Visitor Agreement.
I have posted a question asking for comments about use of the e815---so far no replies;hopefully I will hear about this phone soon because I need to replace my old cell
I suggest you contact your dealer for some feedback, I'm glad I did.
Steve
I could pair it with the TL OK, however, when a connection is made, the sound does not come through the car speakers. I kept repeating the process of clearing the TL's settings and re-pairing from scratch. After about 50 tries, I only managed to have the sound coming out of the car's speakers.
Does anyone know why? with Motorola 710, it is fine. With this PDA, I couldn't get the sound to come through. What I ended up doing is to use the PDA with my bluetooth headset. This allows me to dial while driving using voice dialing.. However, once the call is connected, I have to wear my bluetooth headset to talk and listen.
Any thoughts? Does any know if Acura has a software upgrade? -Tom
The PDA just doesn't seem to work with the TL audio system. The PDA does work with other cars that have Bluetooth phone support (like the Toyota Prius)..
Any thoughts?
Samsung i730 and Audiovox XV6600 are "currently testing".
Samsung a970 and PalmOne Treo 650 are "non-compatible".
There's a thread there on all the upgrades and patches available and a lot of other interesting reading
I got my 6600 to work, but its not great. Typically have to do a soft reset when getting back into the car which is a pain. Also, volume of voice through speakers is way out of line with volume of voice command feedback. The feedback (confirming number, etc.) is much louder.
Signal strength does not show correctly.
Took me a while to figure out how to load phone numbers into nav unit without getting veverticalars for the numbers, but one corrected, loaded all contacts at one time.
Good phone, good experience.
ps. vertical bar issue is that LS nav can't handle () in a phone number. Change region setting to estonia instead of US and contact manager will no longer auto format phone numbers. Will only load one number per contact, so I created a new contact category and put in just name and number for the ones I wanted to upload.
-Matrioux
Pairing between the Treo and Acura HFL was a breeze, and each time I enter the car the Treo is recognized.
The first call initiated from the Treo does not transfer to the Acura HFL, but subsequent calls are. I have formed the habit of making a 'priming' call to my office each time I get into the car. It takes me less than 10 seconds to make the call, and subsequent calls transfer to HFL.
If the first call was an inbound call, it has always transferred to the HFL.
The volume is adequate, but occasionaly I have to crank up on the volume dial. No one has yet complained of not hearing me well.
Neither the inbound or outbound numbers display on the NAV screen, unless the outgoing call is made from the HFL phonebook or the inbound number is in the phonebook..
Using the TL's phonebook is the best way to initiate frequently called numbers. Up to 50 numbers can be programmed with your own voice, and all relevant information is displayed on the screen when calling any number storeded in the phonebook.
Yes, the Treo 650 is approved, but not from Verizon for the RL. The only PDA is for this combination is the Blackberry 7250---which I ultimately changed to and it is a breeze.
Short of it---if you goto the website and get one of the phones listed, it will be a breeze and you will probably get all the functions listed properly (antenna and battery life on the dash) and it will pair without problem.
Please respond to jfallonedmunds.com by Wednesday, September 7, 2005 with your daytime contact info and a few words about your experience
MODERATOR /ADMINISTRATOR
Review your vehicle
Dumont
As the owner's manual says, one cannot dial out easily when the car is in motion. The last number called feature does work while in motion, but to call a number not already loaded into the car one key system one must use the key pad on the phone.
There is an after market kit to allow full phone function through the car Bluetooth screen while the car is in motion.
I got my new TL 05 non navi a few months back and synced by Sony Ericcson T610 without issue. Fido in Canada is my provider by the way.
Within the past few weeks the 'RM' indicator lights up on the console which indicates my phone is roaming yet it doesn't show so on the actual phone and it surely isn't roaming given I'm in the heart of my home town. Very odd. The consequence is that incoming phone numbers aren't displayed on the dash.
How can I get rid of this roaming??? Do you guys think it is my phone or a TL issue.
thx.
Rich
I know Acura is currently testing it
Tee.
Another challenge is the software the device utilizes. As we have seen patches have been developed to increase the compatibility of the cell/smartphones with other devices besides Bluetooth headsets... the Treo for example. It is my humble opinion that most companies did not anticipate the widespread integration of Bluetooth into passenger vehicles. They primarily created the software for Bluetooth headsets... not Bluetooth equipped vehicles. What is even funnier is that technology pundits were declaring Bluetooth dead since it's bandwidth is so small in comparison to other wireless technologies!
Lastly, the entire industry is in its infancy. The issues with compatibility will largely be gone in two years but new issues will emerge. I predict the proliferation of portable music devices (iPod, iRiver, etc) will be the next device that consumers will want to connect to their cars. A few years later consumers, after the service providers have removed their restrictions to the Object Push Profile (OPP), will want to link the in-car displays to the internet to surf the web with their all inclusive digital plans. The potential for Bluetooth is only limited to it's bandwidth and range.
I have set up pauses but they don't always work if the number of rings before the system picks up is not the same. I have also set up a separate phone book entry with the password and use the send command to input it, but the system will not let me do this quick enough as it wants to confirm what I have done before it lets me send the password.
Any suggestions would be appreciated.
Also, is there any way to use the RL's system to dial a speed dial number on my phone. I have another bluetooth car kit that will let me dial my phone by speed dial locations vs. the actual number. (i.e. I just say, "speed dial 1-2" to dial the number stored in speed dial location number 12 on my phone.)
Kris
ckk
Personally, I only use it as a hands-free phone in the M35x. It works very well.
Is this a Verizon issue or Acura?
Have you gotten the phone book to work thru the car?
I didn't get the phone book transferred until after I had paired the phone
and wonder if this is why I am having a problem with it.
Anyone else find a way to transfer phone books to their TL from the Motorola E815?
Works great while parked and sometimes during drive time...but I'm a little disappointed that the Bluetooth/Acura combo isn't a little tighter on the audio out side....I'm trying to figure out if it is a phone thing or a US Cellular problem right now...in the meantime, don't throw away your analog ear bud!
***Mooselook***
