You have probably heard by now the importance of the correct oil (as specified by the oem owner's manual, I believe yours is the VW 507.00 specification).
No, they are not as off the shelf. You might want to look at the vendor section of www.tdiclub.com for whom carries what and at what price.
There are no specification differences between summer/winter oils for the TDI. The viscosity for the VW 507.00 specification is 0w30.
I still run the 03 TDI specification oils and the viscosity is 5w40.
Any feedback would be appreciated. Thanks in advance.
HOWEVER: I have dealt with some VW dealerships which are not very good at submitting such an order and following thru... Personally, I waited 3 months before I found out my "order" was sent to another dealership and sold. (I found out on the internet that the VIN my dealer gave me was sold in another state... I had to CONFRONT the salesman before they would admit it)
Ask your salesman to sit with you as they log into their internal VW delivery schedules and show you what is coming. They should have "visiability" to all vehicles on ships intransit to USA and what dealerships they are destined to be deliverd to. If they cannot do that simple task.. then your salesman may not be telling you the entire story.
If you want to "order" a specific vehicle which will be built to your specifications... get a Dodge! My Dodge truck was deliverd within 4 weeks exactly as I orderd it. The window sticker said "This truck built for Bruce A. Peebles" right off the assembly line.
(Don't even bother with the factory/turanza tires in the snow/ice,
and forget studded snows too. snow+ice tires are the way to go!)
(I ordered my '06 NIssan Frontier with specific features, just like your Dodge. My truck arrived in six weeks, made in Smyrna, TN.)
Here are a couple websites for NOKIAN
http://www.nokiantyres.com/
http://www.nokiantires.com/
Since I have well over 60K miles of experience with the WR... here are my comments.
*)The original WRs lived up to their claim as ALL WEATHER tires. They went thru many Vermont winters and only got stuck when the bumper was pushing snow!
*)The rolling resistance is low.. (I averaged 50 MPG)
*) They became NOISY as they wore.
The new ones (WR G2) are significantly quieter than the original WRs.... I have less than 100 miles on them so no further comments about the G2.
Have you had any other trouble with your TDI?
The last clutch job that I watched, the guy had 230,000 miles and had done a host of things to his car, suspension upgrades: struts, shocks, springs, front and rear sway bars, lower profile tires, expensive rims, chipped, two upgrades of nozzles.... I am probably leaving a bunch of key things out. If he was not approaching 275# ft (from 155 # ft) I would be surprised. The bottom line is we were standing there and he asked me if he should do the clutch (as he had the V6 upgrade at home). I had ridden with him and got a sense of how he drove and treated the car and told him flat no. Wait till he got clutch chatter/slipping and or both.(It should be fairly obvious just his power options seriously out powered his clutch) However I also said to him that if the clutch is pulled to check the condition, it was actually then marginally to way (depending on condition of course) cost effective to put in the NEW one. Curiosity I think got the better of him and he went back home to get the upgrade. When the clutch was pulled, it easily could have gone another 200,000 miles (430,000 total) . We just busted up at the projection and scenario we had discussed before the dismantling. The guru who was doing the job concurred. So the clutch (upgrade) was installed. He was a happy camper before, but I think because he could NOW use his power upgrades with more abandon, a happier camper AFTER.
To answer your question, you really have a couple of choices. The best would be to get on www.tdiclub.com. A vendor I trust is Bleachedbora who sells clutchs/flywheel/throwout bearings. Email him if you have questions. An upgrade (V6) is at $375. shipped. Look to get the service (clutch job) at a local GTG. We are talking less than $725. all tolled.
So, now that 15 weeks have passed, I'm waiting. I may take some advice I read on this thread and go to the dealer and look at their list of cars that are on the way.
If you need to know the price to replace clutch ... CALL SEVERAL SHOPS and ask for estamates. This is such a rare occourance on VWs that you may not get much from asking on the internet.
A properly-treated clutch on a TDI should last for over 200K miles. Heck - one does not even need to touch the throttle when starting off from a dead stop.
As for your xmission, I can tell you that a VW manual xmission can EASILLY go over 200,000 miles. There should be no need to do anything but replace the synthetic fluid in the xmission with ONLY factory-recommended . (or RedLine MTL). I have never even HEARD of a VW xmission wearing out. (And I have owned many VWs over the years.)
Manual transmissions usually give warning signs (except under abuse) long before they fail completely. I drove a manual transmission over 30,000 miles with a bad input shaft bearing once before I got tired of the noise and replaced it.
As for how it sounds / feels, it is restricted to feel...there are no related sounds. I'm easy on the clutch. I never ride it, and it is almost fully engaged before I start to push the accelerator. However, just recently, I'm noticing that as I'm starting to push the accelerator, the clutch is slipping. It shudders, but there is no sound. I can feel it through the pedal, through the seat of my pants. Another thing that it is starting to do occurs as I'm accelerating onto the highway from an onramp, usually in 3rd or 4th gear. It doesn't happen all the time, but there is a momentary lack of power, or so it seems. I've decided that either the clutch is slipping and allowing the engine to rev slightly without the related additional momentum that you would expect, OR the engine alone is experiencing power loss. Could the turbo be dieing? The dealer mistakenly diagnosed it as the cause of a noise at around 100,000 miles, so I ended up getting a new turbo under warranty. It only has 50,000 miles on it.
Too many of these things are happening within days of each other. The clutch is obviously wearing, so I'm reluctant to assume that the turbo could be going at exactly the same time. On top of it all, the coolant hoses split about a week ago, and within hours of that happening, the front suspension started creaking as if it had no lubricant on it. I assumed that maybe the leaking coolant disolved the lubricant on the suspension. The mechanic noticed my suspension bushings were worn, so they replaced those, along with the coolant hoses. Unfortunately, after a few hours of silent suspension, the creaking noise came back louder than ever.
If I fix all this stuff, I'm probably going to be $3,000 in the hole, and keeping the car for another 150,000 miles
An automatic xmission tends to generate more heat into the cooling system than a manual. (That is one reason automatic gets lower MPG). VW knew this and added electric heater for antifreeze when you have manual xmission.
For CERTAIN you should cover the radiator air inlet during the winter. Lengths of pre-slitted 1/2inch pipe insulation is PERFECT for this job.... just slips between the slats of the grille. When ambient temps go up, it can be easilly removed and tossed in trunk with spare tire.
I am considering the purchase of a Jetta TDI next year, has VW reliability improved?
Another is the so called definition of reliability. What does that REALLY mean?
As a comparison, I have the "highly reliable" Honda Civic (04) . Honda defines it SANS "consumables" Well, needing tires at 74,300 miles and three alignments the way the Civic does, does NOT count in the reliability measure, even as I am still running oem tires on the VW Jetta @ 110,000 miles and have not NEEDED any alignmenst. So at 300 per tire set and 90 per alignment, the Civic has cost me $ 570. MORE in operating costs. While this is factored in at the per mile driven cost. It clearly is NOT factored in @ the reliability measurement.
(As history I also had a 82 Honda Accord manual)
By the way, based on our frustrating experience with an Audi and a nephew's similar experience with a Corrado, I suspicion your problem on the Corrado was the fuse panel.
The whole story is important here probably. Head needed rebuilding, has new camshaft, timing belt, tensioners waterpump since it was all open. I also had the turbo actuator valve replaced (the bladder gizmo behind the engine). Right after that the turbo worked great, car ran like a dream for about a weak. I then noticed when the turbo would spool when at high RPMs that it would skip and then plop into limp mode. It has gotten progressively worse so that now it will drop off almost from the first acceleration in first gear. It will usually fix when the key is cycled.
when I run the codes I get P0101 an P1550 (regular handheld jobby), and under the the Vag-Com there are also codes for the rear ABS sensors.
So far to fix this issue I have replaced the Turbo Solenoid (up by the windshield with the hoses going to it), I have replaced the MAF....I have taken apart the hoses going to the air filter (all clear). I have visually inspected the vacuum hoses and though a little frayed don't see any breaks. The air filter is relatively new.
The connector plug (that plugs into the MAF) is a replacement plug so it leads me to believe someone looked at replacing that before I came onto the scene. I am thinking I should check to make sure that is wired well...but what else should I try. Any advice, happen to anyone else? I am reaching the end of my wits thinking about it....need some things to check so I feel like I am sniffing out the problem....give me your best shot!
Jason
WVO 2001 jetta TDI GLS auto
1999.5 Jetta TDI GL :confuse:
Neighbor stopped by this weekend and he'd recently turned 150k on his '06 Jetta TDI. The only "repair" he's made was to replace the glowplugs a few months back. I ask him about the clutch after reading some of the posts here and he said said it was fine. Granted we (as do most TDI owners) drive largely on the highway so there's really no reason the clutch won't last a very long time. I'ver also not ever heard of anyone that lost a manual tranny on a tdi.
How often does this dude replace fuel filter etc ? Does he use the factory maintenance sched and do ya know, is he a member of Fred's?
cheers...
Very impressive (makes the 295k on my VW Dsl PU look like small potatoes).
best, ez
Tested MPG on a couple of 30-40 mile interstate trips. If driven at about 60 miles an hour( 1800 rpm) , I got as high as 47.4 MPG. Not bad. expect better after break in.
Even at 70 expect 40+ mpg
Handles great.built quality appears excellent. Nice amenities including two 12 volt outlets and a 120 volt outlet. My only complaint is the sunroof shade/screen, the interior can be pretty bright if the sun is at a certain angle.
The car seems very well built and the seats are far more comfortable than those in my 2003 Passat. I love the panorama sunroof. Makes the black interior far more cheery. Overall I am very pleased so far and my dealer was great. No hassle and I got the car in 30-days.
One thing I have noticed is that the car makes a high pitched hum for a while after I shut it off. Is this normal? Does anyone know what this is?
