
The counter balances you reference, are weights that are built in to counter balance the other moving parts, to keep the offset weight from causing vibrations (thereby making it vibrate less and appear smoother). This is a different smoothness than I'm talking about earlier, with the amount of sparkplug firings per revolution.
With 4 cylinder engines, they seem to hit the wall on vibration when they reach 2.4L or so....after that, it gets dicey.
You think about replacing the MAF sensor.. instead of just cleaning?
Open the coolant air bleed valve, there is only one,it's located on the thermostat housing.
When you're filling the radiator, if coolant starts coming out of valve close it..otherwise close the valve after the radiator is full.
I don't know about the additive.. the manual states it unnecessary and "may be harmful". I always say if it ain't broke don't fix it... so up to you on that one. But, the Dexcool is suppose to be changed every 5 years or 150,000 miles, whichever comes first. Some people here recommend sooner than 5 years.
Heck, I would proably just change the MAF sensor. I had a free diagnostic code test done free at our local Autozone... code read the problem with the MAF. The dealership wanted $89 to run the diagnostic test and diagnoise to pinpoint problem. I was in a bit of a bind time wise and had them go ahead and do the test, then replace the MAF sensor on my Buick Regal LS. My car was cutting out though on occasion at stop light and slow braking.
Anyhow, hope you can get things squared away.
It's important to remove all the air because one factor in deterioration of DexCool is mixing with air as it's moving through the motor and radiator. Some people recommend changing DexCool every two years or 24-36 K miles just like the abrasive green stuff. DexCool has many good properties that conserve aluminum and other parts of the cooling system. Early seals on 3800 parts in 97 or so were changed in composition because they reacted with DexCool after it deteriorated.
MAF sensor can be removed. I've heard a mechanic talk about cleaning the wire very, very gently like with an artist's brush. If you look at it under magnification it will have dirt particles growing off of it like hairs. But the wire is extremely fragile.
My question is how does the oil cooled piston get the lubrication it needs if there is no way for the oil to get to it?
I,ve posted in other forums to try to get this question answered and am hoping there is some mechanical genius out there that can help me out with this one.
Any and all help would be greatly appreciated.
uteoat :sick:
I have already tried pulling and replacing all fuses, relays and fusible links that I could find. I also tried disconnecting the alternator, starter and ignition switch but the volts would still drop rapidly when the + cable was re-attached. I have also tried chasing down shorts but haven't found anything obvious, yet. Any other ideas??
do you have multiple fuse / relay centers? for example, in my accord, there is one in the engine compartment, but then there are also two on each side of the lower dash.
do you have any power windows, sunroof or seats? those would be my first suspect.
another thing is possible here. that is your fuse / relay center is sitting in a moist environment and somehow shorting a hot circuit to ground.
Vehicles with things like cascade lighting, remotes, alarms and such will often have modules that are still "thinking" for upwards of an hour after the vehicle is shut down.
I put in a new non OEM coolant temp sensor when it first acted up. The temp gage read 1 bar below 200 degrees. Only the car acted up worse due to MAF, vac leaks, etc, so I cleaned and put back the original coolant temp sensor after a few weeks. Ever since, the temp reads half a bar higher. It went down slightly after bleeding out the air. Should I swap back to the newer sensor? Does the temp gage read different because one sensor sends a more accurate signal or because the old sensor makes the engine run hotter?
If the DexCool is red (orange?) it's not been in there 11 years! It should be changed every 2 years but it's 5 years optimum. Actually if you have a voltmeter, put the negative on the ground of the battery and the positive lead into the coolant in the radiator. If it shows more than .3 or .4 volts, time to change out the DexCool because you're getting voltages generated form the metals in the system that shouldn't be due to additives in the coolant having worn out.
The coolant leak... could that be an elbow that seals with little o-rings? In Bonnevilles they often mention that as a problem area.
