Visitor Agreement.
the same issue with my new Motorola E915??
The problem I'm having is with 'sending' numbers during a call. I.e. putting in your code during voicemail etc. I followed the instructions, but everytime I do it, the phone call turns into a high pitched signal noise, and I have to turn off and turn back on my rzr before I can make another call with it. Anyone experience this?
Thaks
Steve.
Astrobuf :mad:
Steve.
Tom
Create a newm phone contact (name it voicemail, for example) and enter the numbers, like #27345 and save it.
Make the call to your primary number, and when it answers, press the send button and say "Call Voicemail"...the system will then send the additional numbers you stored.
Works great for me after a lot of trial and error
Does anybody else have this issue or know of any workarounds?
Anyone else have a Siemens SX66
The Sienna system though does work better with the phone, although it isnt perfect either.
In both cases, from all the phones I've tested, it is the Siemens phone which is the issue...I think it is compliant with Bluetooth, but has a terribly low/inconsistent signal.
Next time you make a call check the CD timer display
and make note of the time. When you end your call
it should pick up at the same time. If not have your unit checked because mine does not just mute the sound
it also pauses/stops the CD
GOOD LUCK and enjoy the great sound of DVD-A :shades:
It would be interesting if there is a difference since in both situations you're playing from a local disc.
Thanks for the info! (I rarely play audio cds).
Overall its a great feature, especially when receiving a call since the system automatically turns the radio volume down when your phone rings. I've missed calls in the past cause I couldn't hear my phone ring over the radio.
And XM is awesome BTW!
Please, does anyone have any advice on how to maintain the Bluetooth connection?? I of course would rather not have to buy a new phone. Thanks in advance.
Note: Sound quality from the car speaker isn't great. The phone numbers on the car screen go blank when the car is moving. However, pressing a blank (no-number showing) preset number does work (the number is called). There is a kit available to make all of the car screen functions visible and functional when the car is moving.
A friend suggested that my problems may exist because the 2006 Prius supports only version 1.1 of Bluetooth, whereas my phone might be v. 1.2. Any thoughts?
Trying to get an idea how well the A900 works in the TL. I currently have a treo 650 w/ the "patch" that works well despite not being on the approved list. Anyone currently have this setup? (A900/TL) Thanks.
Where can I find this kit?
Respectfully,
-Wes
Option: BlueTooth
Phones: Nokia N70 and Sony Ericsson p910a
Problem: Unable to register either phone
Does anyone know why these two perfectly good phones are unable to connect to the BlueTooth on our new 2006 Sienna? The RazrV3 works fine...
Much obliged
-Wes
and most nights I leave it sitting in the car( on ). The
phone is only a few months old so the battery is also
new. I only recharge about every 4 days. My old phone was about 18 months old and the battery only lasted about 1 day.
