Honda Accord Diesel????
The Energy bill being debated has some pretty lofty goals - like 30+ MPG for all passenger vehicles. I don't care how great GM engineers are there's no way a Suburban (or even a smaller SUV) will get that kind of millage - unless you put the Honda iCDTi diesel in it and are satisfied with a 0-60 time of 20+s.
Also:
http://www.autoobserver.com/2007/06/toyota_makes_di.html#more
Hybrids do well under stop and go operations (but not anywhere near the epa ratings). This of course brings up the marketing and operations questions of why it took 10 years to come to the realization that (Prius) hybrids (among others) might be a logical replacement for the ubiquitous and probably iconic NYC taxicab/s (15,000 population?) ? For a supposedly environmentally aware population, they sure have passed a lot of unnecessary gas idling in NYC traffic??? and for a long 24/7/365 .
As a comparison to the CRV (which you quote @ 3700#s), the 2005/6 MB E320 weighs 3,860#'s and gets (real world) 40 mpg at a steady 80 mph. (208 hp/388#ft torque) As you probably would agree, MB is not known for its fuel sipping qualities, as is Honda/Toyota. For example, I would be absolutely thrilled if my 3700#s Toyota Landcruiser's got 40 mpg !!! Of course a lot of re-engineering would probably have to happen, such as: 5/6/7 speed automatics, etc, etc. So just on the "weight" factor alone, the mpg would be 2.67 x BETTER (15 mpg at 80 mph)
Keep in mind also the VW Jetta TDI is relatively porky at 2950 #s, but will get a no brainer 50 mpg at 80 mph. In comparison, I often wonder what my 2004, 2550# Honda Civic with a diesel option) would get!!! With the same motor as the VW TDI and probably slightly different transmission set up, it would probably be a lot more fun and fuel efficient to drive.
Not all drivers have the same needs and there are some expectations that probably cannot be met.
I still think that clean diesel is so clearly in the interest of the truck/SUV centric manufacturers that it boggles the mind that they are not moving forward.
Frankly, i don't believe these numbers for diesel. The jetta is rated for 49 highway, this number _is_ based on normal highway speeds. MPG drops quite precipitously as speed increases, because air drag is a bigger and bigger factor, and air drag increases as a cubic function.
Typically you can get the actual tested number by driving 55 to 60 mph on level ground.
60 mpg with the diesel is quite easily obtainable.
60 mpg with the diesel is quite easily obtainable."...
Yes my RANGE has been between 44-62 mpg. At 55-60 mpg I would swag the mpg to be easily in the high 50's- 60 mpg!
Those VW engineers are good, but indeed they have not violated the laws of physics.
fwiw, the mpg champion at 100 mph is the CHEVY CORVETTE according to Car&Driver. But maybe a TDI would beat the Vette - I don't think C&D tested a TDI @ extended 100mph.
I do fuel at the first click off all the time. Yes 40 mpg is a no brainer. I think the only time I ever got below 44 mpg was doing 300 miles of stop and go driving on the Las Vegas STRIP (taxi cab style), when I wanted to show Las Vegas to my daughter when she turned 21.
With a Z06, 2 folks and packed trunk (if one can call it a trunk), A/C going, 100-104 ambient temps, I get a normal 26 mpg.
Diesels should be available in every category. SUVs could get 30mpg, midsize sedans could get 40mpg and subcompacts could exceed 50mpg. We need diesels and we need them NOW.
So for example I have seen "identical" VW Jetta TDI's one being the GLS and the other being a GL version with a price tag difference of 6,000 dollars. You can certainly buy a lot of commute fuel for 6,000 dollars!
Using the Civic hybrid as an example, there was a 7,5000 difference between my Civic VP. @ 2.75 per gal and 41 mpg that buys me 111,818 MILES of commuting. So far that would work out to 6.6 years of commuting. This is not even to count the interest saved over a typical loan period and the TREMENDOUS depreciation hit.
Europe is @ 50% passenger diesel fleet and growing and that historically has taken them 30 years or yearly growth rate of .017%. The governments have also encouraged its growth vs government blockage at almost every turn.
For the same reason, Accord Hybrid should have been based off Accord LXV6, if not go even lower with I-4 engine.
$27,000 in light of the 12,500 I paid for the 2004 Honda Civic (gasser) will give me 2 Civic's, or one Civic and $14,500 for commute fuel. Even with a 1.2k premium for diesel; that puts it at $13,300 for fuel. At @ $2.75/3 per gal, either will give me 216,181/221,667 miles of commuting. For me this would represent app 13 years of commuting.
Whatever car Honda chooses to put diesel (or hybrid), I wish they would go for lesser trims as well, not just the top end trim. If they decided to put diesel in Civic on top of the new EX-L trim, it would cost almost as much as the hybrid.
Excuse a carryover from another thread.
HONDA PRESENTS ACCORD TOURER CONCEPT AND i-DTEC, THE NEXT-GEN CLEAN DIESEL ENGINE TECHNOLOGY
Date: September 11, 2007 07:17
Submitted by: Jeff
Source: Honda EU Press Release
Might be a US market precurser.....
"I-detect a US market precurser"
That would be the only way to have plenty of head room and still have the lumbar support.
Any other combination, while still appealing, would be a compromise for my needs.
Of course a wagon (avant, club, crosover, estate, squareback, combi etc. etc.) would make the most sense. Why not combine the most efficient Accord mechanically with the most efficient with space.
They could even make the diesel only a wagon so it sticks out like the Prius. Many people buy the Prius for the statement - if it looked the same there could not make the statement as well.
They won't have a wagon of course, but it is nice to think about.
