Visitor Agreement.
I replaced all the 3 belts (A/C, PS and water pump) with original belts made by Goodyear. I also did a PS fluid flush.
So far so good. I have not heard the loud squeaky noise since the repair. The steering feels lighter and I have not experienced any loss of PS.
I am thinking about doing a second PS fluid flush in 4 weeks. This should get rid of any remaining dirt/contamination in the system. Thanks for your advice.
As to why the mfr and the dealerships don't recommend changing the brake fluid, I guess maybe that's just one of life's mysteries.
-ss4
I think brake fluid changes, like other routine maintenance, was taken off the schedule so they could claim the cars cost less to maintain. Of course, the manual usually calls for inspections, so the dealer can still recommend replacement to get the service $$.
I believe in preventive maintenance. Maybe I don't have to change the oil at 3K or coolant at 30K, but I can't see where it will hurt, and might save money in the long run (especially tranny fluid changes). Plus, it makes me feel good!
It's a 1997 LX Accord with 118,000 hard miles. There is a lot of sludge built up inside the engine. Just bought it--didn't know it.
And, have you changed the oil and filter? If you change the oil and it is topped off and the light still comes on, it could be the oil pressure triggering it.
- A really stiff gas pedal that often needs a SHOVE to get it to move from rest. Once it gets moving, the rest of the pedal motion is fine, but the need to shove it is annoying and makes me burn out at red lights. Most people think I need a throttle body cleaning, but this stiff motion applies when the car's off, so does that still apply?
- 16 MPG!!! What's up with this? I should be getting about 24 overall. Over at SE-R.net (for Nissan Sentra/200SX SE-R owners, who have different engines) they say bad gas mileage is usually due to either a bad throttle body or a bad oxygen sensor. Could it be anything else? How do I check its health, and is it expensive to replace?
Thanks for any help.
No harm in an oil and filter change but if indeed the engine is really sludged up, you got problems. I don't know how hard it is on that car to drop the pan and clean the oil pump pickup screen, but that's one thing you might do before tearing into the oil pump itself.
But it would be good to know what the actual oil pressure is, when hot and when at reasonable RPMs. Oil pressure at idle is somewhat irrelevant.
good luck and let us know how you're doing.
Shifty
I then was able to start the engine again so we could pull off the road. When we drove if off the road, a woman who was driving behind us stopped and let us know that there was some fire or glow coming out of the exhaust when we accelerated.
Finally, today, I took the car to a Subaru dealer (we had it towed there) and they couldn't find anything wrong with it! They drove it around, putting a much as 20 miles on it, and nothing out of the ordinary happened. They also said there was no indication on the computer that the Check engine light had come on.
Does anyone has any ideas or suggestions as to what could have been happening with the car when thes problems occured? Thanks.
no codes are currently displaying.
after replacing computer, in tank fuel pump, cleaning injectors, checking fuel line pressure, it now starts fine, then dies.
normally we can figure this stuff out, but could the computer be doing this by switching from a start to run program? others have suggested an anti theft device is shutting it down, but we do not find one.
i myself did not see the injectors spray, but surely 4 would not fail at once?
help appreciated.
tom
also seem like they have gone out. I have to push the breaks very hard to get the van to stop.
Any ideas on what is wrong?
PROBLEM: when driving at any speed the vehicle has engine surge and or jerking. At times the jeking can be pretty bad, surprized that nothing has broke because of it.when i take my foot off the gas its fine I apply gas and it might start back and continue for awhile or might be fine for awhile. i have spent quite a sum but no fix as of yet. I have replaced all 3 coil covers and the overspeed sensor.
ANY IDEAS OR THOUGHTS
thnx
Now, to save money, can your local mechanic guy get the part cheaper?
12/04 88k
fr. pads, new rotors, new br. hoses
6/04 82k
fr. pads, turn rotors, new calipers
1/04 77k
8/03 71k
fr. pads, rr. shoes
6/02 55k
So basically, over the past 17k miles I have had pads replaced 3 times, rotors twice,and calipers and hoses.I have been going to different mechanics to see if anyone can figure out what is wrong. They guess something is causing the pads to constantly be engaged but they cannot figure out what it is really. I certaintly don't keep my foot on the brake all the time. Any ideas are appreciated as the expense is too great to keep this up.
Is there any way this has to do with the master cylinder? That's not considered a wear part and would be covered under my extended warranty.
Basically what happens is the car stops acceleration and drops to idle, sometimes bucking and surging during the process. Bucking and surging is quite pronounced under heavy to WOT applications, and gentle under light load. Lifting off gas usually corrects the situation...until the next go round. Car is going to an independant shop that I trust. Dealership took 5 tries to fix, and now that it's my dime, no thankyou.
Anyclues...or suggestions? Anybody have this experience or heard of it? Might that traction control idea be valid? Anything you all say, is better than nothing, thanks so much.
Anyway - try turning the steering wheel a small amount. It will probably not turn any in one direction, but can be turned a few degrees in the other direction. This will 'unload' the pressure the steering is putting on the switch, and allow it to be turned.
If this doesn't help, there is something else wrong in the ignition....
You don't want to mess with gas fumes. Take it from me, it takes 30 seconds for a car to burn to a crisp and you don't wanna be in it.
Have the dealer check for gas line/injector leak and also check the piping to the evaporative cannister (a far less dangerous condition)
It belongs to a friend whom once had a second hand car sales lot, and this vehicle was a re-possession. Therefore no keys are available, I don't want to go out and replace all the locks as that would be very costly.
Due to this vehicle standing for such a long time, does it mean that I'll have to remove the head an all ? The engine has 112000k on it, and I'm not sure what size the engine is, all I know is it's a straight inline 4 cylinder, front wheel drive.
I'd hesitate to recommend removing the injectors to squirt oil in there since after all diesel fuel itself is rather oily; however, I doubt the car would start even with fresh fuel because there will probably be air in the injector lines.
Also god knows what crude you have growing in the diesel fuel tank.
So you've got a bit of a mess on your hands. Are you sure this car is even worth starting up?
If so, it'll go something like this, bare minimum.
Drain fuel tank, put in fresh fuel and fuel additive.
change ALL the fuel filters
change the engine oil and add a light oil.
Install new heavy duty battery
Hook up the remote starter.
Crank the engine over...it probably won't start but give it some 15 second bursts---not longer.
After a few 15 second bursts, stop. Loosen first injector at engine (don't take the line off, just loosen it) and crank the engine until you see diesel fluid leaking out of that one loosened injector nut. Do this for the other 3 until fuel is definitely getting all the way to the engine.
Then tighten everything up and it should fire.
Have a fire extinguisher at hand, dispose of all rotten fuel and old oil properly.
Now you have to worry about if the tires are rotted or flat-spotted, and you have to check for bad hoses and belts.
After a few hundred miles, change the engine oil and the fuel filters again.
http://www.gates.com/downloads/download_common.cfm?file=GatesTBR.- pdf&folder=brochure
