Fat chance of that!
Read my post. I said, I don't know what-- if any-- safety limitations there would be.
I don't have degrees in chemistry and physics. Maybe you do. I do know that those fix-a-flat cans are covered with warnings, including "Do Not Store In Temperatures Above 120 Degrees." (Ever opened the door of a parked car in Arizona?). They contain flammable, pressurized gas and sealant, and some contain butane propane as the propellant.
Did you read my post #353? You didn't seem to find the energy to respond to that one....
I've carried fix-a flat cans for years including hot Northern California areas and I've never had a can explode nor have I ever had the use for the stuff. I haven't had a flat since I was in college driving junkers.
As far as your Post 353. I have LOTS of energy. I just don't try to represent Honda in these forums. I have no idea why they chose to not include a spare.
Maybe if enough people feel as you do they will change this.
Here's my question: Is 2WD performance with really good tires almost as good as AWD with RFTs? ("Performance" for me is traction under slick conditions and not much else; I drive like the geezer I am.)
It seems to me one sort of NEEDS the AWD for the RFTs because the tire itself has crummier traction. I've never had AWD and generally do OK with 2WD even in the winter here in Chicago, with my Savana van. I want AWD only for winter performance and not for off-roading. I don't live off the beaten track so I'm not looking for serious AWD performance. I am much too lazy to keep a set of winter tires. Besides which our winters are not very bad despite the whining about them. It's just those few times I'd really like to get to and from work when it's blustery.
So far I've pretty much refused to buy because of the RFT issue. Dumb of Honda to make their PAX so proprietary; dumb of Toyota to skip the spare and offer tires with poor traction and tread wear. Even dumber of Toyota not to make the rear seat well large enough to accommodate a full-size RFT spare, with a removable rear seat. I'd happily take out the left rear seat and carry a spare. But even then I'd only buy AWD if the overall traction advantages are large compared to FWD with excellent tires.
Sheesh.
I believe, and have quite a bit of road time now proving out my opinion, that 2WD with really good tires is BETTER than AWD with average tires. That's why I won't consider the AWD Sienna or the PAX Odyssey. In particular, the PAX tires do not appear to be a good winter choice.
My recent vehicle list includes a '97 Subaru Outback (AWD), '01 Sienna (FWD w/o traction or stability control), and a '03 Saturn VUE (AWD). I'm in Minnesota, and have to drive on low maintenance roads to see one relative that is in a remote area "up north".
Guess which vehicle is the best in winter conditions? The Sienna! Reason - I run it with Nokian tires that have awesome grip on ice and snow. The VUE with the stock Duelers slides around quite a bit before the AWD kicks in. The Outback when new was quite good with the stock Michelins. After about 3 years of aging, these tires lost significant grip even though the tread depth was still fine. New "all-season" tires made a big improvement, but the Outback still did not perform as well as my FWD Sienna with Nokians. The Outback with Nokians would have been the best combination for sure, though I didn't keep that vehicle so I never tried that.
Here's the deal - AWD does not help you stop. Really good tires gives you a traction advantage in all conditions. AWD helps when you have to go up an incline from a dead stop. In my opinion, that is the primary advantage of AWD. (yes, there are performance benefits, but that is secondary to the traction question in my opinion).
I'm not scared off by the replacement aspect of run flats, I'm just staying away specifically due to the poor winter capabilities. Those are well documented on "other sites".
Now there are people running the AWD Sienna with non-RFT snow tires. This would be a great combination, as long as you have a viable back up plan if you get a flat. I'll let others trail blaze this combination before I jump into that setup.
My guess is that the AWD/no spare/RFT/no tire life/etc issue will really start to play out over the following model year as early adopters from '04 start hitting those issues en masse. My first instinct was to opt for AWD and RFTs, switching to regular tires at the first necessity, and taking a full-size spare only on road trips, where I don't need the seats anyway (I don't travel with kids). Sorta pitiful considering it's a vehicle with 20 years of opportunity to get it right.
I'm gonna wait though. If the comment boards (here, and the tire boards) are even close to reality, the AWD Sienna is going to take an enormous hit for its used-car value (and that's been a historic strength for Toyota). The used care market is much more price and total cost of ownership sensitive, and they'll be disinclined to buy a car with thousands of extra dollars that need to be factored in over its lifetime, just for the tires.
The thing that's missing here is consideration of the used-car value. A guy who can spend 35k on a new car is only annoyed by a high tire cost. Heck, at the performance car level, it's silly to worry about cost of tires, or cost of car. However for a family sedan, being bought from a manufacturer known for longevity of vehicles and great retention of original value, this AWD/run flat thing is a disaster waiting for the used car market to price it down. AWD owners will take a double hit: first for their tire problems and second for their trade-in value.
When the used car market starts hitting Sienna AWD, I think Toyota will try to do something with a little more urgency.
As an aside, has there been any formal high-level comment by Toyota about all of this?
Well, 2WD with average tires would also be better than AWD with bald tires. But neither statement answers jetmd's question.
I run the OEM run-flats in the summer, and Bridgestone Blizzak RFT's in the winter. I have always found the extra cost of the winter tires (on any vehicle) to be cheap insurance.
Having AWD doesn't eliminate the need to buy snow tires.
There is no perfect all-season tire solution for people unwilling to invest in a set of good winter tires.
I doubt very much that AWD Sienna resale values will suffer, especially considering it's currently the only AWD minivan game in town. Five years from now, it's only used competition will be itself.
I do not think there is much upfront disclosure of any of this by the sales folk. They should be saying, "Buy AWD only where you are willing to also buy winter tires, because only then, in snow/ice conditions, will you realize the value of AWD. You will have poor braking and treadwear performance for all other times, and you will never be able to carry a stowable spare."
The "beater" market will not be owning two sets of tires. They'll be having to decide if they want AWD at all since it brings no advantage without switching tires, costs more, performs worse, and makes them lug a spare around like a suitcase if they want to switch to regular tires. Its competition will be cars that cost less and perform as well.
AWD provides superior traction (with good tires, whether they're summer or winter) over 2WD in wet and rainy conditions, too. And here in the northeast, there are many more rainy days than snowy ones.
Winter tires are always better than all-seasons in snow or ice, whether the vehicle is 2WD or AWD.
AWD does bring advantages without switching tires. But even assuming I'm limited to one set of decent set of all-season tires, I'd still take AWD over 2WD in less than perfect driving conditions.
Time will tell if RFT's and PAX affect Siennas and Tourings in any measurable way. If I had to bet, I'd say Tourings will suffer more, as there's no AWD benefit to counter-balance the cost and limited availability of PAX.
Note that the current GM vans also offer AWD, and they don't require RFT's (at least as far as I can tell). Those tend to depreciate more than Toyota's do, so they could be stiff competition in the used market several years down the road. I for one like the current Sienna a whole lot more, but those more cost conscience will probably go after the cheaper alternative, with regular tires.
And, for tires you can keep on all year round that still offer a good blend of winter Vs summer performance, I like the Nokian WR's. I wouldn't use them in southern climates, but up north they are great for those of us too lazy to want to change out tires twice a year! And they have better winter ratings (considering ice and snow) then some dedicated snow tires do.
Unless you may be referring to some final-run GM Astro/Safari vans, but I wouldn't count 18-year-old designs.......
is there a reference somewhere that explains the benefits of AWD? sincerely i'd like to know because i've looked and didn't find anything truly helpful.
i can see how there would be an advantage to "getting going", but once going, i don't understand the benefits of AWD.
cost and performance of the AWD tire, lack of a spare, coupled with increased drivetrain complexity and any mileage hit, and the cost/benefit equation seems a bit tilted.
Opinions about the Dunlop tires on Tire Rack are very, very negative, and not just over tread wear.
That's really the nut of my question. Not whether AWD with "good" tires is better than 2WD with "good" tires.
I'm sure these have conventional tires w/spare, but they aren't really on my radar. Re-sale will be abysmal anyway, so tire cost won't be relevant.
The OEM Firestone Affinity tires on my 2003 FWD Sienna were like B.B.s on a greased sheet of glass in the rain. I replaced them less than a month after I bought the van new.
And wouldn't the benefit of traction control be double that of a FWD vehicle with TC?
Will be heading over to Honda, I guess; I was down to Honda and Sienna.
Will not buy PAX, but will look at the OEM tire, and might also consider seeing if the Toyota dealer will put my choice of OEMs on a new car...this same dealership just sold a friend an AWD and they are REALLY bummed about the tire issue. I told them to try the Toyota customer rep, but I'm hope the dealership will make good.
I am considering a Sienna AWD. This Run flat tire problems is making me think twice about this minivan. Any help?
A quick check of the TireRack website turned up only one run-flat option for the 330xi (205/50/VR17 Goodyear Eagle RS-A's)-- and that was only for cars equipped with the Sport Package. 'On special' for $199 each, they have only mediocre reviews for tread life and hydro resistance.
For the AWD Sienna, the TireRack lists only Dunlop and Bridgestone as run-flat options.
In either case, 'just switching the brand of tire' is more easily said than done.
Bottom line - if I have a flat anywhere I normally drive I can get home or to a Honda store for repairs. Perhaps twice a year when traveling long distance I take a chance on getting stranded for a day.
I just don't see where the relatively marginal value of the upgrades of a Touring (vs. a loaded EX-L) are worth the hassle of PAX-- especially when (unlike the Sienna) there's no added value of AWD.
At the risk of 'repeating myself constantly,' I maintain that if Honda offered a power lift gate and memory seats on EX-L's, they wouldn't sell any Tourings at all....
If so, is there a place to put a donut spare beside the seat well?
Can the FWD be ordered with 17" tires that are not runflat?
Thanx for any help...
There is one person here who takes every opportunity to knock them over and over and over.
It's so rare to have tire troubles anymore it probably wouldn't affect you. PAX tires are new on the market and availability for the time being is limited should you need a replacement. This situation is improving with time.My prediction is for increase usage of PAX tires on other makes and models.
I could be wrong on this but Honda is a smart company and they don't leap into things without looking first.
The biggest advantage is the ability to drive with a flat. I think the immense safety aspect of this has been shouted down by a couple of others who only seem to see the bad. Get a flat on a rain slicked freeway at night while in traffic or in a bad neighborhood, you'll be very glad you have these on your car.
I would go back, read the 385 or so messages on this subject and decide for yourself if the good doesn't outweigh the bad.
Yes. Non-runflat tires are available in the same size as the OEM runflats and can be mounted on the 17" wheels. In fact, the 17" rims on the Sienna AWD are the SAME 17" rims as on the Sienna FWD models.
"..is there a place to put a donut spare beside the seat well? "
I've heard that Toyota sells a kit(?) which will allow the owner to mount a donut spare within the seat well behind the 3rd row. Two things - first, you obviously lose the ability to drop the seat into the well. Second, it is possible that a flat full-size tire/rim assembly won't fit in the seat well. I know that a fully INFLATED full-size spare will not fit in the well but I don't know about a full size flat.
"Can the FWD be ordered with 17" tires that are not runflat?"
Yes. The XLE Ltd. (FWD) comes standard with 17" rims and non-RF tires. Any of the FWD XLE packages which include the traction/skid control will also include 17" rims and non-RF tires. I don't know if the LE models equipped with traction/skid control include the 17" rims or the 16" rims.
Toyota does sell the kit, including the compact spare tire and it fits and looks like it belongs in the well. The cover is very lightweight plastic but it's reinforced and covered with carpeting which matches the van. I got the kit and wheel at dealer cost (total about $285) but I ordered the tire from Tire Rack ($175 incl shipping) because it was $50 cheaper than Toyota's cost from their distributer. Including $110 or so for installation the grand total was about $600. It looks great and I don't use the well behind the seats except on a very infrequent basis so it's not a problem for me.
An inflated full sized tire DOES fit in the well although it has to be placed in with the edge closest the rear bumper first and then PUSHED into place. It is VERY snug. I've seen pictures of it in place on another forum so I know it can work.
You are correct about the kit not fitting over a full sized spare. The kit consists of a light box that completely covers the compact spare. I tried it with a full sized spare and although the box fits around the spare (there is less than an inch diameter difference between the compact spare and a full sized spare) the box is over an inch too shallow to properly cover the much wider tire. In short, the kit ONLY works with the compact spare.
I've opted to keep the run flats. My wife works in a marginal neighborhood and I like the idea of her being able to "limp" home rather than waiting for the AAA. I also found a "take off" set of new Bridgestone B-380s that I got for a song on eBay so I'm well set for dealing with the run flat "premature wear" and astronomical cost issues. However, I do plan to run Blizzaks in the winter. The run flats are only a "B" traction tire at best and even a great "all weather" tire can't come close to matching a true snow tire.
If it does, I'm buying the AWD with regular tires and living with the fact I can't fold down the left third row seat. I'll have a full-size spare and probably at some point jury-rig a cover for it from the OEM kit. Pitiful, but I want this car.
Here's a suggestion for Toyota: Widen the well to fit a full-size 17" spare. Make a cover that fits even if it sticks up a bit, or deepen the well a couple of inches. Now make the left third seat removable, for goodness sake; it doesn't have to fold down.
Easy to criticize after the fact, I guess...
Seems to defeat the purpose of AWD. You get AWD but tires w/ crummy traction, so you need the AWD just to get back to FWD performance. I'd like to see tests of AWD with the OEM tires (esp the Dunlops) versus FWD with OEM regular tires. Or even better, AWD with the best runflats v FWD with the best non-run-flats. Snow and ice conditions, but also rain and puddles, which are just as important. I'd hate to have AWD and poor tires for that rare time I need AWD, but have bad traction in (very common) rain conditions.
Also, since emergency stopping is way more common than AWD conditions I'd like to see AWD runflats compared to FWD fregular tires for stopping. It seems a poor logic to get runflats for the "safety" of running flat if the stopping ability is impaired, doesn't it? I get flats much less often than I have to stop quickly.
What I HAVE doubted is the potential success of the PAX version of the run-flat concept, because it's handicapped by proprietary technology and the minuscule number of vehicles that require them.
So why does anyone buy a Touring? For PAX? Doubtful....
While I think most will agree that PAX is superior to self-supporting in terms of ride quality, but it will be a big knock against them if different manufacturers try to make their own proprietary versions, just for $$$. In the end the consumers lose due to higher costs, and reduced replacement options with the proprietary designs.
Check out the following for more details on the types of run flat tires available:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=56
Presence of PAX was a major factor in choosing Touring over other trims for us. After changing a flat on our 2002 MPV I realized that there's no way I could expect my wife to ever change it herself.
Recently, my wife had a flat tire in her BMW and I decided to change the set of tires. I was trying to buy another sets of these tires from Bridgestone and Uniroyal, they discontinued the self sealing tires. I have read several bad comments on run flat tires. I think she is stocked with the regular tires and will just try to avoid the nails.
For people who are short like me, the power tailgate and memory seats, and power adjustable pedals are a definite draw. I prefer cloth seats over leather, so if these features had been available on the next lower model, I probably would have bought it instead. ( I didn't get NAV and RES).
I got a response from Connor at Tire Rack about my PAX problem - although it still doesn't explain why I had such a problem getting my PAX assembly replaced.
You may want to read it yourself - it's posting #870 on the "Ask Connor at The Tire Rack" forum. Based on his response, I should not have had a problem. My flat should have been covered under the road hazard warranty because it was caused by a piece of metal I picked on up on the interstate - the flat was not caused by rubbing a curb.
He also says that Tire Rack returns all assemblies to Michelin.
As things stand today, I plan to stay with the Run Flats and use Blizzak Run Flats for the winter. Since the key for snow/ice traction seems to be the tire material rather than a tire's internal construction, I'm assuming that the Blizzak rating for the RFTs will be at least close to that of the non-RFT Blizzaks. Again, without someone running a real world test on RFTs vs. non-RFTs on the same vans, (Consumer's Union, are you listening?) it's impossible to know if there is a significant performance penalty for RFT snows. :confuse:
I would never buy a vehicle with RFTs again!
I'm now considering the Ody Touring and the Sienna FWD Limited. When I asked the Honda salesperson whether the PAX tires could be plugged, he said that they could, provided no other damage to the core, tread, etc. was present. Is this true? I've looked through this thread for that very topic, and haven't found it addressed here.
Having already dealt with so many flats, I like the idea of the RFT systems, and being able to deal with a flat a little more to my convienence than with a conventional tire. However, I'm apprehensive about the RFT's in general, and especially about the "proprietary" PAX system on the Honda because of availability (or lack thereof) and the cost. But, if the tires can indeed be repaired (plugged) after a simple puncture, then that helps, IMO.
I think I was trying to say that in the case of the Sienna these issues are inseparable, since RFTs are the only choice with AWD. Therefore if RFT performance is poor, AWD adds much less (or nothing) to total performance. If RFT performance is really poor, buying AWD may actually degrade performance since the requisite RFTs are so bad.
Many a consumer has ponied up the extra bucks for AWD. I want some proof that they are better off than if they had FWD and regular tires. I'm especially, but not exclusively, concerned about braking and wet weather since those two conditions crop up much more commonly than ice and snow and steep hills (for most drivers).
