Chevy Silverado - Continued IX
Anybody have weird experience with the fresh/recirculate air modes? I was tryin to defog the windshield w/outside air and it kept going to recirc. If I went to "face" position, it would allow outside air. Also, the A/C feels like its on sometimes, but no visual indication. -scott
Ryan
Kevin
Kyle
I figure it must be How can you defog with the same air that is in the truck that had caused it to fog?
Ryan,
You pay what the price is when you pick it up.
- Tim
What's happening now is every car company is getting fuel escalation clauses invoked by the transport companies because the price of fuel is going up. We are all at the mercy of OPEC. This goes not only for new vehicle delivery, but everything we purchase. It affects food, clothing, durable goods, everything. All we can hope is the prices stay stable or start dropping before you get your truck and the prices shouldn't go up anymore.
Jmes: The Sylvania Blue's are available at local AutoZone or auto stores if you go with those, they keep the same 55/65 wattage but put out a white light over the standard yellowish factory. I have them in my car & it was an improvement over standard halogen lamp.
Ray T.
Cam
http://www.PictureTrail.com/dayle1
Rob
I mainly want mine to change the tire size as well. But if gas prices will drop a little, I want to try their other computer settings - 17 HP and 35 lbs torque increase. But you have to burn premium gasoline with the changed settings.
But still don't have the truck yet - built last week though - hope its soon.
Greg
The LT full feature seats are great. I never gave the interior mirror much thought but once you have it, you really appreciate it at night. Other things I like about my truck, the driver's side rear door. I really like the GM soft tonneau cover. I have a ATV & didn't want a hard tonneau cover.
rcoos
No rear sliding window orders were being accepted. The only other thing I could not get was the Auxillary Battery. Even though the Build your own site says it is available in CA with a manual trans, I couldn't order it that way. Oh well, I have Vince4's details on adding it after the truck arrives.
Low temp T-stat is used in conjunction w/engine mods. -scott
Car and Driver did complete dyno tests on a number of 1999 vehicles (including a Silverado with a 5.3L engine and an automatic tranny)using chip upgrades and re-programming tools. They did dyno tests before and after as well as tests at the drag strip. The only one that made any real performance changes was the Hyper Tech in the Silverado. There was no horsepower gains however the tool allows for changes in the transmission shift points and that helped on the street. Plus the fact that it allows you to recalibrate the speedo if you change tire sizes is also a nice feature.
IMHO most bolt on after market performance mods are nothing more than the hardware equivalent of snake oil.
You want real significant horsepower gains you need to dramatically increase the amount of air and fuel used during the combustion process. The only way to do that is with either through internal and external engine mods, a bigger engine, supercharger/turbo charger or nitrous oxide. Then the question of how reliable will your vehicle be.
There is a saying in racing "horsepower costs money, how fast do you want to go?"
Now if you have an auxillary computer, like these programmers people are waiting on, or in the old days a new prom. You can reprogram the motor to take advantage of this extra fuel it's getting, thus more power.
However, to change a thermostat to colder without the other mods to go with it, is a waste of money, time and fuel.
Once removed, it comes apart like a radiator cap, press, and rotate. Then just drop in a BB, or 1/8" spacer into the hole, with a small piece of screw thread, and reassemble.
I did this months ago, and have been delighted ever since. No ill effects. Just a perceived calmer running engine, idles smooth, heater works great, fuel economy unaffected. Runs at about 10-13 degrees cooler if the outside temperature is cool. In hot weather, makes no difference whatsoever, since the thermostat is fully open anyway. Ping has been under control for a long time now, run 85 octane (Colorado regular grade) all the time now.
This change does not "trick" the engine. The drop in temperature is actual, not perceived. Engines today do run hotter, for emissions compliance reasons. Pre-emissions engines ran colder, not because engineers didn't know how to make them run hotter, it just wasn't desirable. So I don't want to debate. I just want to relate to you my personal experience on this issue, which has been very positive for me, in reducing the occurrence of engine ping. No reason to heed the naysayers...they have not tried this free trick.
The T-stat mod also will not turn on your SES light. Some of those other mods, like the Granetelli, Maf sensor have done this.
Ryan
Sorry Babbler were boring you but we do like to occasionally take about Silverado's instead of drywall & music.
back to sleep wake me when we get to a good topic
ZZZZZZZZZZZZZZZZZZZZZ!!!!!!!!!!!!!!
Ryan
I was messing around with my ZZZZZ i was being a smart [non-permissible content removed] (im young i still can do that) if you dont like it you know where u can put it.
So your a mechanical engineer? What a coincidence thats what i am going to school for. art doesnt interest me.
Exterior options should be an interest maybe because EVERYONE sees your truck????? Waht do you want it looking ragged and plain? Go for it then. Some people want to "dress" their truck up to make it look nice.
Ryan
Ryan
And if you and that other ME (so he says) Rwellbaum don't stop writing "your" when you mean "you're," you're going to have to redo the whole semester, that's what!
Damn I'm mad...
Chill out man seems like YOUR stressed out. Take slow deep breaths
Ryan
see u all in a few days
I want the simple, minimal air line setup. You know kinda raggy and plain. How much bucks? How long did it take you to install?
Went to TX a couple of weeks ago with two guys, two dirtbikes and big trailer, had the equalizer bars cranked way up and rear fender well height was still about 1 1/2" lower than front. I think the bags woulda fixed the problem.
Ryan
Ryan
P.S. Bob259 has left the Silverado group and joined the Mercedes ML320 fold. Tired of the problems he was having. Let's say a group prayer for the misguided soul (moment of silence).
I know this stuff bores you, but I think the best mod. you can do is to change the tires. I like the 265's, but the 285's look so much better. Ford puts 17" rims on some of there trucks with 265's on them and these 285 16" tires still look better. They really make it stand out.
17 H.P. and 35 ft. lbs. of torque through the hypertech?? Sounds a little much. Anyone with a 99 done this and noticed a big difference?? Still waiting for 2000 hypertech. Thanks for all the info...
Who cares if the subject isn't what you would like to hear....chill and wait until it is what you want to hear.
Life's too short man.
- Tim
I think they were around $180, give or take, after presidents club (LOL) discount.
Took me about 5 hours as I recall, about 1 or 2 of which was consumed by false concerns about how they fit. I had to drill holes through weld beads. I thought they would be hard and brittle, but were soft and easy to drill. Also have to put your hand in some tight places to install the locking nuts inside the frame rail, but they do fit. Somebody good, like you, could do it in half the time. Once installed, you can change an air bag in seconds, without tools, if you need to. I haven't needed to.
I don't have the on board compressor option, but just ran short lines to (2) shrader valves installed in the fender well lip, and use a bicycle pump. Don't join the two air lines, or air could transfer from one bladder, to the other side during hard cornering, not good.
Still love 'em and recommend 'em.
I hope to settle down to earth soon so I can start dressing that beauty up. It is INDIGO BLUE.
Have a nice day everyone,....:)
Roger
I dont care what you guys talk about it doesnt bore me at all trust me i read all the posts. I was just being a smart [non-permissible content removed] i apologize. No one has a sense of humor nowadays
Ryan
Go to http://www.huskylinings.com
they have very nice floor mats that catch everything.
RSK also i dont have my truck yet only thing i have gotten so far is the mudflaps (were on back order till june but some how they came in) and a receiver plug.
Ryan
http://www.huskyliners.com/
sorry bout that i always get it mixed up
Ryan
