- also, where i said T bar, I meant the old fashioned push/pull of an X cross bar. They're the best unless one of your arms is a 22 incher and the other is only a 10.
I may have misunderstood your post and now can't see it to refer to as I type.
But it seems like you have used the torque wrench to 'loosen' the nuts. This is a very bad practice as it will throw (especially a click type) t wrench right outta calibration on first nut.
If the aluminum are rated as you said, I would use the same for steel wheels, assuming we are talking about an average sedan of 3500lb or so?
Then there is the potential debate of whether the rating is on dry or lubed threads. Usually these ratings are stated with a dry thread intention. I have been lubing my threads (but try to not get any nevrseize on the actual taper flange that seats the wheel) for 40 years with nary as issue or warped rotor. Others have warped them when it was out of my control, and hence why i never let anyone touch them. Generally speaking, lubed threads use a lighter ftlb torque. I use a T bar and i can feel the consistency between the staggers as I torque them up by hand. If mine are tested they are all virtually what I torque them to as 75ftlb. Never had an issue. I do check them twice over the winter and summer season and they seem to always hold consistent. YMMV since i do not know your skill using a T bar. One thing is probably for sure now tho...I'll bet you can use a T bar carefully acknowledging the force between them and be a lot closer than your present (unfortunately abused by accident) T wrench will do. Just don't have the wife or kids come out and talk to youy as you are manually torquing. If your wrench was a really good one, maybe consider investing to have it re-calibrated and never lend it out after. I also leave mine unweighted and always in the house or where ever it is most dry and the temperature is most consistent throughout the year. Definitely don't leave it in 120+¼ sunlight while you go in for lunch and a little squeeze with the honey before heading back out.
I did not use the torque wrench to loose summer wheels. I used a breaker bar
I did not lube the threads..
the torque wrench is a click type, a relatively cheap one I got from canadian tires. I read a few articles about torque wrench online beforehand, and I'd think I am using it correctly. it just felt so easy to hear the "click".
hehe
to add some detail:
when i was taking off the summer set, I was on my knees, had to put my shoulder weight into it to get it loose. then with the torque wrench, I just relax, the ~18 in long t wrench did all the job.
Can someone recommend any in particular?
I want to scan really really deep and do a lot of DIY
In general, most cast wheels (aluminum or chrome) call for 100 ft-pounds.
If your wheel is a basic steel wheel, I think it would be less, and 85 ft-lbs sounds about right.
I bought a basic code reader from somewhere (Amazon, Sears, ????) for about $40.
I think you need to do some research on what code structure your RAV4 needs. There are different codes for different autos. What you are asking is not a simple question.
"You depress the clutch pedal and hear a loud grinding, rattling, whirling noise. You ease off the clutch pedal, and the noise starts to dissipate."
The main difference is my car makes the grinding, whirring noise (more or less; and sometimes more, sometimes less) when the clutch is released and the car is moving rather than when it's depressed.
Of course 198,640 miles is a lot of miles, but I thought that manual transmissions usually last considerably longer if they're driven with care. Is mine the exception?
I replaced the original clutch at about 160,000 miles. The engine runs as though its got a lot of life left, and burns virtually no oil.
Although I'm going to dispose of this car, I'd welcome the comments of those who've had experience with manual transmissions that have failed because this puzzles me. I know that most automatics don't make it to 200,000 miles, but I expected a manual to live longer.
BTW, for clarification, a bad throwout bearing has NOTHING to do with the condition of the transmission!!! A failed clutch throwout bearing is an entirely separate part than the transmission, so don't make the mistake thinking your tranny is bad just because the bearing that allows you to engage/disengage the clutch is bad. Even if you're not mechanically inclined, think about getting a Z repair manual, tearing into it and see how far you can get before you have to call for help or sell it as scrap. You will need to remove the transmission to remove the throwout, but with patience, caution, following th manual, and a little help from your friends, its doable. Don't scrap that Z- fix it!
With the clutch pedal released, the throw out bearing isn't even moving.
198K is very respectable mileage for a manual transmission, and I'm sure many failures occur even before that mileage. The transmission owes you nothing.
You may only need a "small parts rebuild" in the transmission, not a total one.
Among the reasons I'm most likely going to dispose of this car is that, in addition to the transmission related problem, the steering rack leaks (its the original), the windshield has a crack, and it needs a complete brake job. I'd prefer to sell it as a project car, since the engine is sound, the body is straight and has no visible rust, the leather interior is basically good and clean (though, naturally, somewhat worn), the A/C blows cold, and it has new tires. However, if no one expresses interest for a modest price I'll donate it a take a tax deduction.
OF COURSE... :sick: ...there's the "while we're in there" factor, meaning clutch and pressure plate, blah blah.
Given his description, and the value of the car, the decision to repair or sell is...marginal....
If you repaired the trans, put in a clutch, fixed the windshield, you'd be into it well over $2000, closer to $2500, and you can buy these babies clean and running for not a whole lot more than that.
on the other hand (hence the marginality) the car you have is a known entity, whilst the used one you buy is not.
Were it a turbo car, the decision might be easier.
As a project car, you'd be lucky to get $1250.
With all the problems, near 200k miles, and the least desirable model (2+2), I'd say more like a $500 parts car.
Okay add $900 + another 3 hours labor.
Of course, he doesn't need to restore the car, just get it operating satisfactorily. He can add p/s fluid now and then.
Figure it this way--to find any kind of decent used car these days that doesn't need a boatload or work or doesn't have annoying deficiences that you have to live with, you need to spend at the very least $5K-$6K
The steering rack leak isn't too bad yet. I've been using Lucas PS fluid to reduce the frequency for adding fluid, but it's only a matter of time before it'll need a new rack.
I was hoping to nurse this puppy to 200,000, just because it's a nice round number, and because I've never gotten a car past 188,000. I've given up on that idea, though. And to think that, not too long ago, I thought this car was good for 300,000 miles. I think the engine could make it, but not the rest of the car.
Driving a car beyond its 'statistical life" (which on modern cars, is about 175K to 225K) seems pointless unless you just stop at that point and start a full restoration.
After 225K, cars can become downright dangerous---engineers don't plan for bizarre "ultra-mileage mishaps" like metal fatigue.
In addition to mileage, age takes its toll on some parts and components, and my 300 ZX is 25 years old. I think age doesn't affect mechanical parts much, if at all, though, or am I wrong on this? Does age per se take a toll on engines, transmissions, and steering components if fluids are changed at proper intervals? Body parts, paint, and rubber and plastic parts degrade with age, or course. This occurs at a significantly reduced rate if the car is garaged, washed and waxed regularly, etc., but some age-related deterioration still occurs.
But seals in engines and transmissions deteriorate from age.
And metal can just fatigue---control arms can crack, etc.
1992 trooper transmission wiring/harness diagram
On the off chance that any of you were wondering (or losing sleep) about the outcome of my 300ZX, I sold it for $495 from Craigslist. Someone who has a '87 2+2 will use the parts from that car to replace the parts on my '88 that wouldn't pass inspection. The good things on my car were the engine, straight body without rust, clean and well kept leather interior, four new tires (two had not yet been mounted), cold A/C and T-top that doesn't leak.
I was glad to sell it to someone who will drive it.
Thanks again for your valuable input.
Thinking it was a problem with the fixture, I pulled the part out of my identical parts car (fixture and about 6 feet of cord which then plugs in). Same thing with that wire/fixture combo. Tried 3 different bulbs in both fixtures.
I've got + voltage where the wire plugs in to the left rear part of the trunk, as well as + voltage inside the where you stick the bulb in as listed above.
What am I missing here? What makes the light turn on when trunk open/off when its shut?
Do you have a good return (ground) connection on the shell of of socket where the bulb plugs in to?
Is there a mercury switch in the fixture?
If you have a helper, try to keep leads in place and move trunk lid and/or wiggle the bulb socket holder to see if there is any bad connection or break in a wire causing it to maybe work intermittently in a different position.
I had one of these cars years ago, but don't recall the type of switch used. If the switch/bulb holder you mentioned has a spring loaded button somewhere, then that is your switch and there won't be an extra mercury switch anywhere. Does it look like it is undamaged and in an OEM position? Was car ever in a fender bender? Very hard to help trouble shoot over the internet without not knowing what processes you are doing and which leads are going where. The more specific you can be the better. It seems you have power there, but in the wrong place, (nonetheless the bulb itself should work with polarities reversed) It doesn't make sense if you have tried a new, different, or known working bulb.
edit - also, if you have power, then lower the trunk until you have NO power. If the power goes off before you have actually closed the trunk, BUT, also before any part of the trunk lip is touching anywhere where there could be a button switch, then it DOES use a mercury switch somewhere...probably mounted to the side of one of the swing hinges, but not necessarily. It WILL be mounted to the trunk lid somewhere accessible..if not on a hinge, then probably inside the double wall near the rear latch assembly.
BTW I get my Oil Sig. Oil Change done every 3 K-4-K miles now at Jiffy Lube since as long as you go in prior to sticker mileage for next oil change they have to give you a free 'Top-Off' Service so after every 1.5K.5K - 2.5K Miles I go in and they add 3-4 quarts of oil to an almost bone dry engine , all the oil has burned off by than or disappeared??
Believe the Toyota diagnostic & pay the piper. There isn't anything in a bottle on the shelf you can pour into the engine to heal it. It needs what it needs.
