Visitor Agreement.
$24.95 per year for the first vehicle.
The information provided in Alldata's system is taken directly from the manufacturer.
Has it ever had a tune up?
Has the fuel filter ever been changed?
Which engine? 2.0, 2.4 or 2.5L?
But most likely, the problem is in the idle air controller (IAC). This is mounted on the side of the throttle body and looks like a little tube.
But, if the check engine light is on, then there may be another problem causing it.
Best thing is to have the vehicle scanned and let us know if there are any active codes and any history codes.
Transmission Type: Auto
Mileage: 125k
Problem: It won't start - no fuel delivery
If I turn the ignition key to "ON" (without starting the vehicle), should the fuel pump of my 92 Suburban activate? Should I be able to hear the pump at this point?
Check all fuses and then check fuel pressure.
Type & Size of Engine: 4 cylinder 2.4 liter
Transmission Type: Auto CVT
Mileage: 400
Problem: I'm getting around 14 to 15 mpg's which is not the 23 to 26 mpg's advertised on the window sticker
Other Info: Dealer serviceman claims that it's common complaint with other cars as well because they're mixing more ethanol in the gas. Says there's nothing they can do.
What do you mean by 'what to run'? Are you wanting to know what motor you could place in this car which would fit and also give you more power/hp?
My opinion - for a 1982 Cadillac, which is basically worth zero, I sure would not spend the money to install a motor and transmission, even a used one from a salvage pull. If you do this, you car is still worth about zero. If you are going to get into doing this, the cost of a motor, tranny, and installation would be several thousand dollars, I would think. Especially if you change to a different motor and have to make modification to make it fit.
A few thousand dollars opens up all kinds of cars to purchase, much newer, lower milage, and would have more power than an old, heavy Cadillac.
- the seals were incorrect (but you say they were tight),
- the main crank is bent or have wrong bearings around it.....thereby when the crank is spinning it is wobbling too much for the seals to be able to hold the oil in.
Most likely the seals are sealed.
I'm not certain of it, but I think Bear may be part of OTC now too.
Walt5
THE TEMPERATURE GAUGE IS IN DEGREES. What is the average temperature it should be running at before it overheats???
So, the average temp should be 180-190 degrees.
Some newer vehicles are running 200-210 degrees.
If it is fuel injection with electric fans, then it is possible that the thermostat is a 190 degree thermostat.
If you are running above 200 degrees, then you are pushing your luck. You would need to determine that the fans are coming on and that the thermostat is opening.
Also ever since I have had it seems once in a while can't start at first try but if I turn key off and on again but only one notch and wait until the beep beep stops it usually always starts. It has always started even if it took 2- 3 times. Anyone know if there is a quick fix or maybe some sort of recall on this problem?
Thanks much!
Hydro=locking occurs when the engine's air intake sucks up a large amount of water...this is forced into the cylinders....the piston comes up, but cannot compress water nor eliminate it through the exhaust valves fast enough.
And this bends your connecting rods in an instant.
So a compression test/engine test is in order before you try any other solutions.
Was the water up higher than the bottom door sills? Did you 'splash' thru it where water would have sprayed up from the wheels........or did you drive very slowly and gently thru it?
As suggested, this could be a very serious major engine problem. Might also be a medium sized electrical problem.
Ranger manuals
It's as viewed by the owner-operator. What I view as highly driveable, is certainly different than what you may view.
As an example, some require manual transmissions to match engine power to speed and road conditions, others require auto transmissions as they don't want to be bothered, and some people are indifferent which kind of transmission.
There is no 'right' or 'single' answer to your question.
If it is the 4 cylinder (you didn't say whether 4 cyl or 6 cyl, which would have helped) and my memory serves me correctly, the 2 idlers should be about $15-$18 each.
The bolt in the center comes out and the pulley comes off the bracket.
This should be the part number
Idler Pulley part number 4792112
Any Ideas?
And thank you by the way for responding to me.
The confused technician.
Mostly engine operating problems.
Misses, crossfires, fuel problems and things like that.
Over time, it has grown to include emissions, check engine light problems, transmission and exhaust (cat problems) that affect the "comfort" of the driver.
It is so loosely used that I don't think you will find any real definition to the term.
When most shops ask about driveability any more, most are asking if you do diagnostics. Then again, I could be wrong, not knowing the shops.
