Stability Control, are you ready for it?
many cases I've heard about researched, the sensor was
operating properly, what other factors came into play is the
question. I remember once, folks are gone now, can't hurt
to tell on myself, but distracted while driving and rear
ended a parked car. Turned out to be a HS classmate, and he
thanked me, got a new car out of the deal. My story at the
time was I swung at a bee and hit the wheel, I was alergic
to bees so, plausible. Not that anyone ever omits any
details but it is possible they got confused ...
Back to the gyro, the one I was most familiar with had a
built in default mode along with software defaults where if
the inputs from gyro, steering and wheel speed sensors were
out of bounds, the system gave a shut off notice. That
leaves bad input that mimics normal driving, not real big
window there. The gyro default was that if it didn't have
self test data that passed the test it also did a self shut
off with notice. I am not aware of any cases where sensors
where found to be at fault.
The software for the full system is usually a car mfg. item
using various sensors and yes they look for low cost on the
sensors. Some but not all do pull back on engine power when
the system engages. Depends on what they are trying to
accomplish. If using the front brakes is the answer, using
engine braking shifts more weight forward than just using
one brake, being more effective. If however, the rear brake
is called for then keeping power down is better, some have
figured it out, Corvette being one.
Most sytems only have one gyro, BMW however, opted at least
for some time to go with redundant gyros and compare outputs.
Some gyros can co-exist with other gyros but there are some
that seem to give bad data when they get together, it is
pretty complicated for a finance type like me vs. what the
engineers can discuss. Last I heard there were four main
gyro producers with two having the Lion share of the market.
A German Gyro was in the high end MB, BMW, Porsche, etc.
while a US gyro was in lower end units of those same mfg's.
I'm about a year out of date on what is going on currently.
alive applies. My MGB carried the scars from that one for
several years before I sold it. I finally found that
snacking while driving keeps me awake, what ever works ...
This is
important because ESC reduces the risk of
single-vehicle crashes by about 40 percent.
The effect is greater for fatal single-vehicle
crashes, which are reduced by more than
half. ESC lowers fatal multiple-vehicle crash
risk by 32 percent (see Status Report, June 13,
2006, and Jan. 3, 2005; on the web at iihs.org).
SUVs benefit most because their high centers
of gravity make them more likely than
cars to roll over. ESC decreases the risk of
fatal single-vehicle rollover crashes of SUVs
by 80 percent.
I'll expect the same arguements that were used against seatbelts and airbags citing individual experiences that fall outside of the average. I've had people tell me that they'd be safer if they were ejected from the car rather than belted in. I'm sure there are instances where that's true, but for 99% of crashes it's false.
since he owns a toyota race team, i figure he was driving the latest and greatest model, although i can't tell from the picture.
the seatbelt probably saved him.
The references to the studies have been posted several
times and you still say to don't know how they were derived.
Go read the study introduction, not even the whole thing,
and you will be enlightened! The one I remember from
several I looked at in the past took two years of crash
data for a single model and then took two years of similar
data when the ESC was standard equip. In a world where 34M+
passenger vehicles are sold annually in the US and EU, that
does allow for statistically significant data pools. Since
ESC is the prime difference and since demographics would be
similar for the same model over time, pretty good study.
Randy
It's difficult to find something like that. The Altima Hybrid might have been the one, but you have to buy the $5000 option package to get bluetooth and then you have a $30K plus vehicle. You can't get VDC on the 2.5 non-hybrid at all. The 3.5 is pricey and a gas guzzler.
No VDC on Sentra and Versa.
Does any vehicle like this exist now?
I think I can cherry pick that combination of options on the 2007 base model Mini Cooper, but it would fail my reliability requirement. I also have heard rumors than the 2008 Ford Focus might have this stuff available, but reliability might be subpar and resale value will definately be poor. I have also thought of a Dodge Caliber SXT, but reliability and MPG reports have been poor.
I think the current best choice is the Camry Hybrid or 4 cylinder Camry XLE with optional VSC unless the 2008 Accord has VSA and bluetooth standard on LX or EX 4 cylinder models this fall. I think the next most likely vehicle will be the next generation Honda Fit or Corolla (2009??) unless Nissan has any plans on making VDC available on Sentras and/or Versas in the next year or so.
Sounds like I might have to wait until stability control is mandated in 2012 to get this combo in features in sub $25K cars. I don't want a Prius and I don't want a bluetooth headset.
I'd actually prefer to go down to sub $20K economy cars, but I'll look at cars in the 20-25K range if necessary.
Any suggestions?
Missing Features Pt. 2 (Strategies for Smart Car Buyers)
Note Joepublic's comment - "But in Ford's defense, stability control probably barely registers on the average buyer's radar. Nobody knows what it is! (Okay, not nobody, but probably less than 10% of the general public)."
Ref's to safety data including ratings with some ESC cars.
http://www.designnews.com/article/CA6451550.html?industryid=43655
Discussion of new mandate, I thought it was in place but
some items seem to say it isn't final yet. Also a little
discussion of differences in systems like the Ford Roll
Stability Control which has roll measurement in addition to
Yaw measurement which all systems have.
Randy
As expected the list of what has ESC is growing.
Seems the FIA is pushing the stability control system too.
It seems like their profits should start rising as more and more automakers put it on more cars as the date where stability control becomes mandatory gets closer.
The studies had shown that the reduction of accidents was with those few cars that had stability control.
with Stability Control as added functionality. So, Bosch, Continental Teves and
GM all had their own systems. That was most of the market through 2005, but
then TRW and Akebono were late to the market. Bosch made the first systems
for MB using their own gyro and CT/GM used a gyro from BEI, now Schneider Elec.
Several other Gyro makers have entered the fray in the past couple years. The
gyro is what measures yaw (about to spin) but then it is the computer program from
each car mfg that tells the system what to do from that point. Toyota had some
really terrible systems early on while MB, Porsche, BMW and Corvette had some
of the best. Oh, the system usually also uses data from wheel speed sensors to
get wheel slip info as well. Some of the systems use Accelerometers to get linear
data too, it all adds up to how drivable the system is and how noticable it is, which
it shouldn't be. All those component mfg'rs have been doing well since 2000.
Randy
With about 250M cars on the road in the US and sales of say 15M and less than
50% having ESC, the impact is going to be small until several years after the
requirement is on 100% of new sales. The saved lives figures were based on 100%
of the fleet having the system, which may get close about 2020 or later.
It still keeps it from completely spinning out of control, but looks much more precarious.
http://www.youtube.com/watch?v=iH6TuPIipMQ
Here is a very good extended video of stability control on a Jaguar X-Type.
http://www.youtube.com/watch?v=K3m24bjkfg0
The Jaguar did better at high speed on ice than the Tundra did at much lower speed on wet asphalt.
The pickup truck test looked like it may have been done on a synthetic ice surface (enables icy road testing in milder climates). Even so, both of the pickups slid around quite a bit!
http://www.mercurynews.com/business/ci_11407633?source=rss
http://cordis.europa.eu/ictresults/index.cfm/section/news/tpl/article/id/90364
Recent info on the migration to the system and studies on impact. 2012 MY
vehicles are still 2 1/2 years away. Interestingly they do mention that the
systems are different and that is expected since, as noted, Corvette drivers
want more leeway than other drivers
Randy
http://autospeed.com/cms/A_111046/article.html
Wonder how long it will take to get similar item in US?
Well since they have figured out how to retrofit truck trailers,
I would guess that someone will figure it out for the auto market:
http://www.todaystrucking.com/products.cfm?intDocID=21186
For anyone interested in the Mems market:
A few mentions of Yaw sensors,
http://www.eetimes.com/news/semi/showArticle.jhtml?articleID=213403733&pgno=3
Chips are becoming pervasive in car systems eh?
Ford's Testing of its Latest Safety Tech Involves a lot of Hot Air
