There's a Buick discussion and a couple of Bonneville discussions here.
One thing that sometimes will prove this is to firmly hit the dash above the tach with you hand and watch for the malfunction.
Saw this on a 79 Olds Calais and drove folks nuts until the problem was found. Soldered the jumper down and the problem never came back.
I've been told that its the timing belt, but I'm not sure.
Anyone else have this experience?
glaroya@yahoo.com
Could be drive belts or idler pulley or bad alternator bearing.
One quick thing you can do is spray just a little WD-40 on the belts before you start it up cold and see (hear) what happens. Or even rub a bar of soap on the belts inner side, with the engine off of course--LOL!
... the rims I spoke of, ARE IN FACT OEM's ... replaced them with identical factory insatlled originals and since the problems occurred before replacement (twice) and continue after they were installed, I'm pretty confident this isn't the problem ... where do I send the gratuitous pizza and beer for all of the money you guys have saved me in the past? I'm about to buy a 95 Cutlass Supreme Convertible so Im sure I will be asking for more help when the needs arise.
What's the typical life of an alternator belt? I needed mine replaced due to severe cracking. The car is 5 yrs old and only has about 34K miles on it.
Should an alternator belt typically last longer than this???
The owner, over the past year, replaced the water-pump, thermostat, hoses, belts and had a new core put in the radiator. The engine now has a blown head gasket, so I am thinking this could be a good project for he and I to work on together. I have reasonably good mechanical skills and have the tools we'll need, I think.
My questions are:
Is this a project we can do by ourselves in our home's garage, or does it require specific tools and equipment that we're not likely to have?
My assumption is that when we remove the head, we should take it to a head-shop for checking, have it resurfaced, and if necessary, have the
valves ground, etc. Are there any other things we should be aware of?
What should we expect to pay for new gasket kits, bolts, etc. from an after-market parts store like Checker, AutoZone, etc.?
Is there a good place to get these materials by mail-order or online source that has really good prices?
I've also heard that these engines are prone to blowing head gaskets. Is that true? If so, what is the cause, and is there a fix for this?
Is there anything else we should check while into this project? Like, change engine oil and filter in case any coolant got into the crankcase when the gasket blew, or any other things not mentioned
above?
Thanks for any advice and suggestions you can provide.
Lee
I would be assuming that if you MUST have this car, that you are going to put a running junkyard engine into it. warning, if you don't match the engine model and year and application up exactly right, be sure you get the computer module that was on that engine with it. the modules are standard, the programming for each engine/transmission combo is specific.
myself, hearing of a blown head gasket is enough to keep walking. sounds like the old owner is from the "throw enough parts at it, and eventually you fix the issue," and he diddled around with overheating long enough so that the real cause -- leaky, then blown head gasket -- has had a real good shot at blowing the engine. put every possible part in EXCEPT a head gasket. guess we know why he's selling it.
this thing's old enough anyway that it probably needs a ring job, so we're talking about having everything machined in a shop, full disassembly, get all new running parts inside the block (several hundred dollars or so) plus a new oil pump and screen Just Because You Can, a hundred bucks worth of gaskets, on and on. gut feeling is you're into $1000-1500 doing all your own labor, including the machine shop charges, on the engine alone. it might not be salvageable either, some used blocks just won't dress up before you exceed the maximum rebore specs.
run, don't walk, away from this one. the mill is a doorstop.
Given that this happens in reverse, when there is no load on the engine particularly, I would suspect the fuel filter which I believe sits inside your Cherokee's gas tank.
The only glitch that gives me doubts is that your car (you say) performs well in passing gear, which somewhat contradicts a fuel starvation problem.
In a way, your symptoms don't quite make sense, but you should be the best person to report them accurately.
Another suspicion I have is your engine's distributor.
there have been a load of posts about a year back about goo coming off the inside of jeep gas tanks gumming the fuel systems up from about that era, and it could mean replacement of the gas tank. so I can see where shifty is coming from. I'd still like to pull a couple plugs and look 'em over good myself, see how the wear is, and go from there.
Reverse really shouldn't have much load on the engine, since a low gear doesn't strain the engine at all---like the lowest gear on a mountain bike is the easiest to pedal.
so my reasoning was that ignition systems usually require a load to show up. There's really no reason why a plug should not fire in reverse gear but fire in first gear.
Now a downshift into passing gear decreases the load on the engine/ignition but the higher revs should consume more fuel, which makes me wonder why the engine doesn't miss on downshifting.
This contradiction in turn makes me suspect the distributor, which can act somewhat randomly.
I've seen this kind of problem on the Jeep 6 cylinders, and they can be devils to diagnose, absolute devils!
Hope you get lucky on this one.
I'd go from "simple to complex". So plugs, wires, external fuel filter (not the gas tank one), maybe some very nasty injector cleaner (or done with a machine through the intake manifold) then to distributor (you can check it with a light and also check it for tightness and moisture), then maybe we have to drop the tank if none of the above works. And if THAT doesn' do it on top of all the other things, then you are in the Jeep Hell I spoke of, a Land of Mystery and Anguish. Let's not even talk about that, it's probably simpler than that!
Still, your idea does connect the two seemingly disparate situations....going in reverse creates a problem and downshifting cures it...in both cases you get engine motion.
Diagnosing engine mounts isn't too hard. Lift the hood, start the engine, foot on brake, put it in reverse, and depress the gas with brake FIRMLY applied...and peek through or around the hood and see if the engine jumps up to say hello every time you touch the gas.
getting to the basics, you have to have fuel, air, and spark to run an engine. if it dies suddenly, fuel and spark are the most likely culprits. fuel could be interrupted by the computer, a relay to the fuel pump, the fuse, bum wiring, a dead fuel pump (if you never reach the bottom third of your gas tank, you are much, much less likely to ever replace a fuel pump.. fuel cools 'em, and they need to stay covered.) spark could be interrupted by the computer, any of a dozen sensors, a bad coil or coils, potentially no fuel delivery if this is interlocked with a pressure sensor, or voltage too low to run the computer properly. if battery voltage drops below 10-1/2 volts when cranking, all bets are off on whether anything is going to work correctly.
just pushing the test port Schrader valve on the fuel rail and getting a spray of fuel under pressure isn't really a good test of having fuel, because it has to be within a range of pressure for the computer to utilize the fuel accurately in a modern engine.
no, if you can't switch fuses of the same size around and get started, I'd say it's time for a tow and a mechanic with diagnostic equipment to look at it.
Hey guys, isn't there a spray that he could try just as a longshot?
Have you ever heard of Web sites that evaluate photos of your damaged car and help you get repair quotes, such as dingit.com? Please contact jfallon@edmunds.com if you know anything and/or have an opinion about these services.
MODERATOR /ADMINISTRATOR
Review your vehicle
Real Men might try taking the two halves of the evap housing off, and clean the fins with soapy water and a hose. those Real Men would then have to seal the housing up again, and hopefully wouldn't have put weight on the assembly in the process, also getting a real good chance of breaking the tubing or coil and blowing a bunch of dead presidents for experts to fix up after them.
you wouldn't believe the amount of crud that settles into that wet-finned coil. one of my pet peeves is that there isn't a filter ahead of the evap to catch that slop. it might have something to do with having to take my 76 buick's system apart and scrubbing out the evap with a brush in the sink to get any air flow through it.
then again, it might not...
Check engine light came on Friday morning. Then, the temperature guage started jumping up and down, one second it was normal, the next it was near the red mark. Took it to the dealership. They said the temp sensor was bad. They replaced it but it still had the problem.
Now for the strange part. I started to drive it home and the RPM s were jumping up and down. I had to push hard on the brake at the first red light to keep the van from lurching forward. Most of the warning lights also flashed on and off. I started from the red light and the van jolted back and forth and I could barely excellerate. Barely got it back to the dealership. It's there now but they aren't even sure what the problem is.
In the meantime I've learned how to release the pressure on the shock (pull a little cap thingie and the car drops about 8 inches). Still would very much appreciate hearing if any others have problems with the automatic levelling system .
the whole package appears to have one thing in common: the engine computer. I'd clean the connector up, tighten the grounds up, replace the fuse, and try again. if that didn't do it, I'd try flashing the thing. they're going to be reluctant to change it out, electrical stuff can't go back on the shelf, but that's a strong, strong suspicion I have.
air suspension systems are a very common complaint, and the cost to fix these things, assuming they can get parts, is in the thousands.
most folks roll back to a standard suspension, at slightly reduced cost.
there's a reason I didn't buy the pearl-white explorer on the lot... it had automatic air suspension. you take the labels off the parts, and they are all stamped MONEY PIT EXTREMO.
it would cost less to have some specialty shop make your air system over as a hopping car
Sir,
I have a Honda Civic92 DX, 2 door Hatch back. Some times at Idling speedometer needle points 100km/Hr and returns to 0. most of the times it does not show the actual reading instead shows 0 km/hr. after a bump on the road needle again picks up.
I changed the speed sensor but problem still remains the same. The dealer said I have to change entire system at a minimum cost of C$ 750+Labour [ or more ]. Is this a typical problem? I can tackle at local garage?
Need your suggestion.
-Hewlett
Brampton Canada
