It's not hard Mark, the following is copied from the Edmunds Town Hall 'Help' section.
"Question:
How do I post a photo in the Forums?
Answer:
You may post a link to a photo or insert the photo using the standard html tag for an image.
Or you may use the HTML formatting provided beneath the text box. Type the subject of your photo in the "Title." In the message text box, click on "Img". This will insert the first portion of the image tag. Insert the URL of the photo after it. Then click on "Img" again.
Click on "Post My Message."
NOTE: Photos must be uploaded to a web site or hosting service. This will generate a URL that you can use in the above tag. Please contact your Internet Provider to see if they offer this service. If not, there are free image hosting services such as Imageshack.us and Photobucket.com.
Photos that hamper our page to render, either the photo is too large in size or file size, will be removed by the host."
I have a 2006 LR3 HSE with running boards and roof box which I had broken in with 600 miles prior to this trip.
(The Good News)
The LR3 handles very well indeed. The acceleration for a vehicle of this size amazes me. I had no trouble passing other SUV’s/Cars up the mountain pass on hard pack snow (factory tires). The visibility was great and on the trip down, the defrost worked awesome. MPG on the highway, even in the mountain passes was right about 17 MPG I had been getting 10.4 during the break in period for city driving, so it was nice to see that gauge pop up there a bit.
(Side note)-I am going to add this as I have seen many posts regarding chains/snow tires
Since the dealer wanted 650.00 for the dealer approved chains, and they didn’t look all that simple to put on (and I was required by law to carry chains) I did some research for other options. I decided to try the spike-spider (which the freelander uses) based on a recommendation from Les Schwab. These things are amazing as far as how quickly the go on, and they never come near the back of the wheel (spike-spider.com) These are still a bit spendy (400.00) but the fact that you can put them on in under a minute (found it took me 2 minutes) and take them off in less than a minute (had many people asking me if they were always that easy to remove and put on) I figured I was worth the money especially since it was 250 less then the dealer chains. FYI-I did make several calls to the service manager to get his opinion, but he never did return my calls.
(More Good News)
The LR3 with the factory tires handled really well in fresh snow (was a bit surprised after reading so many articles to the contrary) We received 20 inches of fresh stuff over a 36 hour period, so I had many opportunities to test this baby out. I did end up in the ditch (if you can call a 4 foot bank of snow a ditch) when another vehicle lost control and I swerved to miss it. Fortunately a little rocking back and froth and we were able to free the car and move on. I did need the chains twice; as the road conditions iced up on the way to the resort, and they worked amazingly well once I recalled the correct way to install them.
(The Bad News)
I am hoping someone else can tell me if either of these has happened to them. First, with all the snow, and of course the ski gear and cold weather, the inside windows fogged up like crazy and I constantly had to hit the max frost button. This created a ton of moisture, to the point we thought the sun roofs were leaking but later determined it was just condensation (a lot of it) Anyone else run into this?
The other issue was with the door molding. It came off when I closed the driver’s door, possibly from snow being on the running board. This is kind of odd, since you have to open the door, and it would seem tat would clear the snow away. The molding did not go back in very well, so it’s going to the dealer next week to be fixed.
Well that’s enough of a novel so far, comments on the issues would be great.
Sean
I might be wrong but as a solution, tonight before driving up my steep driveway, i selected the Low Range and then drove the truck up. It seemed to took less effort on engines part and less RPMs as well. Does this sound like an Ok thing to do for atleast during the break-in period.
Also, does leaving the car parked like that (Nose up) in a steep incline pose any immediate or future problems. Like engine not being adequately lubricated enough for the cold morning pre-drive warm-up run.
When, I asked my dealer about the break-in procedure, he said that there was no need for break-in these days. But LR3 manual talks about breaking the car in properly for the first 500 miles or so.
Do the tires have any break-in rules as well, like not driving above certain speed for a certain number of miles or keeping a certain air pressure etc.
It really needs to be in the instrument cluster. If not displayed all the time, it should at least be available while flipping through the trip computer pages.
I always see a lot of condensation from snow on boots etc in winter. One thought occurs to me though - when you used the max. defrost program it didn't turn on air recirculation did it? That would make things much worse.
We don't have much snow as yet in Nova Scotia this winter, but I'm keeping my fingers crossed!
Chris
- Will my paint deteriorate? The fact that LR have issued a special paint map in order to "categorise and understand the paint complaints" could be a tad worrying...
- Will my parking brake clip break? (LA206-002)
- Will my hood start vibrating and moving due to the known insufficient room (LA501-004)?
- Will my A-pillar start leaking (LA501-006)?
- Will I get water ingress (LA501-012)?
- Will my seat cushion develop a gap to the back rest (LA501-011)?
Now don't panic: these are all "just fix it if the customer complains", and every complex technical system (even a Boeing 747) has constant bulletins and improvements, so presumably the answer is all "no, don't worry", but with my long road trips, half of me thinks I'd be happier with the systems fixed before they have a chance break, not after... what say you?
Michael, you get my 2006 award for the correct spelling and usage of 'brake' and 'break' in a motoring related forum, and what's more impressive is that you used them both in the same sentence!
Believe me, it's a feat rarely observed. :shades:
I know I've said this before but for those of you who now have the mud flaps, just be careful going over rocks, snow drifts, ice formations because the mud flaps aren't flexible. I broke my front drivers side on the Mercedes while "off roading" and almost lost a back one. The back mud flaps (on the Mercedes) are attacked to the rear bumper cover and I didn't want to lose that!
If the LR's mud flaps were flexible, I would buy them but since they are not, I'm really afraid that I will lose one since I will go off-road occasionally.
Just my .02 worth. Mark
Indeed! I can attest to that. And I noticed you didn't spell it "feet!."
Another thing that happend to me, I like to back-in a parking spot sometimes and I almost broke a mud flap then too. The curb was really high and, thank goodness, I stopped before I broke the rear mud flap. Once I got out and saw it, I had to pull the vehicle up as it was pressing really hard on the mud flap. :sick:
Because of that experience, (for me), I'll pass on the mud flaps. It's just one thing I won't have to worry about. As far as rock chips, etc, the lower trim pieces are plastic, as you know, so I feel protected there.
Happy Off-Roading to all! Mark
grommet, i know you mentioned that i should not worry about the break-in too much and just drive nice and easy for a bit, but what about driving nice and easy but for a constant long time like 4 or 5 hours.
Oh, good to hear that. My typing is bad (brain faster than fingers), but my spelling is excellent... I have a real bee in my bonnet about spelling, if you will forgive the punny metaphor!
Once about 10 years ago, I drove the same trip with only one night on the road. I will never do that again! I drove about 10 hours the first day and 16 the second.... wow, I was tired!
I try to do the trip rather leisurely and just stop when I feel like it. My buddy will be going with me and I'll leave the Land Rover at my other house for about a year until I have to bring it back to my home state for tag renewal. Even with the long trip every December and January, I'll only put about 10,000-12,000 miles on the vehicle per year.
Mark
"Seats in only six vehicles -- all SUVs -- earned the highest rating in the IIHS analysis, including the Ford Freestyle, Honda Pilot, Jeep Grand Cherokee, Land Rover LR3, Subaru Forester, and Volvo XC90."
Now you know why some people don't like the head restraints: They are safe. :shades:
Here is the direct URL for the test.
LR3 Test
No: I don't like them because they push my head forward and give me a headache. They are ridiculous and should be at least an inch further back.
This is an emperor withouth clothes: these headrests are supremely uncomfortable because they push my head forward an inch. All the government rules, safety reports, and good intentions do not change that: I say again, THEY ARE UNCOMFORTABLE AND GIVE ME A HEADACHE. THAT is why I do not like them, not whether they are or are not safe. They give me a headache.
And when you read the article you see:
...geometry (distance behind and below the head of a seated average-size man)
So these monstrosities are made for "the average-sized man", and they are NOT adjustable. How dumb is that? If you are not average sized or shaped, tough.
That is just bad thinking - which I presume is why most other car makers quite rightly ignored it.
Did you have your LR3 head restraints modified by a 3rd party?
From your 1 year review, you stated "The seats are perfect for driving long distances. I can easily drive 12 hours (and did that after a business meeting yesterday) without getting at all tired." and make no mention of your comfort issue with the head restraint.
Nah, I've not had them modified - I live with them by tilting back the seat back further than I would like.
So the seats are fine! It's just the headrests. The seats means the surface, firmness, shape etc of the seats. And indeed they don't tire me at all. The headrests on the other hand push me when I do not want to be pushed, so I have to drive with the seat back way back. Yes, it is doable.. but I must say - and you picked this up very well :-) - that indeed I resent having to do this because the LR3 designers have decided I must not have an adjustment option!
Yesterday my dealer, Flatirons LR in CO, sponsored the first event of 2006 - Ice Racing on Georgetown (CO) Lake.
This was insane! My wife entered the women's division and took second (missed first because of my backseat driving). I only took fourth in the men's division (should have listened to her tips).
These three ton behemoths handle very well on ice. I am running Nokian WR SUV tires after the stocks wore to the threads. If you do not try to push these vehicles to the limit you will never truly understand the incredible value you got for your hard earned money. Running the LR3 on ice proved that technology can control this monster on the slickest surface around. I am even more confident in the safety of this vehicle after this weekend.
I hope your dealer strives to give you as much of the "experience" as mine does.
A few pics:
Don't go over the dam!
And they're off!
Did you compare to the V8 version of the XC90? If you don't need any hardcore off-road or any of the unique features of LR3, it's a good alternative bet -- and pretty quick. And if you're really keeping the 4Runner on the list, you might as well add a common '06 Explorer, too. :P If fuel economy is a real concern, you might as well cross off LR3 as it's probably the worst of the bunch due to it's heaviest-in-class build... but they're all pretty bad. If you really care, you need a different class of vehicle...
Pricewise, the LR3 and the XC90 were neck and neck the Jeep Commander was about $10,000 cheaper (MSRP).
I did not compare the Toyota 4 Runner so I cannot say anything about that one. The Volvo had very short sunvisors with no adjustment once you move them to the side (I think I'm the only consumer that it bothered). Secondly, the nav screen pops out of the dash and seemed smaller than the LR3. Also it was tilted forward and I'm not sure if it adjusted because I didn't touch it. It just so happened when I was looking at the Volvo that the sun was hitting the dash; I could not read most of the instruments on the center console. The nav controls are on the back of the steering wheel. If you have a passenger that would like to control the nav, they said there was a remote the passenger could use. To me, that sounded like the nav was an after thought.
Compared to the LR3, I found the Volvo's second row seat difficult to fold over to get into the third seat. Maybe I wasn't doing it right but it worked perfect for the LR3 the first time I flipped it up.
The Commander came up short in so many area's for me. The third seat was the tightest and the rear load floor was raised 3 or 4 inches when all the seats were folded down. And, the dash looks cheap to me. It has wood grain but it's all below the big plastic part running across the dash. (I added the wood dash to my LR3 and it looks great)
The Jeep passenger seat is only a "4 way" automatic. It will not raise or lower, only back and forth movement. I didn't like all of the "bolt" design from the dash to the wheel moldings and even in the headlights. But, the Commander does have a good drivetrain and strong engine.
The Lexus GX470 lost immediately with the "big" swing-out back door. If you are in your garage and if it's a standard size, you will have to open the garage door to get anything out of the back because there will not be enough room for the big Lexus door to open. The hanging third seats get in the way compared to the other three vehicle I just mentioned.
Good luck on your search! I think the LR3 will win!
Mark
Did you guys see any difference too?
Which one you guys think is the best fuel from all the different stations?
Thanks in advance.
I have been looking for a Nav system to fit into my LR3 as I did not purchase one (and wish I did). Which Tom Tom model is the one that fits well? Do you have that system in your LR3? Do you have pics to post or e-mail?
Kevin
I'm hoping my 2006 LR3 HSE doesn't give me any problems but my dealer is only a few miles away. I would have to say if my dealer was 100 miles away, I would have to think long and hard about driving that far for service. I think I would pass on a Land Rover product because of the distance.
Mark
Are you dealers seeing that also???
As a guy with a large family, I am going to need the LR3....if I can locate Black with beige however!!!
Do note if you have a "large family", you aren't going to have a lot of space if all 7 seats are in use in the LR3. You need a van. :P
While I was visiting Newport Coast this past summer, I saw a black LR3 with matching painted wheel lip moldings and bumpers. It looked gorgeous. I had wondered if that was an option but I have never seen another like it. I guess the owner had the panels painted.
I acutally like the fact that I have plastic since I will be on the highway and for parking lot dings. I just hope no one pics the "smooth as glass" side door panels to bang up! :sick:
I'm using 100% cotton baby diapers to wipe down the Rover as not to scratch the shiney black finish. They seem to work perfectly.
Happy Motoring. Mark
This is my first high-end vehicle, and, while I love it, I'm pretty pi$$ed. If this is not quickly and permanently corrected, I'm selling this :lemon:
The LR3 is a pretty complicated vehicle and has not been out on the market all that long if you think about the lifespan of a model. It could be that the Tech at Darien has run into a problem he is not familar with and is checking with Land Rover to see if someone some where has seen the problem. By doing this he benifits from all of the Land Rover Techs in the whole world and hopefuly someone some where has seen the problem and reported the fix to Land Rover.
Give them sometime to correct the problem. I would not start calling my car a Lemon after a single trip to the dealer.
