Visitor Agreement.
I a 99 set up just like the truck you have ordered.
Around town, I get 10.5-11.0 consistently.
On the highway going 75mph I get 11-12.5 unloaded
Pulling a four horse goose loaded I get 8-9, I don't usually get it going more than 65 then.
With the 2000-2001 you should expect to get at least what I am getting. If you have a really heavy foot and drag race away from every stop light you might get closer to the 5 to 6 mpg but I doubt it.
The half dozen folks that I know who own V-10sd are all in the general range of what I reported.
You will hear folks talk about getting 15mpg with the same set up, I highly doubt it.
Some will say as your friend the truck is terrible and it only gets 5 to 6mpg, I doubt them also.
The 460 got better milage than that with a carb sitting on it.
I hope this helped, don't panic you will get what the rest of us do 10-12.5 avg.
Have fun
Cowpokes
11.5-12 - hwy
9.5-10 - 50/50 mix of city/hwy
The winter commute mpg with 50/50 city/hwy and lots of 4wd is about 1mpg less. My last tank was 9 mpg. If we go through a real cold snap and I am idling the truck for 10 minutes in the morning to defrost, it can cost me .5-1 mpg more, but I've never got less than 8mpg even under those conditions.
With my slide-in camper in the bed (just under 12,000 pounds for truck and camper combined), I get 8.5-9 hwy and can get close to 10mpg on flat hwy at 55.
They are precision machined and fit up into the top of the window channels. A guy I work with has them on his Y2K F-250 Crew Cab and they look really good.
I ordered a 250 CC Lariat 4X4 SB V-10 3.73 a few weeks ago - I decided to get the plain-jane 235-85 BSW Tires - Have I made a mistake? I went with them because I wanted the taller tire, (235 x .85 > 265 x .75 ), and I don't believe in paying about $100 for white letters! Are these tires too narrow? I'm actually considering swapping them after I get the truck - There's a tire store here that will give credit for the factory tires, probably not much, though.
Anyone actually driven with both and compared? Do you sacrifice ride when you go narrower? Do you loose mileage with the taller ones?
Here's a question for discussion. I am diligent about turning off my overdrive when I am hauling, of course, but I am hauling 99.9% of the time on hilly country roads. I heard once that you don't necessarily have to turn it off when you are hauling on the interstate. What are all of your thoughts on that?
As ggt1 said, the outside diameter is basically the same..
With both tires being the 'same' height, the narrower will in theory give better mpg, (less rolling and wind resistance). Probably not enough to be measurable in the SD..
I agree that the OWL are overpriced, however I felt the LT265x75 AS BSW were reasonably priced ($166) and they function and look great..
I agree, you pay alot for those white letters, although they are also All Terrain, vs All Season.
A popular gadget for folks who tow alot is a tranny tempature guage.. When the temp goes up, keep out of OD. Heat is the enemy in a tranny.
I was filling up the other day, and there was a guy filling up a D**GE on the next island. Boy was he checking out my new toy :-)
Someone in an earlier post said "if you have to ask if you want a diesel, you don't want one".
Jim
Anyone know why they don't offer the heated seats in pickups? I was real close to losing the Lariat because it gets pretty cold here! Plus, after a hard day of snowmobiling, a little heat on the rear would be therapeutic! I guess I'll just have to carry a towel in the Winter!
lilelmo... congrats on becoming a "have". the wait is most certainly worth it.
maincowgirl... with the psd you'd not need to exit overdrive unless the grade was greater than interstate standards (with the 4.1 or 4.3 diff ratio). the v10 is not that far behind (unless you've got some altitude) so it would probably be a circumstance issue rather than a hard line choice. as bess mentioned, excessive heat is the indicator of too much load being applied.
rbroll69... we've got that basic config. note that the f350 actually sits a couple of inches lower than the f250 at the side rails. you can't easily lower the rails any further by doing "body work". our rig is a perfect match to the truck, but we do have high road clearance due to Airstream's usage of torsion bar axles (no leaf springs). one of the "tricks" (on a standard leaf spring axle) is to "flip the axle to the bottom of the leaf springs (this gives you the height of the springs (at the axle) as additional coach height. Airstream recommends that you ride no more than 4" high (off of level) at the king pin (but I've seen coaches riding a lot higher than this). I'd recommend that you make any modifications to the coach rather than the truck. if you need additional info, please post back & I'll provide some measurements... note though that I "check-in" only once or twice a week so please be patient.
all... well, waiting on our "kwik-slide" reese hitch adapter. found that even with a 16" extended pin box it still will not allow us to place the combo in "jack-knife" position (which should not be attempted when the trailer wheels are on dry pavement)... not enough clearance between fiver & rear corners of cab. this may not be necessary on an 8 foot standard width but it is a problem with the newer wide body (8'6") coaches.
Mileage is beginning to come up a little. 1400 miles on the truck and am averaging 14.5-14.8 mpg city only. Next week we're taking our first extended pull (to northern Orlando area) so anxious to see how mileage works. still don't have the rig weighed, though... will have to wait until return.
Mine was released last Thursday from KTP but BNSF still doesn't appear to have a record of it and I was wondering how long it took yours to get loaded on the railcar.
SOUNDS AWESOME!!!!! Nice growl to it....Does not sound as good as my flowmaster on 97 F150 4.6l though....but about 90% as good. The guy spent a lot of time tweaking it out....and he even came in at $75 less than the origional quote....that was a suprise to say the least...he could have charged me what he quoted and I would have been happy...Now I'm off to pick up my K&N filter and that should just about do it for add ons. I did like the truck on the front of the latest Performance Truck Access. catalog though....nice tires......anyone else see it....Maroon truck...
2K 250SD, SWB, 2WD, V10, Auto, 4.30LS, Camper, Tow, Hitch,CD, 265x75, Two Tone Island Blue w/ Harvest Gold accent. Ordered 12/10/99 Clean and Unscheduled.
I wanted the PSD for the gas milage as my current 97 Dodge 1500 Xcab,4X4,SB,5.2 with cap 71k miles is only getting around 12 mpg empty,mostly highway, it used to get in the mid teens. The dealer told me after looking at it several times that there wasn't anything that they could do for me, they ether get 11-12 mpg or 17-18 mpg like my brother's 98 with a 5.9.
What I'm wondering is, does anyone know where to go for a long term loan? Like around 84 months as the best that I've found is 72 months.
Any help would be appreciated and sorry for the long post as I've been following this for some time.
I was driving along today and had one of those times when a spontaneous grin just breaks out. I looked DOWN at the Ch**y next to me, adjusted the classical music pouring out of the four big ol' speakers up just a little bit more, and flat enjoyed the moment.
It was worth waiting for. No doubt.
Four Wheeler mag. Nov. 99 www.fourwheeler.com
good luck,Greg
I'm pretty sure it's BNSF all the way, KTP to KC to DEN (where the offloading railhead is). The Denver railhead actually has a Union Pacific sign but the sign is pretty old and BNSF's map shows KC and DEN.
I sure hope mine still isn't sitting at KTP
So take it from me the front tires will lock down and lay a lllloooonnggg black mark on dry pavement. Off to tire store.
2000 SD CC SB WHITE 265 AT TIRES V-10
About Chebys.....Friend down the street went in to test drive them....after the Dodge fire I abstained from the trip.....He said Cheby is coming out with an 8.something liter V8....and that their new diesels are improved and sporting Allyson (spelled right) transmissions. He was impressed with the Allyson transmission....is it supposed to be better??? Now an 8.something liter V8....GAS HOGG I would expect.........
With about 2500 miles, getting around 12-12.5 mpg on 50/50 city/highway miles .... 2k 250 CC short bed V-10 auto 3.73LS. I don't baby it but at the same time I don't have my foot in it all the time either. A couple tanks back I did have fun and checked out the performance characteristics of my baby .... mashed on the gas a bunch .... and got 9.7 mpg.
Something I've been concerned about .... when I mash her down from a dead stop .... is it normal to have a sort of a hesatation going from 1st gear to 2nd? It is smooth but doesn't lock up quickly like most automatics.
Hope ya'll are enjoying your trucks and those that don't have one yet ... hang in there baby ... it's worth it.
Gotta take Mama to the Super Walmart in Broken Arrow to have the Beehive hairdoo redone .... Happy motoring!
F250 4x4 SC LB PS 6 spd.man. - ordered 9/7/99.
Ordered '00 250 v10 CC 4X4 XLT sb manual trans. on 1/17, built week of 2/7. I'm flying to Denver (from SLC) tomorrow a.m. to pick it up.
psmith13: 13's not bad, and 10 is the best you can get from the dealer. Better than 10 takes approval from higher up FoMoCo muckety mucks.
jeffi: gossamer's got a good idea there. Why not rotate the tires and try to cook off the flat spots. What do you have to lose?
Cheers. Dave.
wassbe, took about 3 weeks from serialization to to getting build week and the build week was about 3 weeks out.
psmith13, NW21S Y doesn't look like a VIN to me. The www.ford-diesel.com site has a good description of VINs (in the FAQ area as I recall). Same place also discusses priorities. Comparing priorities among dealers is almost a waste of time since the priority used by the dealer to prioritize *their* priority. For one dealer, a priority 20 might put you at the top of the list while for a different dealer, you'd need a 10 to be at the top of the list. Allocations are just as important as priority.
As for tracking my truck via BNSF. Don't know who was fast on the draw but the truck was released from the plant on the 17th and by the 21st it was at the railhead in Denver (and I didn't start checking until the 22nd, I had *no* idea it would show up that fast!) Just checked and the dealer doesn't have it yet but Friday's trucks haven't come in yet. Dealer (in Castle Rock) is showing a 3/4 delivery but said they've been coming in earlier
As for my dealer's allocation, I actually did some looking around before I ordered. I went to a commercial dealer that was supposed to turn-over a high volume of trucks and have a good allocation. They have been telling me that the allocation applies to regions and not just dealers and the mid-Atlantic states are supposedly the hardest hit with the delays. Of course, I happen to live in Maryland.
The more I find out about this truck, the better it is. FoMoCo put their (my) money in all the right places.
crazyelvis/mainecowgirl:
My pore ol' laborador retriever 'bout wet himself the other day when I drove in for the first time. Now, he wants to ride, too. Maybe when he quits slobbering.
The term beast or baby? This truck is to baby as Godzilla is to those Budweiser iguanas. Maybe beast-baby. Could be a new song, "Beast-baby, beast-baby, here on the sand.." Naw,too much. :-)
For you waiting: It's worth it.
On the up side, it's due at the dealer on Monday. On the down side, the invoice is reflecting more than the price we'd agreed and the sls rep is trying to figure out where the difference is (we both suspect a price level difference but sounds like the invoice he has doesn't show the pricing level). I'll be glad when I have the keys in my hand.
If one dealership can nail it like that, why can't they all? If the secret FoMoCo person would answer me that on this site, I bet lots of people would be much appreciative. My point is I think that the dealers should be able to tell buyers if the wait will be 5 months before any deposit money changes hands. To BS with info like that is misleading and underhanded. If we can't go to Ford to get answers then the dealers should have ALL the answers.
Billingsley Ford, Lawton OK. F350/SD/SC/4X4/deep wedgewood over silver/$100 over. Alaska bound next week.
I feel for this guy....and I know if I had ordered one from Flammer I would still be waiting.
BTW....I test drove an XL V10 CC 1999 truck at Flammer before I did order mine last Aug. They had a 31,000 and change sticker on it and wouldn't move on the price. I got my 00 V10 CC Lariat for 26,400 plus destination and tax. The guy at Flammer did call me after I ordered to see if I wanted to come back and pound my head against the wall for his XL....I told him I ordered from Gator and told him the config. and price....he basically called me a liar.....so once I took posession...I drove the beast to his dealership and showed him my deal. What an *sshole......
Sorry for the long post.
Still getting the 14 mpg reading.....let me ask again...would the new exhaust plus the K&N really give me an increase from 12.5 to 14 mpg....Plus today was HORRIBLE in traffic....stop go stop go...so the 14 reading was in very heavy traffic.
P.S. Saw a great display of road rage today...an acutual fight in the middle of US 19...a six lane hwy.....what a bunch of fools!!!!!
Its all based on allotments. BUT, with many vehicles where production capacity is higher and demand is lower, dealers can often order or get the the vehicles quickly even if they are over their allotment..
If the vehicle falls within the dealers allotments, there is still not 'guaranteed' turnaround time, but its generally in the 8 to 12 week range for most vehicles.. A few months ago, the superduties were comming in in the 12-16 week range for dealers within allotments.. Of course there were some exceptions, I'm speaking generally . Today, it appears that the dealers within allotments are even in the 8 to 12 week range based on what some folks are getting.
So, when the truck is within allotments, dealers are generally telling folks 8 to 16 weeks..
For those vehicles ordered over the allotments, the dealers really have much less of an idea of when the truck is comming, until the truck is serialized and given a schedule.
The idea is that FoMoCo wants dealers to buy alot of trucks. Those dealers who buy more trucks, get more allotments. FoMoCo knows the totals of all of the allotments added up, so they can very accurately plan production to at least meet the allotments they have divied out..
Remember though, dealers don't like having too many truck sit on the lot for too long, because they (the dealerships) are usually paying interest on the trucks until they're sold.
Im sure my story above has some holes in it, but I think its fairly accurate..
Didn't find anything on a quick troll through Ford's web page ( www.ford.com ) but I didn't look too hard.
Talk to the GM. If it's been serialized, no reason that you shouldn't have the VIN. I've found you can't get financing or accurate insurance quotes without it. I suspect financing is to make sure you're really getting a car but the insurance needs it too. Tell 'em you want it for insurance quotes.
That's unfortunate that your sls rep is insecure with your knowledge. I sure haven't gotten that impression with mine. I think he likes not having to deal with the less-informed.
My sls rep missed on the quote, he told me 6-8 weeks and it looks like it will be 11 weeks to the day. However, I'm willing to cut him some slack since he'd been there about 2-3 weeks (don't think he'd sold cars before) and we were the first vehicle he'd sold.
On the flip side, our sls rep waived the dealer prep charge and when the truck came in with a higher invoice, he (well the dealership since I know he had to talk to someone else
Jason Bowden at Medved Ford in Castle Rock.
http://www.ford-diesel.com/contents/getitems.php3?Birth%20of%20Tyrannosaurus%20Red
Here's my guess of how those dealerships do it.
The default priority when they order trucks is 99, thus, its sortof like telling the factory, 'when you get a free moment, build this one'.
This might them from taking up an allotment slot. (I'm not sure when the truck gets counted against the dealers allotments, at delivery time, order time, etc.)
So, when someone comes in wanting to pay MSRP for an ordered truck, the dealership will give that dude/dudette a priority 10. And since they've not used up their miniscule allotment, it will arrive.
FoMoCo gives all of the trucks to dealers at invoice price (- 3%). FoMoCo makes the same amount of money no matter what the dealers do. So there's no incentive for FoMoCo to give higher priority to someone who's paying more vs someone paying invoice.. They let the dealers decide how they want to make their profits..
Oh about my truck..
Still averaging 15.5 mpg (last tank happened to be 16.1 in mixed traffic).
Goes to the dealership on 3/1/00 cause I want the engine 'spark knock or pinging on acceleration' looked at..
Y2K F250 XLT 4x2 SC 5.4L 5sp 4.10LS
