Honda Civic Sedan 2006
I had to look through the list a couple of times before I found it.
I liked the EPA mpgs, crash tests, and thought it was reliable but if people are having problems now, what happens when the warranty runs out?
I guess there isn't any sedan that has a combo of high mpgs, perfect crash ratings, and reliability.
Subarus are the closest with these qualities like the Legacy and Forester. Unfortunately the mpgs suffer because of the AWD but I guess you can't have everything.
Others with high mpgs are the Honda Fit, Scion xA and xB, and 2007 Nissan Versa. All these cars horsepower is lower than the 2006 Civic and none have been rated by IIHS yet but their Gov crash tests aren't perfect, though the Fit is close (front: 5 driver, 5 pass; side: 5 front, 3 rear). Too early to know Fit is reliable but Consumer Reports predicts reliability to be 'better than most' for the xA and xB.
All I know about the Versa is interior and trunk is larger than Civic. If Crash results are descent I will consider it along with the Legacy sedan.
It is not smart to run from a Civic to a Nissan Versa in chase of better reliabilty.
It makes no sense at all to even be considering a Nissan Versa because a Civic is "not reliable enough."
It is the opposite of a logical thought process.
Nissan+Renault+first year of manufacture does not equal a higher odds of better reliability than a 2007 Civic.
-You need to have your windows up and sunroof closed to use voice input
-the screen is washed out with sunroof open and sunlight hitting it
-XM is like 500 bucks plus month to month (all sedans, coupe it is standard for 06)
-It is very quick
-The stereo in the coupes has an amp and premium Pioneer speakers as the sedan has no amp and cheap Pioneer speakers.
Probably a lot more but its quiting time and I need to go home.
Also, how is the pickup? I don't drive like a dragster, I am very good at getting up to speed though and cruising my way to work or on the highway. Like I said, I average 25.3 mpg in my 2001 BMW 325i and it is rated at 19-28 I think so I am closer to the upper end, and it is an automatic. When I had my 528i, I was averaging 28 mpg, and it was a 5sp.
If you never needed to refer to a paper map to find where you needed to go, then why would you need nav?
Hi tjs01: This is really useful info. But I have looked through all of Honda's Service Bulletins and I cannot find any that relates to the 06 Civic engine mount.
Also, I don't see any other posts regarding the mount. Can you please let me know which Bulletin and post you were referring to?
Thanks a lot.
If I were you I would not spend the money on the Navi. The sound system is not great and it is the same with or without navi besides the PC card slot and I still use my Ipod mini rather than that because I can mark them with stars when i want to keep or delete, the EQ and play lists.
Good luck and I am always willing to answer any more questions.
Honda http://townhall-talk.edmunds.com/WebX/.f0d71c1
http://www.8thcivic.com/forums/showthread.php?t=10426
Where is the fuel filter for 2006 Honda Civic lx ?
Mine had this problem, too. Cause was an assembly line problem wherein one of the seals under the dash was improperly installed. Fix was to disassemble the airbox under the right front dash, take the kink out of the seal, and properly reassemble it along with a generous anount of "goop" adhesive. No drips since.
Thanks a lot.
It's not a service bulletin; it's in what Honda calls service news. I just had this right side engine mount relaced, but the noise still remains.
Can someone please point me to official honda service info page, i am looking for website where Honda maintains the service/problems record for 2006 Civic.
I noted lot of discussions regarding the wind noise from driver side window above 50 mph, the dealer said that he fixed the problem by inserting a form, but still i hear the same wind noise, has anyone wind noise problem being fixed completely ?
No problems, 38MPG
You might want to check for loose things in the glovebox. Also, have a passenger press the door closed while you are driving over a rough road. If that stops the sound than you know where to start.
If its just a fairly low volume rattle, it might be something as simple as a loose wire or plastic heating duct contacting the top of the glove box. I'd ask the dealer to remove the glove box and look into the area above and behind it for dangling parts that should be taped or wirewrapped into place.
Be careful in there though. You don't want to endanger the airbag system that's in that area.
The increase in revs is not drastic, but it's enough that I can definitely notice it. Any thoughts? I don't want mechanics ripping apart my engine if it can be avoided.
One thing about an automatic is you can just step on the gas and get good acceleration. Not that I'm opposed to a manual, but to maximize acceleration you have to drive a manual like you really mean it, specially off-the-line if you want to go from a stop light.
Anyway, I guess I'm locked in on my '04 for a while because in a weak moment I bought a set of new Kosei Racing 17 x 7" wheels and 215/45 Kumho SPT tires that wouldn't fit on the new 5-bolt set-up. I should note that the original Bridgestones are also very good.
Actually, an alternative I am considering is the all-new '08 Accord when it comes out.
