Visitor Agreement.
Provided they have proper jack stands, jack and some front end tools.
Most the tools for the front end work can be rented at most quality parts stores.
But I will agree that a puller is the best tool.
This is the tool I use.
i can get myself as far as jacking the car up, removing the wheel, then i don't rightly know what i'm looking for...
feel free to refer me to another more relevant thread too, if this ain't the place to be...
If the vacuum hose is damp or smells of fuel, replace the fuel pressure regulator and change the oil and filter.
Check fuel pressure. Specification: approx. 2.5 bar (36 psi) .
Disconnect vacuum hose from intake manifold upper section at fuel pressure regulator (arrow).
The fuel pressure must rise to approx. 3.0 bar (44 psi).
Let us know what you find.
I haven't experienced it myself, but it will run along fine, then the guages go wonky, and everything electircal (and of course the engine) ends up dying out.
Normally, it will immediately (or withing a few minutes) start back up and run fine.
I am assuming that it needs a normal electrical system back track (battary, cables, grounds, etc.)
But, does anyone have a bright idea of something sneaky to check?
That sounds like one of those hard to diagnose problems, certainly for a DIY without proper tools!
I have a 2000 Nissan Sentra XE with auto transmission, about 80,000 miles, 1.8 liter, I think, with a sticky gas pedal problem. The gas pedal sometimes sticks when going from the brake pedal to the gas pedal, when you first go to accelerate. However, in the past month I have had two instances where I start up the car, put my foot on the brake, then go to step on the gas pedal to find the gas pedal seemingly completely depressed and it won't go anywhere. I'm not really sure what is going on but the bottom line is you can not accelerate at all. The first time, the gas pedal released after going back and forth to the brake pedal. This last instance I shut the car off and started it up again -- the car was fine after I restarted the car. Could this be an electrical problem? What would cause the gas pedal malfunction.
Thanks for your time.
I've only had this happen on one vehicle and removing the cable and spraying a lot of WD40 in to the housing and working the cable back and forth fixed the issue.
In your case, I would also try lubing the hinge points on the pedal assembly.
i think you can find it on the H&A web-site associated with a new radio installation.
one QN: what's a SIL? :shades:
My understanding is that an O2 sensor reads the amount of oxygen and tells the computer to adjust the air/fuel mixture accordingly. It will continue making adjustments UNTIL it cannot adjust the computer enough to get the right mixture, ONLY THEN will it trip the CEL.
Given this understanding, why would it not be possible for an O2 sensor to THINK it is properly adjusting the mixture when, in fact, it is fouling it up? Let's say, for instance, the air receiver on the sensor gets gunked up. How would it know? All it knows is that its not getting enough oxygen, so it adjusts the mixture until the reading is correct. Since it is not reading it fully, its not ACTUALLY correct, but it THINKS it is correct. Know what I mean?
Maybe I'm totally off on this. I don't know. But I can tell you that just the other day I pulled the O2 sensor on my '86 Alfa. I have failed emissions with this car and am trying to figure out why. The O2 sensor looks HORRIBLE. I don't see how any air is getting in there at all. And based on the readings from the inspection station, I am running very rich. Yet, I have no CEL. I'm waiting for new exhaust gaskets now before I can put it all back together and find out if the new O2 has fixed my problem.
By the way, an OEM sensor can cost quite a bit of money, so I'd hate to tell you to do it for the heck of it. BUT, there are universal sensors available that are MUCH cheaper. I'd ask your mechanic if he can fit one of those for you. I used a universal on my mazda pickup and it works just fine.
In either case, you car appears to be running very 'rich', with unburned gas probably being burned in the exhaust system, and this is the increased heat your are finding. This increased heat is what is damaging the cat converter.
Causes of over rich condition is what I would look for.
-A vacuum leak might be one problem (into the intake?) which would be making the sensors think the car was running lean and increasing the gas flow.
-Bad injector/s that remain open and allow gas into the cylinder/s which is then pushed into the exhaust system unburned.
-Bad fuel pressure regulator that could be over-pressurizing the injectors, or allowing gas to leak into the vacuum system, where it is being pulled into the exhaust?
More experienced mechanics probably know of other things that could cause a car to run overly rich.
Not necessarily.
The O2 sensor can still be working with in the specified range, but slow to switch.
On a 92, it isn't like today's vehicles where the computer will show a slow O2 sensor. Unless they actually checked the O2 sensor with a labscope, they really won't know.
The 92 is throttle body injection.
As bolivar stated, there are several causes that can cause your symptoms, but just because the light didn't come on, doesn't rule out the O2 sensor as the problem.
My questions would be, how was the timing set?
If the timing connector wasn't disconnected when the timing was set.
You shouldn't have to adjust the timing for altitude, that is what the MAP sensor is for.
First thing I would do is check for vacuum leaks.
Then set the timing to what it should be.
Then run a compression check.
Next would be check the fuel pressure and see where it is at. Possible that it is running too high. If the fuel pressure regulator is bad, that would be a symptom.
The next check would be to see how much play the timing chain had. If the timing chain has stretched (which on a 92, if it has high miles and has never been changed, it will be), then resetting the timing all you want won't get the ping to go away.
Without having the vehicle in front of me, it is hard to tell what is going on, but those are some things that should have been checked.
Sounds like you found the root cause of your problem.
It also allows coolant to burn thru the cylinders, which causes some mixture problems.
Sounds like this new mechanic is good. (Not just cause he agreed with me.)
He seems to be thorough, knowledgeable and reasonable.
And I really like the fact that he explained things to you.
So please, as another mechanic, make sure you remember this guy the next time you need work done or your friends need a recommendation, sounds like he earned it.
Keep us posted on the outcome.
Folks don't seem to realize the importance of those "little" facts. :shades:
But I'm glad he tested the O2 sensor and really checked things out rather than just throw parts at it as others have done. I agree with others here, too, it sounds like he is good. Hopefully this will cure your problem.
Usually however, a whining problem like this is usually one of the accessories or pulleys. Turn the engine back off, and try turning each accessory by hand now, to see if you can feel which of the bearings are bad. It is pretty easy to feel most of the time. Replace the part that is bad, and consider putting a new accessory belt on while you have everything apart anyhow.
Remember this mechanic and spread the word about how well he treated you and how good a job he did.
It is very important that you do this.
"My new mechanic told me he took the time to explain everything to me carefully because it was obvious to him that I had been on line asking for help and understanding. He knew that I had the “I need to know why, how, and for what reason” thing inside of me. "
He had respect for you, your thoughts and your desire to know what is going on. You found a good "honorable" mechanic. Sounds like he is more of an "old school" mechanic, which in my opinion, being one, are the best kind.
Oh yes, to add to what Mr Shiftright said........
If you have time on a warm day, bring him a 6 pack of beer or root beer (some guys don't drink) or on a winter day, run some hot chocolate by. You would not believe how much those little things are appreciated.
I second that! Good mechanics are soo hard to find, we are very lucky to have a great one less than 30 miles from us. He helped us fix our log skidder when no one else would and barely even charged for all the time he spent with my hubby working on it. Its a big piece of heavy equiptment, not exactly a little car, lol. He was just happy to help. They are getting harder and harder to find though, most places just have parts replacers these days.
LOL, oops!! I did just wake up from a nap when I typed that, be thankful everything was spelled right and kinda made sense, lol.
I got a question that I am not sure where I could find some help. I got a 2003 VW GTI that is making a loud whomping noise when I am going from about 25mph to 10mph. The car makes this noise whether the car is in gear or not (It's a manual). Currently the car has 40K miles.
It seems like it is coming from underneath the engine. It also shakes the car a little bit. The noise follows the speed of the car, meaning that when I am slowing down, the frequency of the noise also slows down.
I just had a 40K mile maintenance done at the dealer, but I can't take it back until tuesday, and I was planning on doing a 700mile trip with the car on monday.
Does anyone have any idea what this could be?
Thanks in advance for any help!!
Required Info:
2003 WV GTI
4 cylinder 1.8T
Manual Transmission
40K Miles
Problem: See above
Thanks again!
I believe from your post, that you have indicated that if you put the clutch in and put it in neutral, thereby allowing the engine to idle, you still then get the whomping at car speed, not engine speed. So probably not engine related.
My gut would say it's probably tire rotation speed related. If so, you'd suspect tires, a rotor warped (which would give you a brake pedal pulsation as well when stopping), or a wheel bearing or constant velocity joint.
Another possibility to look at is a very loose wheel bearing, which could be dangerous. So I'd inspect the tire for damage, bubbles, etc., the wheel for being bent, the wheel bearing for looseness, and the axle CV joint for excessive wear.
I drove it again today, and indeed the noise seems to be related to the tire rotation (I was going at around 20mph, shifted to neutral and revved the car. No different in the noise frequency).
I'll go down in a little bit and visually inspect the tires. It seems as if it is not coming from a single tire, but from "both". I'll keep you guys posted.
Again, thanks for the help
It does seem like the tires are wearing evenly. I just had a tire rotation done on the car along with a few other things at the scheduled maintenance. This is when the noise started.
As another use asked, the noise does seem to be synchronized with the tire rotation on a "1 noise per wheel revolution".
This sound is driving me crazy. I was supposed to go on a trip tomorrow morning, and I am going to have to put the car on a car dolly and carry it behind me in the moving truck.
I wish I knew what was happening.
I will take the car back to the authorized dealer in the new city I am moving to. I will keep you guys posted.
