Visitor Agreement.
www.toscom.com/rally/psdrally.htm
and
www.ford-diesel.com/ubb/forum19/HTML/000527.html
00 F250 SD CC 4X4 SB 4.1 LS V8 ABS blah,blah,blah!
Averaging ~9.5-10.5 city, 15+ highway.
keep truckin'.
on a delivery date without the help of a middle
man (district sales rep.) It's the good ole boy
system. Also, the squeaky wheel gets the greese.
And where would one get and have installed a transmission temperature guage? Thanks for any help.
00 CC SD Lariat 4x4 5.4 4.10LS loaded to the gills
Woodland Green Z-Series(A.R.E. Cap) Grizzly wrap around grill/brush guard, 265s
I'll describe it as best I can.
In the automatic, the torque converter provides a clutch like function (slipping). In the old days, there would be some torque converter slipage, even on the open highway..
In the manual tranny, when the clutch is out, theres a solid link from engine->wheels.. This is one reason manual tranny's are usually more efficient.
Well, the torque converter lock (relatively new invention), basically locks up, providing a solid link from engine->wheels for efficiency.
Enough about theory.. On to the real world.
You know when the transmission shifts gears up, cause the RPM's drop about 500 rpms or so, but your speed is maintained..
For example, when accelerating up to speed, you get to around 45mph at 2000 rpms. Then when it shifts into 4th, the rpm's drop to around 1500.
During this time the torque converter is doing its slipping and sliding, cause, umm, thats what it does, it slips..
But, have you also noticed when you reach constant speed (say, 60mph in 4th), the RPM's will drop down another 50 or 100 rpms but the speed is maintained? This is because the the torque converter lock engaged and there's no slipping..
(I'm guessing at the RPM's cause I have the 5sp).
No slipping means, less heat generated..
I'm sure there will be others that can post this subject matter in a much shorter and clearer fashion..
I'm not sure where you get the guages installed, (catalogs like JC Whitney have the guages). Seems like folks on ford-diesel.com love all the gadgets.
Dry roads up but started to snow after we arrived.(3" or 4")
The 4x4 ESOF worked great and for the first time averaged 12.9 mpg. All of my other trips have been short -- to work and back -- less than 20 miles. Average there has been 9 to 9.9 mpg.(V-10 with 3.73 LS rear end.)
I am really pleased !!!!!!
from experience (as well as from Superchips
themselves):
Anything more than air filter and cat-back
would usually require re-programming (this
would include headers, mass air flow sensors,
throttle bodies, etc.); in my case, I have
the Edelbrock/BBK throttle body + Superchip
w/ stock program and experienced wierd
transmission/torque converter behavior.
Called up superchips, and when I mentioned
the throttle body, they told me that's it--
so the chip's out for now, and all is well.
The behavior I was getting felt like abrupt
locking & unlocking of the torque converter,
and worse yet, delays in its connection and
disconnection. I suspect it had to with the
fact that with this new throttle body, the
throttle position's changed and that's one
of the parameters involved in the chips
program.
So now although I can tell I'm running with
a bit less power and no more quick/firm
shifts, I prefer the way it is now because
the drivability with that problem really
wasn't good, but I'll put it back in when I
get all my mods done and the chip
reprogrammed.
Any info would be appreciated.
As for financing, if you belong to a credit union, I'd check their interest rates (so far, haven't seen anyone... bank, Ford Motor Credit, on-line, offer better rates than our credit union).
If you're new to forums, I'd strongly recommend also checking out www.ford-diesel.com . There is a wealth of information
Until about a month ago, there was access to the VOPC system (Vehicle Order Processing Center). This is an automated phone system dealers can use to check the status of vehicles.. however, too many non dealers got access to the system and were probably using 'non automated' options. So Ford had no choice but to add passwords so that 'dealers only' have access. Ford also sent notices to all of the internet forum owners to remove any reference to the VOPC. So, I think your left now with only the dealer to call for your status. (I've heard something about the CAC, but not sure what this is).
I'm sure sometime in the future ford will have this type of info on the Web, but its not a high priority as it is with some industries. Fords distribution channels for vehicles is currently much different than factory direct PC distribution.
Also, it sounds like you picked a good dealer, (large and truck only), but 8weeks is the fastest you'll see it.
www.ford.com
Been reading since Dec. Ordered 00 350 SD SC XLT
V-10 3:73 Woodlandgreen 12/11/99. Dealer gave me ETA of late Feb.,early March. Sold my 97 250 yesterday,and am now a contractor with no truck!
Dealer told me 4 or 5 more weeks. E-mailed him
post #210(thanks northpole) I think he got the point! I hope Ford gets on the ball before I`m outta business. Will post updates.
Thank you very much(4CrazyElvis)
#30 of 241: mileage info with 315's (duckfoot1) Wed 16 Feb '00 (04:45 AM)
Does anyone have mpg info for a 4x4 psd cc with
315 tires?
Looks like the 315's are a 35" tall tire. Did you find anyone currently using this size. I was thinking of putting 305/70R16's which equate to 33/1250R16. If the 315's post no clearance problems they would the tire of choice. Any info you discovered will help. I'm still in the "not haves" section or I would go to the tire shop and check the different combos.
Your explanation was great. Maybe now I just need another lesson in the theory of limited slip axles...
i had already ordered when i found the site but it did help with the waiting
i know youre getting close hope it happens this week
everybody-they are worth the wait
This has nothing to do with the 'Limited Slip' rear axle..
So, your next question is, "what does the limited slip rear axle do for me?".
A. Normal rear axles only apply power to 1 wheel at any one time, (the wheel with the least amount of traction). So, if you jacked one wheel up off the ground, or put it on ice, it would be the one that spins.. The other wheel on solid ground would just sit there.. So, you'd be stuck.
With a limited slip axle, 'some', power is applied to BOTH rear wheels. So in the case above, the rear wheel on the ground would also provide some forward drive..
Summary:
4x2 w/o limited slip= 1 wheel drive
4x2 w/ limited slip= 2 wheel drive
4x4 w/o limited slip = 2 wheel drive (1 front, 1 rear).
4x4 w/ limited slip = 3 wheel drive (1 front, 2 rear)
Hope this helps
Still getting 13.9 to a 14.1 rating on the mpg... I have to say that the cat back flowmaster and the K&N are wonderful....noticable increase in performace...better sound...and higher mpg...what a country!!!!
Everyone should go to www.sandbox.net and enter the March Madness contest....10 million $$$ if you can pick the entire NCAA bracket....heck...its worth a try....just think of all the crap you could deck out your truck with....with 10 mil....
According to DeLorme Street Atlas USA V6.0 (great tool by the way
nailbender 1 maybe after you pick up your beast tonight you can report if you got the new style holders and how you like them.
Does anybody here feel Ford should replace our drink holders under warranty if the new style is better then the old one?
John
I've been keeping track of the forum for a while. Ordered in late Nov. and it is on the rail (or at the dealer) as we speak. 2K F250 SD SC 5.4L 4X4 4.10LS XLT 5SPD Blue in Blue. I didn't order the CD (ups and downs of regretting and not) thinking I could get a cleaner-better after market deal. But, I am getting worried that may not be the case. Any success stories out there for adding CD capability to a SD that only has the XLT radio/tape? I hear there are FM changers, changer adapters, and total head replacement (hopefully not mine) with accompanying changer.
"Finding" a truck with the 5.4 may not be the same as "ordering" a truck in that configuration. If G&W says 8 weeks, I'd be inclined to go with that date. Just make sure you follow up that your order has been accepted (for this model year). I think with your configuration, you should be okay. It sounds like the auto trannys are the issue at the moment.
Your truck sounds alot like what I got. I received mine in just over 7 weeks. (and this was several months ago when the delays were generally longer for most folks).
As far as finding 5.4L's or V10s on a dealer lot, both are hard to find.. 5.4L's because dealers don't seem to order these for general stock, V10's because they are hard to get, and they sell immediatly..
Most dealers seem to prefer stocking PSD's. Gee, I wonder if this is because of the extra 4K for the engine alone..
8 to 12 weeks is worth the wait!
Y2K F250 XLT 4x2 SC 5.4L 5sp 4.10LS + options
average mpg=15.5
It was a tossup between a 4.1/4.3 and the 5.4 or the 3.73 / V-10. 310 HP sounded soooo good! So that's what I ordered!
Craig
Craig
Got my Ford Accessories catalog from my pal Bob, and I am cozying up to the woodstove tonight and doing a little dreaming....
Others if looking for one off the lot: I checked out a dealer (Key Ford) down in Pensacola and he said he could get one in 6 weeks. I took this with a grain (no a block) of salt. He did have a 350 drw psd white/gold on the lot. I don't know the tranny type but I suspect auto.
lilelmo.....Do you know anything about the Fanin County Georgia...Blue Ridge area....Have been wanting to get out of the rat race here around N. Tampa....and have heard good things about that area in Georgia....you can email me if you have any info...so the others here won't be bored...I would appreciate any info you might have....
Hey I do have a SD topic after all...
I am taking the beast into the dealer tommorrow to get bumper fixed....gas tank looked at...I think it is too small...and alignment check....Will post after fix.....
Cannot tell if the cupholder on my truck is a new one or old one. It's does seem to hold drinks in satisfactorily, however.
An earlier post from a couple of days ago reminded me to have a look at the front leaf springs for the shipping shims. Sure enough, there they were, wrapped in black tape. Cannot seem to notice anything different with them off however...
Still lovin my PSD. Now passing 800 miles and the gas mileage is in the mid-15's and slowly climbing (combo city/highway driving).
I was out in Chicago last week visiting my sister and her family, and we walked out to the end of Navy Pier. I looked East, and all I could see was Lake Michigan, the breakwater and inlet/filtration buildings for the water system. Sure didn't see any train tracks going to a Blue Island!
(sorry to be such a wise a**, couldn't resist.)
Dave
It's also a habit...when you live in Seattle, it seems like everything...except northpole and brutus...is east.
Finally, I've been through Blue Island (grew up near Chicago). My apologies to Lake Michigan...
Jraske- cup holders have a spring arm that is still a bit whimpish but better than old one. Light switch is a knob that turns like that in explorer, wish cup holder was like the molded ones in the explorer. I was told that the truck has 4 wheel ABS, but remember that old posts said the it only has rear ABS. Does anyone know for sure and how can you tell for sure? Really like deep W/W blue and dark denim interior. Was worried about stock tires but I feel the are fine, although it came with the General brand instead of Goodyear. XLT has lock for spare tire. Also got bumper 7 pin and 4 pin hookup on tow pack and a plugin for future brake control in cab. Need to check on beast see ya later.
