but i have experienced this noise after driving on forest service road for about 3 or 4 miles and now it is here to stay no matter where i drive!
let me know if you get any info.
I HAVE 46000 MILES ON MY TITAN AND I AM A MAINTENANCE NUT FREAK. I HAVE HAD NOTHING BUT PROBLEMS WITH THE TRUCK AND NOTHING BUT DENIALS FROM SMITHTOWN NISSAN. I HAVE HAD TO FIGHT FOR EVERY WARRANTEE. IN 12 TIMES FOR BRAKES. WAITING ON PARTS. NO SERVICE LOANERS, CANT DUPLICATE COMPUTER ERRORS, INTERMITANT PROBLEMS, STRANDED ME FOUR TIMES. I HATE THIS TRUCK AND I HATE NISSAN. I HAVE HAD VEHICLES THAT HAVE SOME PROBLEMS BEFORE THEY WERE USUALLY STRAIGHTENED OUT AND GONE BUY 10 TO 12K MILES. THIS PIECE OF JUNK JUST KEEPS GETTIN WORSE AND WORSE. IF I WERE A RICH MAN I WOULD DONATE IT TO THE FIRE DEPT TO LET THEM BURN IT FOR :lemon: :lemon: CAR FIRE PRACTICE. I WOULD LOVE TO WATCH IT BURN. :lemon: :lemon: :lemon:11111
Anyway, I am sorry to hear that you have had such rotten luck with your truck. Sounds like my terrible experience with a Volkswagen car years ago.
John
ABS is noisy, I don't think I've ever seen a vehicle that had quiet ABS when it activated while stepping on the brakes.
I purchased a 2006 Titan in it's place (with the tow pachage). I HAVE NEVER HAD A SINGLE PROBLEM with the 2004 and love the 2006. I hate to read all those horror stories without at least commenting on the great luck I have had so far. I really love the Titan and plan to keep one in the driveway and reccomend it. Good luck to the rest of you.
As for the ashtray - I was also surprised to find that it did not come with one - I asked the dealer to get me one and when it arrived it consisted of a little cup-sized unit that goes into one of the front cup holders beside the gear shifter and the push/pop style lighter that goes into the driver side power port. It seems less glamorous than the rest of the truck indeed !
I have had it for just over a year and have 20,000 Kms on it now.
I have had a couple of problems - the stereo cut out after about 45 mins at almost full volume (I like my tunes when crusing down the highway) the dealer replaced it and all is good now.
I am having the usual poblem with the brakes Nissan is replacing them with bigger better rotors / pads at no charge.
I am also having a problem with the cruise control - when I turn it on the power on light in the dash lights up but the set light also continues to flash off and on and the cruise control will not activate. If I turn off the ignition and re-start is seems to be fine.
This has only happened 2 times in over a year and the dealer has promised to fix it whatever is causing it.
I bought the truck from Eastern Nissan in Manitoba and I can't say enough good things about them - they are great - they even came and picked up the truck, left me a loaner to drive and when they were done came and droped off the truck and took the loaner back - it just does not get any better than that!
Ed
Thanks, John
I have read your messages re: Titan brakes and replacement with larger rotors, etc. We here in BC have an '05 Titan and at around 25K km, find significant brake shuddering which worsens with higher speed braking. I have noted from other sources that the brake rotors may be too small for the vehicle and hence lead to more heat buildup and warping. How has your brake replacement gone? Improvements?
Peter
Maple Ridge, BC
I just happened to do a google search for Titan and this came up. WOW....those are crazy problems. I'm looking at a Titan Crew cab 06'. Have they gotten the ticking, brake problems and everything fixed in the 06' or should I look at something else?
Any help would be great.
Jon
Cheers,
Peter
I think it's a stick valve in the transmission control module. IF contamination or dirt from the clutch or elswhere gets caught in one of teh valves it can cause this.
Any ideas on when Nissan is goin to fix this????
That same day I drove 30 minutes outside of my town to another dealership. Same problem...not one truck I wanted. They offered me one that was close but I wasn't happy with the color. I told them they would have to make me a killer deal for me to drive off the lot with that truck. He assured me he would come back with a great offer. He said they would call me Monday......No call.
Jezzz...what's a guy gotta do to buy a truck?????
Not sure in your case but I went to a Dodge dealer.....problem solved
Go to the Nissan website and select the “Build Your Nissan” option under Buying (http://www.config.nissanusa.com/redirect.jsp?tryset=true&flow=trimselect&make=n- issan&lang=en). This allows you to enter the model, color, and options to search dealer inventory for the car you want. The results do not give you the exact dealership; however it provides the inventory sorted by matching results.
NOTE: When the dealer list comes back, scroll to the bottom and extend the mileage radius of the dealers to search. This is the first field on the bottom half of the page. The model I want is about 70 miles away. This beats having to drive around town.
Let us know how this works out for you.
As for the plastic faceplate on the dashboard, i'm also having the rattling issue with my 06 Titan SE CrewCab 4x2.
Does anyone notice that the back end of their truck (i guess the bed)is making these squeaking/rattling noises?
No my truck isn't perfect but I still love my Titan.
Kwikirk
Oh and the dealership is terrible!!!!!!!!!!!!!!! :lemon: :lemon: :lemon: :lemon: :lemon:
That's the sensor in the seat, some people have had issues with it. Not a huge deal since you appear to still be under the B2B warranty.
My 04 LE hasn't had the issue with the airbag sensor, but it has had other issues. However, I also have 55,200 miles on it.
Chris
P.S. I still love my Titan!
