Bluetooth Technology
Technically and FWIW, Verizon has only been around since 1996 when Bell Atlantic merged with GTE. In any case, I'd be miffed too!
I recently bought a2005 Buick Rainier - I really like the OnStar/verizon handsfree thing, but don't like having a separate phone number for the car (and would rather not pay Verizon anymore than I already have too)
I've been told they sell aftermarket Bluetooth adapters, but I was wondering if anyone could tell me if there are any Bluetooth units that take advantage of some of the OnStar equipment (microphone, radio connection, etc)
I like the way it works now, but I'd rather have caller ID and call-waiting...
Rick
The [Verizon phone] includes Get It Now, our virtual mall of games and productivity tools that customers can download. The agreements we have with our content providers preclude our allowing anyone to download these applications beyond the phone. The open architecture of Bluetooth could also allow customers to download Get It Now applications beyond the phone"
so to read between the lines - they are concerned about piracy of BREW games and ringtones. that's what this has all been about. keeping tight control over what is put on their handsets
See here for more details: http://www.burningdoor.com/steve/archives/000977.html
z
I was told by Nextel that I would be able to pair my Blackberry 7520 with the bluetooth system in my LS430. However, although the dialing and speakers in the car work... the mic does not. Hence, I can't use the handsfree at all!
Has anyone used a bluetooth blackberry successfully in the LS430?
If you haven't updated in the last month or so it might pay to stop by your local Verizon store.
Also check out
http://www.verizonwireless.com/pdfs/user_guides/CDMA_BT_OEM-Car-Kit-Support_022105-to-Web.- pdf
They have a lot of work to do.
I've spent two days between Verizon and the Lexus dealer with this stuff.
gblutas
Only complaint is I drive a Miata and the wind noise makes it hard to talk when the top is down.
Setup was a piece of cake. I know it's not integrated with the car, but I chuckled when I read the secret service comments above. I feel kind of "cell crazy" using it outside my car, though.
-juice
PS service is with T-Mobile
USING A PALM TUNGSTEN T
1. I own a Tungsten T. You may be able to get the same results with other Palm devices that use Bluetooth, or other PDA's that have Bluetooth.
2. I did download and install the latest Palm One bluetooth software. It was touted as having better connections and more phone support.
I converted my Motorola V710 phonebook to a text file. Now, I'm not savvy enough to know how you convert a WAB file or anything.....I actually typed a new text file with short names and phone numbers (having no dashes in the numbers).
At this point, there are several ways to load your text file to your Palm or other PDA. In order to move it, you should create a CATEGORY in Addressbook on your PDA. I named that category "Phonebook". Once your file is loaded into this Addressbook category, you are ready to go to the car.
Start the car, let it find the cellphone. Go to Telephone....Transfer File. It will say "Send phonebook from phone". On your PDA, opened to the "Phonebook" category in Addressb ook, select "Send Category". You will then have a choice to send by Bluetooth. Your PDA will then search for a bluetooth device, and hopefully will find it (as "HANDS FREE").
Check the box beside HANDS FREE. You will be shown a screen on your PDA to input the access code. The transfer should then begin. When complete, you will not see the transfer screen on the Prius. Open your Phonebook on the Prius and everything should be there.
If you have any questions about this particular procedure, please don't hesitate to email me at laverne@iname.com
On your Motorola V710, go to Settings
Then Go to Car Settings
The first feature under Car Settings is for "Auto Answer" If this feature is on then turn it off. This worked for me.
When a call comes in use the phone button on the steering to answer.
Thanks, --David
I want the AI option package but I think the Bluetooth only comes in the package with the Navigation system which adds 5000 to the cost!
Is the bluetooth available to add after car arrives at dealership? Sounds like a mess from the above posts although some don't know how they ever lived without it, whatever it is? Sounds like some sort of telephone but will have to check out links suggested on other posts.
Incidentally, Motorola doesn't make the Ojo videophone but signed a multi year exclusive marketing and distribution agreement with WorldGate WGAT a small company 32M float compared to MOT 2.4B float.
Thanks for whatever enlightening comments or thoughts you have in store for me.
Just got my beautiful 2005 Lexus RX330. Perfect car, I am in love. One problem: the Bluetooth system. I've matched up my Cingular Motorola perfectly, make calls, get calls, it all works... Only thing is that the people I speak with hardly hear me at all. I hear them perfectly. They complain that I sound faint and far away. I have confirmed this by calling my voicemail and then listening to the message I recorded from the car. I am really annoyed by this. It was a major reason I was so excited about my Nav system (which this came with). PLEASE help, any and all tips or tricks are appreciated. Thanks. :confuse:
I had that problem a while ago with a phone dock, and it turned out to be incredibly simple - the plug wasn't in all the way.
-juice
BT 1.2 is backward compatable with BT 1.1 or 1.0 phones but you dont get the improved signal.
Btw, isn't this a great way to get the word out to the CONSUMERS...I applaud Edmunds.com for creating such a site!!!
Thank you for visiting acura.com and for your inquiry regarding
HandsFreeLink compatible phones. You are correct, if your V710 has the new
software, which is 1.40.0 or greater, then you should be able to use it
with HandsFreeLink. Your local authorized Verizon dealer should be able to
perform the software upgrade for you if needed. Once we know the software
upgrade is available to all customers we will list the V710 with this
software as approved.
Please feel free to contact us with additional questions.
Sincerely,
HandsFreeLink Customer Service
-----Original Message-----
Sent: Monday, May 09, 2005 6:37 AM
To: HandsFreeLink Support
Subject: HandsFreeLink Web Support
This e-mail was auto-generated by the HandsFreeLink web site at 05/09/2005
09:36:55.
Vehicle Information:
2005 TL
Mobile Phone:
Motorola v710
Mobile Carrier:
Verizon
Reason for Contacting HFL Support:
Inquires - Compatible Cell Phones
User Comments:
The Acura HandsFreeLink web site indicates that the Motorola V710 cell phone
is not compatible w/ the HandsFreeLink but I checked Verizon and they said
that w/ the software version 1.40.0 installed on the Motorola V710 it is
compatible. I'd like to get confirmation from Acura what is supported
before I purchase the Motorola V710 cell phone. Thanks.
Looks like LG is releasing a bt 1.2 phone but only in Singapore for now. Strange thing is Motorolla headsets are now BT 1.2 but they have no phones to take advantage of the advance noise rejection and other features of BT1.2 ! if you use a BT 1.1 phone with a BT 1.0 car kit , the phone wil downgrade to 1.0! It sucks that Lexus hasnt updated their hardware to at LEAST 1.1 Bluetooth. unfortunately I dont think its a software update only.
However, with V551, you will have to send one contact at a time, not the entire phone book at once. It is pity.
Just wondering before I puchase the phone.
Charles
That's a bit oversimplified. The "technology" consists of the the microwave receiver and transmitter, signal generation, modulation/demodulation and communications software. As with all leading edge technology, standards are evolving and there will be incompatibilities between devices.
http://www.edmunds.com/advice/specialreports/articles/103685/article.html
I have Bluetooth on my iPAQ but haven't had occasion to try it out yet.
