Got a Quick, Technical Question?
16364666869114
  • pgshieldspgshields Member Posts: 1
    where is the answer to the question?
    More probably the sender unit rather than just a ground, especially since it reads ok over part of the range.
    Most of these are inside the fuel tank. Fuel tank must be dropped to access it.
  • bwebber1bwebber1 Member Posts: 1
    Daughter took my 93 Chevy Blazer to college and transmission went bad...can't get out of 2nd. Could I drive it a hundred or so miles to get it home? Obviously would have to take the back roads. The terrain is hilly also. Any advice?
    You'd be better off renting a tow dollie, put the drive wheels up on the dollie and pull it home with another truck/large car. You have no idea what the problem is, and driving it futher may tear up other parts if there are broken pieces already floating around.
  • a918doa918do Member Posts: 9
    Any body know how to take off the tail light assembly for replacement. Wife backed into a car and broke the clear caseing and of course now I have to replace the whole thing. :confuse:
  • gliderridergliderrider Member Posts: 4
    I have a 1998 2L Escort Wagon (190,000Km) and a 2000 Altima SE (136,000Km)
    I have reasonable mechanical aptitude and a good set of tools.
    I would like to do my own tranny flushes using synthetic Mobil 1 and wondered if this was a DIY job.
    I believe that the Escort has a filter and that I would need to drop the pan and replace the filter and the pan gasket.
    I have been told that the Altima does not have a filter.
    If I need to buy some equipment or tools (a fluid pump?) as a one off expense that would be OK.
    Could I ask you these questions:
    1. Is this a DIY job?
    2. Can you either point me at a resource where I can get some generic instructions on how to do a tranny flush or can you give me the basic steps to follow?
    Thank you for your help,
    My opinion: I don't believe in tranny flushes for high milage autos. And I feel both your cars are high milage.
    Flushes on high milage cars have the possibility of breaking loose some 'crud' which does not flush out, but does lodge in some place where it will cause a problem.
    Look at the owners manuals. There may be one out there that does call for a flush, but all I've ever seen just call for a drain of fluid, change of filter (if there is one), and refill with the same type fluid.
    If the original tranny fluid has gotten you to these milages, why are you considering changing to some other type (synthetic)? Removing all the fluid from auto trannys is about impossible (it will not drain out of the torque convertor, leaving about 40% of the fluid undrained). So, you are going to be mixing two different fluids if you go to synthetic.
    So, my advice is to just drain and refill with original fluid called for in your owner's manual.
    Can you do this? I don't know. Most auto trannys will NOT have a drain plug. You will have to drop the pan. Sometimes there may be 'something else' in the way that must be removed. Not much you can do (without a service manual) except crawl under there and look. When you 'drop a pan', it's a mess. Fluid will start pouring out all around the pan. Unless you have a huge catch pan, you may make a big mess. The pan and fluid that remains in it is somewhat heavy, so you have a potential for even a greater mess. Tranny fluid stains, is oily, and thin and runny. You've been warned....
    Thank you for the information Bolivar.
    In answer to your question, the reason I wish to use synthetic is that I have had it extend the life of a Mercury Villager tranny that was at 168,000km and had developed hard changes from 1st to 2nd. After adding Mobil1 the hard changes disappeared and I sold the vehicle 11 months later at 189,000km with the tranny still performing normally. A friend had slippage problems with a Subaru and followed my recommendation to use Mobil1. In his case the vehicle is still running two years later and 62,000km later with no tranny problems. Two cars do not make a scientific study but this is what I am going by.
    In terms of loosening crud in the tranny I was wondering what a tranny flush would do that might be different to a pan only fluid change?
    Also I am probably wrong but I thought that Mobil1 was compatible with regular tranny fluid?
  • jasmith52jasmith52 Member Posts: 462
    While a tranny flush may or may not be advisable here is how to do it...
    1) disconnect the transmission fluid line (input line) at the radiator (The transmission fluid is cooled by the radiator just so you know).
    2) take a small diameter hose and put one end over the transmission line. Put the other end in a bucket to catch all the old fluid.
    3) have somebody poor clean tranny fluid into the reservoir from the top while the tranny pumps fluid out of the line into your bucket.
    4) when the tranny fluid runs clear you are completely flushed. Stop the engine and reconnect the tranny line at the radiator.
    jasmith, I agree to your procedure for a DIY 'flush' without any power pump involved.
    Here are a few possible points.
    -The metal lines into the radiator may be difficult to remove. If there is a rubber line in there (used many times as a flex joint between the solid steel lines and the radiator), I would break the lines there. Usually jointed by screw clamps. If there are no rubber lines, take care to not rip the line out of the radiator. Speaking from experience of changing a radiator, these connections can be very tight.
    -You will have a 'balancing' job of guaging the outgoing flow, and pouring new fluid into the fill tube. You don't want to let the fluid run low in the tranny while the motor is running. This might cause severe problems, quickly.
    Jasmith and Bolivar thank you for the information on the procedure for flushing the tranny.
    I was just out at the car and there are rubber pipes connecting the radiator to the tranny.
    Bolivar's warning about keeping a balance between the fluid going to waste and the new fluid being added is well taken. Does anyone know how much tranny fluid the sump under the tranny holds?
    Well you've got another problem when trying to do this yourself. Many cars don't have 'dipsticks' anymore, so you can't check the level of transmission fluid when you are all done. If you don't get this right (too high, or too low), you'll have problems.
    With the cost of replacement transmissions, I started taking this to the dealer to get it done right.
  • jipsterjipster Member Posts: 6,302
    ...balance between the fluid going to waste and the new fluid being added...
    How about drain a quart... add a quart? Start off with an empty quart bottle.
  • imidazol97imidazol97 Member Posts: 27,787
    It sounds like the process is add fluid at the transmission dipstick fill tube while the pump takes it out to the tube at the radiator.
    I had thought (and changed my mind) about doing a flush by connecting to both tubes at the radiator. For the one going back to the tranny just connect it to something like a 2-liter bottle with the bottom cut off and keep fluid in it (2nd person holding it and pouring in bottles of transmission fluid) while the fluid coming out the other tube is caught in a container.
    When the fluid coming out through the clear plastic tube is clear, you're done, and probably have used about 15 quarts for a 12 quart transmission.
    I decided to do the gentler thing and drop the pan and replace 6 of the 12 and do that 2 ro 3 times in a row. Essentially get complete change without shocking the crud in the transmission.
    Drain a quart, add a quart. Assuming that you start with the tranny fluid level at the full mark, could you do any damage to the tranny by letting the level fall by 1 quart?
    From what I have read from others who have done this procedure, you wouldn't do any damage to tranny.
  • essilemessilem Member Posts: 5
    I've read through ALL the forums searching for a possible solution to my problem and I haven't exactly found what I was looking for...
    My car starts up fine, but many times when I start it non of the guages, radio, A/C, OnStar, Cruise, etc. will work. Turn signals and hazards work fine.
    Took it to the dealership one day when it was actually acting up, and the guy said he wasn't getting any error codes on it at all...which I believe, I was standing right next to him in the parking lot. Checked all the fuses, no issues there. He says it could be an ignition switch, but not sure. I'm reading that it's possible it the bcm.
    By the way, this usually only happens when it's warm outside. I'm from NE OH, so yesterday when it was 80, they didn't work at all. Today it was 35, and everything worked fine.
    Any ideas?????
    That sounds like ignition switch to me. A wiring diagram would help - see if the non-working systems get power from the same contacts in the switch.
    I agree with burdawg.
    Curious though, if the car starts running what happens after a few minutes? Do those things start working? Or do you have to shut down and restart in order for them to work?
    but troubleshoot first. don't just replace parts.
  • bull3bull3 Member Posts: 3
    I have a 1994 f-150 pickup with an inline 6-cyl., 5-speed tranny, with 2-wd. you have to push the clutch pedal all the way to the floor to get the truck into gear. I've checked the clutch master cyl. and it is full. Is there any adjustment on the inside of the bell housing? or do I have to completely replace the clutch assembly?
  • toomanyfumestoomanyfumes Member Posts: 1,019
    Someone else might be able to answer this better than me, But I think hydraulic clutches are self adjusting. Probably needs clutch replacement. My 1989 Ranger I had did the same thing and I ended up replacing the clutch.
    2012 Mustang Premium, 2013 Lincoln MKX Elite, 2007 Mitsubishi Outlander.
    Could be a clutch but I'd replace the Master and Slave cylinders first before going for the clutch. Also make sure there is no air in the system.
    -mike
  • crankshaftcrankshaft Member Posts: 105
    I believe the slave cylinder on these vehicles is inside the bell housing.Might as well repl;ace the clutch.Mine started to fail this way until the clutch stopped disengaging.The clutch was all bound up inside.Slave and master cylinders were ok.
    Ah ha, thought they were external, that's why I suggested to do them first.
    -mike
    Oh internal slave cylinders. Shades of Saab automobiles. I hate that type of cylinder. If they collapse it's a real pain.
    Have a 2001 Villager. Both boots over the front CV joints are completely split all the way around. I'm going to try to replace them. Do I try to pack grease around the CV joint? Just regular grease like in a zerk fitting? I'm thinking just take a chisel to break the old clamp attaching the old boots? Any other tricks to know? Thanks in advance for any help.
    Here's some info:
    http://www.automedia.com/CV/Rehab/ccr20021101cv/1
    No! NEVER use chassis grease. You need a special high temp, moly-based CV joint grease that you can easily find at Kragen, NAPA, etc.
  • coderedcodered Member Posts: 43
    i have a 90 Lumina.....it has a noise that kicks in round 40mph......its not there when wheel is pulled to the right...i was told driver side wheel hub...but still not fixed .....any info would be great...thanks
    Thanks for the link, Shifty. However, I was thinking of just replacing the boots. I'm hearing no clicking when I turn the wheel. Isn't there a replacement boot that's split and be installed without removing the hub? Do these work and hold the grease in? I changed the oil in December, gave the front end a quick once over, and noticed nothing. Changed it again today, and both boots split all the way around.
    Yes there are split boots but not for all cars.
    It's such a stinking nasty job....blech! But yeah, if you can find the split boots, that might save you some money. But by all means check on prices for rebuilt half-shafts. If your CV joints have more than 80K on them, and/or if they've had split boots through a rainy season, you may want to consider half-shaft replacement.
  • mr_pralinemr_praline Member Posts: 3
    If you had a 10-year-old Honda Accord missing a wheel well liner, would you bother to replace it? I assume its main function is to keep out rocks, road salt, water, etc., but is this risk worth the cost of replacing the liner on a car this old?
    Thanks for any insight.
    I guess it depends on the condition of the car and whether you live in an area that uses road salts, or in a beach environment. You might see if the wheel liner would also prevent any damage to electronic components if you hit a deep puddle, etc.
    Had my mechanic check it out today. He hasn't had much luck with the split boots. He said what you did, as long as it's apart, and with the boots being split through winter, he's going to look at rebuilt half-shafts.
    It sounds crazy to do that for only split boots, but in terms of overall outcome, it really makes sense. If you go through all that mess only to have a clunking CV joint in 5,000 miles, you are going to be very unhappy AND you'll have to do it all over again.
    I've done it both ways and except for my Porsche, where the CV joint was outrageously expensive, I opted for rebuilt half shafts. Porsche makes a very nice split boot...even so, I took the half-shaft out of the car to install the split boot, as the whole thing was so disgusting to work on. That grease is like some blob from a horror movie! :P
  • kecajkecaj Member Posts: 4
    Why do dodge recommends 89 not 93 for the hemi in magnum ???
  • 0patience0patience Member Posts: 1,712
    I totally agree with Mr. shiftright on not using the split boots.
    Trust me, you will end up replacing the CV shaft sooner than later.
    Your mechanic made a good call.
    Sounds like a reputable guy.
    Because of the compression that the hemi is run at, the higher octane runs better and has less problems with detonation/pre-igniton/pinging/spark knock (depends on who you talk to, as to what they will call it).
    Pinging will cause the knock sensor to detect pre-ignition and retard the timing to prevent the spark knock. This can be a good thing or bad thing, because when the computer advances or retards the timing, it affects fuel economy and emmissions.
    Clear as mud? ;)
  • spoonsspoons Member Posts: 1
    I have a 76' Surburban w/ electric rear window. Motor takes window down but not up. Took it off and bench tested it, motor spins both ways. Re-install and it's the same problem.
    Can the motor be taken out and replaced with rear hand crank?
    Spoons
    Can you test it in the door using an independent current supply? It's possible your switches are bad or your wiring harness.
    If the motor works both ways on the bench, and will not respond in the door, and it's not jamming (trying to work) then it's definitely the wiring.
    Could also be the regulator, especially if it will go one way but not the other. When I had the 85 Suburban (for years and years) I had trouble with the back window a couple of times. In my case though it was the safety switch on the side of the tailgate, which disables the window if the tailgate is open. The contacts would get oxidized and the switch wouldn't work.
  • brknrodeobrknrodeo Member Posts: 3
    Man have you been takin for a ride. The Isuzu has a recall on the 1999 ABS. Hopefully you have already found this info out.
    That's true, but if it were the regulator itself you'd hear the motor trying to push. Oh yeah, safety switches---that's a good thing to look for!
  • titan1970titan1970 Member Posts: 2
    I just replace my spark plugs with bousch platinum 2 and now iam getting 1 mpg less than I was before the switch, what's up with that? Also i was unable to torque the plugs due to space, but i wrench them on pretty good without over tighting will that be a problem not torquing them.
    thanks tony
    What year, make, model and engine??
    My crystal ball is in the sop, so I don't know that info.
    Anyways, what plugs were in the engine, that you took out?
    What does the manufacturer call for.
    Replacing spark plugs in todays engines, they need to be replaced with what the manufacturer calls for.
    You see, the computer "sees" the resistance from the spark pugs. If you change the spark plugs to something with different resistance, then the computer tries to compensate for the resistance it is reading.
    Well, it is a little more than that, but you get the idea.
    I'm late but I'll concur. On the Subies the wholesale price is about $75/axle w/CV etc well worth the money.
    Not sure how expensive they are for your car but still should be worth the replacement.
    -mike
  • smeyerssmeyers Member Posts: 1
    Will a 1994 jeep cherokee auto transmission fit in a 1991 jeep cherokee?
    It goes in Wednesday so I'll see what my options are but I have a feeling it's getting new/rebuilt axles. I've known this mechanic over 20 years so he's pretty fair on prices. Charges me cost on parts and I pay for labor of course. I guess it's worth it to fix it right since this the family truckster for vacations/travelling etc.
    it is a 2006 dodge ram 1500, v8, 4.7 liter and autolite was in there, to be honest i am not a mechanic and didn't know that the brand mattered.
    tony
    It's a 2006 and you are changing the plugs??
    Why?
    The 4.7L is equipped with copper core ground electrode spark plugs. They must be replaced with the same type/number spark plug as the original. If another spark plug is substituted, pre-ignition will result.
    The car actually always runs fine, and nothing happens, even after a few minutes. Not even if I turn if off and back on. Some days everything works the first time I start the car, but if I turn it off and back on, they won't work again for the rest of the day.
