Visitor Agreement.
I used to see that all the time at my shop.
Sir or madam you spent 30,000 dollars on this car don't you want to protect your investment by putting the right oil in it and changing it at least every 5,000 or so miles?
When Ford and Honda went to 5w20 spec oil we didn't carry it in bulk initially because we weren't sure they would keep up with using that oil. We had it in bottles and since it was a little more expensive then regular bottled oil we charged 4 or 5 dollars more for an oil change with 5w20.
We had people all the time that didn't want to put the 5w20 in because a 25 dollar oil change became 30 dollars.
We had people that didn't want to change the oil in the interval recommended because it took too long to get an oil change. :mad: :surprise: On your regular mass market american or japanese sedan I could have someone in and out in less then 10 minutes. Actual 10 minutes from the time their car drove over the pit for oil changes till the time they were driving out of the parking lot. On some cars you could even do it faster. Toyota Carola that held less then 4 quarts of oil and had an easy to get to oil with no chassis lube points might take 5 minutes.
Seriously you can't spend 10 minutes if you come by during non-peak times? If you really don't have the time then spend twice as much for full synthetic and more then double your drain interval. No, no, no that was too much money.
Sheesh drove me crazy.
probably quite few engines left that could be salvaged.
Yesterday I put the LeMans's battery in, and it still wouldn't fire up. I don't know what made me think to do this, but I pulled the distributor cap off, pulled the rotor, blew on it, and rubbed my finger on the contact point. Put it back together, and it fired right up!
So was it maybe just some moisture in there? The cap and rotor are new. Well, less-than-a-year-old, new.
I've never had this problem with my other '79 though, the 5th Ave, which is identical. And if it is just moisture, what's the best way to deal with it? I don't like the idea of having to "pleasure" my car every time I want it to fire up! :P
Barring that, you might try some silicon spray on the cap and wires (are the wires old--say more than 30,000 miles old?) and you might consider a battery tender on the car to give you that little extra battery boost. I think you have the gear reduction starter, don't you? Those can get a bit "draggy".
I did get new wires for it, but for some reason never got around to putting them on. Procrastination, I guess.
I'll try the silicon spray and see if that helps. And yeah, it does have a gear reduction starter. What is a battery tender? Just a little charger?
My '73 Fiat 128 SL would need a new distributor cap and rotor every maybe 30,000 miles or so. I could tell when it was time to replace them because on some cold, damp morning the car would refuse to start. I would yank the cap, rotor, and plug wires and bake them in the oven for a half hour or so to dry them out. Then , the car would fire right up.
My theory is that the distributor cap or rotor would develop microscopic cracks that would allow moisture to collect, which would short out the spark.
Maybe it needed a distributor cap condom like those Mercedes Shifty mentioned.
Personally, I'd be tempted to just ditch the whole Lean burn system...distributor, carb, and all, and just go for the simple aftermarket Mopar Performance distributor setup. I'm not knowledgeable enough to do it myself though, and my mechanic said that it's so rare to find a car as nice and original as my '79 NYer, that he doesn't want to butcher it up like that. Personally I don't care how original it is, I just want the danged thing to start semi-reliably!
i'll bet they had them until they went to the 4.6 with cops.
Mustang
Mark VII
Ok... let's try this. Shoulda used this on the Mystery Car Pics thread.
arrrggg. pic too big. lemme resize, rehost, and repost.
And here is the ad copy. Price is $850:
1987 Nissan Maxima This Maxima is a one of a kind. Build by Erebuni Corp. in 1987 as a show car. This car was on the showroom floor in Queens, NY for a long time then abandon outside for a long time after that. The Title says 79,971 miles but the dash says 51,000 miles so I’m not sure which one is correct. This car was running about a month ago until the fuel pump broke. Now the car is located on my driveway. Body also needs work as you can tell from the pictures. Special Gotti deep dish wheels and tires included. New battery and exhaust. Car must be towed away. Please contact me if you have any further questions
Queens? Don't they have nuclear weapons?
Hadn't thought of it as a Lemons candidate, but now that you say it...
Heck, it even has excess protection for bumpin' and rubbin'.
-m
Only costs $64 to fix! Ok. Tell ya what, I'll give you $100 to fix it for me. You can make a profit!
Its not uncommon to hear of these engines going over 500,000 miles. Huh. Must be in some other car cause these bodies don't last 500k miles.
Hey stickguy! Weren't you looking for a FWD V70 2.5T? This seems like a good deal. Too good, actually.
"It is not uncommon to HEAR of these engines going 500,000 miles"
is what he says.
True enough. :P
99 Infiniti -- $64 to jack the car up maybe. Another $250 to fix the axle, presuming of course that that is what that horrible sound actually IS....
What is the seller on, something I haven't tried yet? I can safely tell anyone here that those B230F engines do need quite a lot of TLC just to keep running - constant timing belt changes, anyone? No, those bodies will not last over a half million miles - even though they were galvanized post-1986, they are still prone to rust. Those 240s have little nooks and crannies where gunk can accumulate and contribute to the tinworm. Shifty will probably attest to this too.
Nice pictures in that ad too! Had to go to the dealer web site to find some.
Looks like it needs a serious detail, probably tires soon too, so who knows what else.
Why does a dealer not even bother to vacuum or wipe down the interior before taking the pictures?
My favorite item though is it needs a headlight bulb replaced (it is, after all, a Volvo). They have a shot of the guages, where you can read the bulb failure message, plus a shot of the front end with the lights (er., light) on!
"Vehicle prices reflect fifteen hundred dollars owners loyalty discount. Five hundred dollars college graduate discount to qualifying customers.Must be financed through dealer"
oh, and their website also says its AWD. :confuse:
doesn't it look like the hose nozzle is set up to spray into the radiator opening in the 300 zx? :confuse:
Also several W110 fintails over 10K Euro.
asking that much money, could you at least move the trash bin?
price keeps dropping started out @9200
lots of info, some confusing. did these have an ECU?
hmm
if andre hits the lottery this would look good in his garage
69 Camaro -- LOL! "Awwww, why do I have to move the trash bin. I ALWAYS have to move the trash bin...."
Am I losing it faster than usual, or does anyone else rmember it this way... c'mon guys, a short 14 years ago...
-m
I liked that greenish-gray color. Came close to buying a '96 Roadhazzard in that same color about 4-5 years ago. Black is probably the color to have, but I prefer that green.j
I forget what production of them was over the three years, but in 1996, I remember they built about 100,000 total of the RWD B/D body. Of that, around 40,000 was the Impala SS, leaving the Caprice, Roadmaster, and Fleetwood to scrap for the remaining 60K.
Can't say as I remember the "Lord Vader, your car is ready" as it pertains to the Impala SS. However, for some reason, I remember it being used with the '81 Imperial! It wasn't a car advertisement, but I think one of the buff rags might have said it. Or a classic car rag.
The only thing it controlled was the electronic ignition. It wasn't like the later ECU's that were complete computer systems that would control a variety of functions, and were a pain in the butt when they started failing. GM started putting those things down in the passenger side kick panel of their cars starting in 1981. Not sure when Chrysler or the others did that.
Or at least it was originally.
Looks like they used it for Impala SS ads too.
link title
No wonder it was in a showroom for very long time...nobody wanted to buy it because it's so ugly. And then it was abandoned probably because nobody even wanted it for free.
But for $850 you get a piece of 80s car tuning history that nobody cares about anyways.
