any ideas?
Have 89 4R with V-6, 5spd. Great body/interior. Compression is 165psi and hot idle oil pressure is 30psi.
THIS IS MY SORRY TALE:
NO CHECK ENGINE OR CODES FROM ECU.
Started to bog at low rpm. Replaced fuel pump; cold start injector, diaphram checked ok. Replaced ALL SIX fuel injectors (They were cracked and leaking), plugs, plug wires, dist cap, rotor.
Is now burning rich; runs good when cold, then black smoke out tailpipe when it warms up and cylinders 5&6 periodically misfire. Plugs in 1-4 cyliners are black, but not oily.
Have put $3,500 into it. Mechanic is going to check sensors and ecu with ohm meter. He seems in over his head. TELL ME WHAT TO DO before I have to declare bankruptcy!
There may be a temperature sensor that is bad. Not the sensor that drives the gauge on the dash, another sensor that reports to the 'computer' if the car is 'cold' or 'hot'. It is saying the car is 'cold' all the time, so the computer runs the injectors, timing, etc in a 'rich' condition. Since you say it runs ok cold, then badly when hot, maybe something like this is what is wrong....
How are these built? The service manual for the 1998 LeSabre doesn't address the internals of the mirror.
If you have a friendly body shop around they might know more and tell you, or you can always go to the dealer's parts department and see if they have a blow-up of the internals.
My impression is that this is a "replace only" item with no repair procedures.
I apologize if this is a double post. I tried to post earlier today, but couldn't find my message when I got home.
We have a 1993 Isuzu Trooper with 238k miles on it. There is a strange noise/vibration that only occurs on the interstate/highway and not around town.
Speed doesn't seem to be much of a factor, though it seems to happen at 50+ mph. The noise/vibration sounds almost like the vehicle is shuddering. It feels off-center towards the driver's side.
The odd thing is, you can take your foot off of the gas for just a second and the noise stops, then you can push down on the gas, the noise will stay gone for a few seconds/minutes and then return.
I've had a couple of different mechanics keep it and drive it and they can't pin the noise down. Any ideas (besides a different mechanic :-P )
Thanks in advance.
P0170- SYSTEM LEAN BANK 1
P0300- RANDON MULTIPLE MISFIRES
MY MAZDA 2000 PROTEGE HAS THIS PROBLEM AND I TOOK IT TO THE MECANIC AND THEY SAID THAT THEY DONT KNOW WHAT IS CAUSING THE PROBLEM. I TOOK IT FOR TUNE UP AND THEY CHANGED THE PLUGS AND EVERYTHING. DO YOU THINK THAT I NEED TO CHANGE THE GAS FILTER OR THE AIR FILTER, AS WHEN I DRIVE THE CAR IT FEELS THAT THE CAR IS NOT ACCELERATING. WHEN I AM ON THE INTERSTATE I WILL HAVE TO ACCELERATE TO FULL AND IT WONT GO MORE THAN 70 MILES. CAN YOU HELP AS WHAT IS CAUSING THE PROBLEM AND WHAT NEEDS TO BE DONE OR CHANGED. IF YOU CAN HELP ME I WILL APPRECIATE IT. THANKS...
AND TAKE YOUR CAPS LOCK KEY OFF.
I'm very surpised that the shop that did the tune up didn't recommend changing the fuel filter.
That may not completely cure the problem, but I guarantee it's a stumbling block. You didn't indicate if any of the diagnostic trouble codes were still present after the tune up.
And please lose the caps...
Don't know if this is the appropriate place to ask this or not, but here goes-
There is a section here on the Edmunds site that lists TSBs and Recalls by vehicle. I saw a TSB # that I would like to find out more about. Where is a good place (can it be done on this site?) to enter the TSB #, and get a complete explanation for the TSB? I would like to know what exactly the TSB suggests as being a fix in this particular case.
A/F Sensor Circuit Range/Performance (Bank 1 Sensor 1)
A/F Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
Has anyone encountered this or have recommendations on what to change?
I'm told in another forum that it's the A/F sensor on the firewall side, and that it's challenging for a DIY'r to replace. Could it be anything else?
Someone suggested cleaning the the MAP sensor by the air filter. The cars actually running a bit smoother, but the error code persists.
You can explore more at www.alldata.com, and of course you should google the government sites like NHTSA.
You can also try our "search" feature and use the "advanced" version of search, which allows you to search actual message text in each and every post ever posted at Edmunds! It is possible that entering the # of your TSB might reveal it in 'advanced search' mode. Be sure you click on "message text" search in advanced search mode.
shifty the host
engine started frunning rough. Shop then said the new fuel pump with the correct pressure was overpowering the injectors because the injectors were leaking, cracked, etc. Put six new injector, plugs, wires, cap.
3.0L V-6 runs rich on all cylinders now. Five and especially six will foul out and then catch, but overall engine has one dead cylinder all the time and pours out black smoke through tail pipe.
tried different ECU and no change. Still no 'check engine' light. Been told by other mechanics in town that this is not uncommon for the pre'96 era Toys.
Shop at their expense is tacking it to a Toyota Dealer to diagnose. I am not impressed.
Let son take it to this shop as I did not have to work on his truck myself. Big mistake. will likely see these clowns in court. Meantime...
NEED TO GET THE THING RUNNING!
Any info, experience, SWAG would be appreciated.
As a fallback I can unscrew the whole unit from the bottom of the radiator, but that seems a bit extreme.
Bill Cobb
I do think though that's it's nice of the shop to take it to the dealer for you. Maybe it'll work out for you?
1. What damage can I expect to find?
2. Is a crate/rebuild the best option?
3. Can you swap the 3.4 or other engine?
4. What is the "hot tip" in this situation?
Get an estimate on a tear down and be prepared to go with a rebuild or a used engine BEFORE they tear it down. You don't want to be in the situation of having your engine in pieces without having planned for all the scenarios you are likely to see.
That has been my plan. Best Buddy (Army) has a shop in Detroit. I plan on taking there to evaluate.
I agree, sentimentality aside, a replacement 4Runner with mine for on-sight parts depot would make more sense.
Thanks again,
AWGuthrie
When I turn, especially now that it's really cold, there's a horrible groaning/low-pitched whine noise. I suspected power steering fluid loss, and went to re-fill the PS fluid - nope, chock full. It's 12 degrees, so I didn't stay out to nose around much more, but it seems like there could be a blockage or kink in a hose, OR, my power steering pump is shot. Am I likely on the right track?
kirstie_h
MODERATOR /ADMINISTRATOR
Review your vehicle
First, you may have a problem with the lockup torque converter clutch. It sounds as though you are getting the vibration when the clutch locks/attemps to lock.
Second, you may have a collapsed motor mount. This would permit the engine to torque around farther than it was designed, permitting hard parts to rub/vibrate. You can check this by opening the hood and watching the engine as you shift between park and reverse with the brakes on. If a mount is bad, the engine will flop all over the engine compartment.
Tom
Review your vehicle
2. Well, yesterday I opened the PS fluid reservoir yesterday and added a smidge of fluid. It was pretty full, but I added like 2 tablespoons, then put the cap back on. No noise since. What the heck???
I'm still going to take it in given that it's 2000 miles from warranty expiration, and if there's a problem, I don't want to find out 2001 miles from now. Thanks for the advice on the PS hydraulic rack - I'll ask that it be checked!
Review your vehicle
Sometimes, just talking things out on this board helps one think logically!
Review your vehicle
What is the difference in European (import) brake rotors/disks and american brake rotors/disks? (I.E. Honda/VW)
quick fix: replace the thermostat, top off the coolant as per factory instructions for eliminating air blocks.
Has the fuel pump actually been replaced, and did they check the lines? My first instinct would be to head for a 2nd opinion on the fuel issues.
kirstie_h
Roving Host
Host, Future Vehicles & Smart Shopper discussions
Review your vehicle
i'd probably start by examining the fuse (or fuses) associated with those two functions. if one fuse handled both the clock and the locks, that would be a sign that a particular power circuit may be having an issue (a short somewhere?) resulting in a blown fuse perhaps.
many manufacturers supply spare fuses in the fuse block areas, and potentially, a fuse pull / insertion tool for fuse removal.
fuses can be inspected visually to some degree, or by using a continuity tester / ohm-meter to determine if an electrical path for current to flow remains intact.
at the very least, you can make sure the fuse is firmly inserted (has not vibrated loose), or alternatively, replace the fuse with a spare fuse (presumed to be good) of the same current rating (very important). a 7.5Amp fuse should be replaced with a 7.5Amp fuse. A 10Amp fuse with another 10Amp fuse. etc.
if re-seating or replacing a blown fuse "solves" the problem, then great!
if the problem re-surfaces after replacing a fuse(perhaps the fuse blows again) - don't keep replacing fuses for that circuit...
get it checked out! fuses are in an electrical ckt to "blow" (open up and inhibit flow of electrical current), when something in the circuit draws more current than it should... in this way it protects the ckt from, for example, electrical heating which could happen with a short, resulting in wiring damage, even leading to a fire.
just speculating, i suppose it might be possible that something restricting the door lock solenoids from moving freely when they were commanded (maybe ice buildup)? might cause the associated electrical circuit to temporarily draw more current than they were designed to draw, causing the fuse to blow. i'm sure the mechanics could tell you if that is in the realm of possibility in your case.
hope it helps.
How difficult is it to repair the wiper motor assembly?
As well, currently on the Dodge Shadow the wiper spray tube runs along the wiper arm and the spray nozzel is attached to the wiper arm itself. Is it possible to remove this assembly and place some sort of spray nozzel onto the nub in the hood where the tube connects into so it sprays the windowshield - the tubes keep freezing up and losing pressure.
Jeff
