Visitor Agreement.
or bad head gasket.
Sounds just like my Mazda truck. Bad lifters AND a cracked head.
hmmm... would a stuck valve give smoke? i guess that wouldn't necessarily burn oil, though.
Could always run a compression test and at least eliminate SOME possibilities.
and i checked the blinker lights and the front right was out
could this be why its not blinking at all not even on the dash.
Or you could do this. Put your thumb over #1 spark plug hole. Disconnect the coil so the engine can't start. Then rotate the engine by hand or by remote starter until you just feel compression under your thumb (maybe you can do this with a breaker bar on the crank pulley nut)...when you feel compression, you should also have a) rotor in distibutor pointing to number one wire b)both valves on #1 loose and closed.
I don't mean to scare you but sometimes the timing gear marks are punched wrong at the factory.....unlikely but you never know....
worn suspension part causing car to drop slightly on the left
malfunctioning caliper or caliper slide
grease/debris on rotor or brake pad
Does anybody know where the associated relays are located? There could be one for the day/night sensor. Is there another?
Problem: turning lights do not flash anymore (front left or right, rear left or right) but they are on (not flashing) when signal is on. The turning signal inside the car turns on but does not flash also. However, when turning on the emergency light, all 4 lights flash properly. I have replaced the 4 lights to no avail. What next?
This relay flashes both the left and right turn signals.
Check your owners manual for the location, look in the index under fuses. I believe ?? it's on the topside of the fuse panel.
voltage regulators on the alternator may be bad. possibly a bad / loose connection or broken module.
see if you can't get a replacement from a pull-it place or parts store. how much does an alternator cost? can you return it if it's used? I know, stupid question. maybe a whole alternator assembly from a pull-it place.
ther other possibility i suppose is perhaps some intermittent short in the battery. i'm just WAGing though. hopefully someone else can add more.
Obviously you have fuel in the line but it's not getting into the intake manifold. Perhaps there's a clogged filter inside the carb/throttle body? Of if it's a real carb, a stuck float bowl?
could be the clutch is shot. Or it could just be stuck. Or it could be the slave cylinder or clutch master cylinder. Pretty much any clutch component.
It will go in the space for all the gears but will never lock into gear. When I first got to it, it would go into rev. and 4th gear. Now it will not lock inot gear. I can see the shifter moving the controls on top of the trans but that is it. I got I home late so I will look at it tonight.
so you are saying it goes into the slot for the gear, but then nothing happens? It doesn't pop back out of the slot or anything? Have you tried holding it there and see if you can accelerate? If you are getting nothing while the gear selector is in the slot, I would have to guess that the gears have been stripped clean. That would be pretty odd, though, unless something else caused it to happen. I might say synchros, but usually that involves grinding and popping out of gear. Maybe that happened first and it was abused to the point all the gears stripped.
I'd also like to know things like how long your daughter has been driving a stick and what her habits are.
I'm wondering if some linkage pin has fallen out. This, however, would make the gear shift lever feel like it wasn't attached to anything at all. (no resistance)
In theory, with the engine running, this car couldn't actually be going into gear. The clutch must be working to allow you to enter a gear..so it must have busted some linkage or some internal part in the transmission has cut loose entirely. At least from what you say. If I were in the car, I'd know more.
once upon a time, wife got a new half-shaft and CV joint because our '94 Accord Manual was exhibiting the brrt brrt brrt and the CV boot was gone and the packing lost.
following replacement, wife driving, gets to intersection, puts it into first and hears grinding. Vehicle/Trans is in first, but no forward motion....
you may need lots of wine if you fubar some gears though.
good luck.
A. that with the engine running, you can put the car into 1st gear, let out the clutch, and the car won't move?
OR
B. with the engine running, the gear won't go and just grinds or jams?
If A, you've busted linkage or internal transmission parts or severed a half-shaft completely
If B, you have a bad clutch slave cylinder or bad clutch.
Like I said in my last post i can see the shift linkage moving I have not looked at the Clutch linkage
Were Do i start looking on the car to find out what is wrong with it.
Read over (A) option again. It either is or isn't doing this. There should be no uncertainty here at all. Once you're SURE what's happening, get back to us and we can tell you where to look for trouble.
If you can start the engine, put it the clutch, put it in gear, and the car doesn't move, that's A.
If you start the engine and CAN'T get it into gear without it jamming or grinding, that's B.
It's either A or B.
Here's another test but you MUST be careful.
Make sure there is nothing in front of the car. Put the emergency brake on REAL tight.
Do NOT start the engine.
Put the car in 1st gear using the clutch pedal, then release the clutch pedal completely. Make sure the car is in first gear and the clutch is released.
Now put your foot firmly, really hard on the brake
Now turn the key.
Did the car lunge forward, (B) or did the car start up like it was in neutral? (A)
If A, you've busted some linkage or internal transmission part or severed a half-shaft
If B, you have a bad clutch or clutch slave or clutch master cylinder.
If it's A, there's nothing you can do without a lift.
If it's B, check the hydraulic fluid level in both the clutch master and clutch slave cylinders.
Standing of the engine I can grab the balance weight and I can move it around and it sound like it is going into gear.
I don't know if i a\said it was a 2002 beetle
You put it in gear, have the brakes on, and tried starting. The starter would try to turn the engine, but the engine is in gear, and the tires won't turn because you have the brakes on. If the clutch would have disengaged correctly, then the engine would be free to start.
If that's the case, then yes, you have a bad clutch or master or slave cylinder.
I don't know what you mean by "did not start". That's something new again....
You can check the axle shafts and I think you could have someone pump the clutch while you check to see that the slave cylinder (or cable, whichever is used to operate the clutch) is working the clutch fork. It should move about an inch or two when you pump the clutch. You might even have broken a main shaft in the tranny.
As for checking linkage, I don't know the car well enough to know if you can remove the shift boot and look down there. Maybe you'll get real lucky and just some pin fell out of the gearshift lever!
you can't get it into gear while running. but you can get it into gear while the car is off. SO, how bout pushing the clutch in, putting it into 1st, THEN starting the car and then letting out the clutch.
It is still bothering me that you can't get it into gear while running, yet you can put it in gear while off and push the car around. These 2 things don't typically go together. If you can't get it into gear while running, that usually means the clutch isn't releasing. But if the clutch isn't releasing, you shouldn't be able to push it around the yard while in gear.
Couldn't hurt. I never did understand his explainations of what was and wasn't working and/or when??????
How about this:
Put car in neutral, take off emergency brake (LEVEL GROUND!) and push the car and see if it rolls.
Okay, it rolls.
Step 2
Put car in "gear" or what you think is in gear, and try to push the car and tell us what happens. Try different gears and trying pushing each time. Try reverse as well.
Also, is there a separate module for the alarm system or are the two integrated?
It seems the doors unlock at random. If the alarm is set, then the alarm sounds. To me that implies the car doesn't "think" it was the remote that unlocked the doors.
We were sitting in his driveway last night having a cold one and every few minutes we could hear the door locks "click". In one case, we locked all the doors (alarm not set). In a few minutes, we heard the click and is seems only the driver's door was unlocked. To me that means the lock controller thought that someone unlocked the driver's door using the inside door handle or key in the door.
The car has an aftermarket remote starter system. He has taken the car to both the dealer and the guys that installed the remote starter. Both say their parts check out and it must be a problem with the other's equipment.
Thanks in Advance
PeteCal
Also, last night we were driving down a country road and it clicked two times. There was no other cars or houses around and his remote was on the key chain.
It has happen at other times like when his remote was in the house, beyond range (we tested that) and while in the parking lot at work.
I just need to open up the door panel and also the control module and do some continuity checks. That is why I would like to know the location of the control module.
Pete
They said it had a bad electrical problem. But Friday when I talked to them they said " We cant figure it out. Dont have any Idea. And we probally wont." Is there sonethig else that causes this? They said the replaced the dashboard selector. But, still couldnt control it.
