I really like that chin spoiler and the rocker-panel fairings, too. Those are also Ixion, right?
Cedric
The first time the issue came up, it was winter time and I thought the cable just got brittle and snapped. I took it in to get fixed and they must've done it wrong because it was harder to open the hood. Well, after a few months, I tried opening the hood and something popped. The release lever just flopped loosely and upon inspection, the metal that surrounds the barrel at the end of the cable had broken. To open the hood, I grasped the end of the cable with a pair of pliers and pulled and the hood would open.
Anyway, getting it fixed the 2nd time (at a different dealership) proved to be the answer. Not only did they fix it, the hood seemed to release much easier like it did when the car was new.
Good luck!
Mike
I just wanted to say thanks for you responding back to my post. I will try that and see will it open up.
Take care,
Ironsapper.
Mike
I'm on my 2nd inflatable lumbar support for the driver's side seat back....Have you had any problems?? Both under warranty.
1) Is this a symptom not of the suspension components, but of an insufficiently stiff body structure allowing reverberations where the components join it?
2) If the bushings are at fault, is it because they're so excessively soft that they allow slack or bottoming? Would stiffer urethane bushings fix it? It's interesting to note that Hyundai's press release on its effort to fix this in '08 said they actually went to softer bushings than previously. This would seem to indicate that Hyundai doesn't agree.
Would a stiffer bushing actually be the answer? I would think stiffer would allow more vibration through to surrounding surfaces, whereas a softer one would absorb more. I would think it was the case since the clunk doesn't seem to be an issue with the '08 Azeras.
IF...the bushings were the culprit, I would think it would be easy to retro-fit all '06-07 Azeras with the same bushings used in the '08 models.
Again, please don't take my posting as saying the suspension isn't at fault here, but the experience I have had with the '09 Sonata I'm driving right now really gave me some time to hear it and think of other possibilities of what could be the problem.
On another note, now I'm worried that I could possibly hear the clunking noise as I was informed that they are replacing the strut/shock that was causing the noise. I really, really hope they're replacing it with the same model and that everything goes back to how it was before the creaking noise started. We shall see!!!
I bought my 07 Azzy in Nov 07. I was aware of the noise issue before I bought it. I haven't heard any noises in my car in about 18k miles. I drive over our wretched potholed roads here in Houston. Other than tire noise, I haven't heard anything. I am very very sensitive to noise & if it was a prominent noise, I would have noticed it.
Could someone explain to me how it sounds? Sometimes when I drive over rough roads, I turn off the radio just to hear any noises coming from the suspension & haven't found any.
The clunk I'm hearing in the Sonata sounds like (as one poster put it) a few golf balls in a big box. It doesn't have a metal on metal sound at all, it's more of a muted thud and it just seems to come from underneath the car. With the windows rolled down, you hear nothing at all outside the car other than the tires across the pavement. Inside the car, whenever you traverse a patch of uneven pavement, you hear the "clunk" and it seems to be in concert with how the car travels over the uneven road.
There's another issue, it's not heard in all the vehicles. I own an '06 Azera and I haven't heard the noise I hear in the '09 Sonata or any other clunk noise described by anyone else that seems to have the issue. Up until my recent creaking noise, my suspension has been fine.
Honestly, if you've driven over rough roads and you don't hear any sounds that alert you or make you feel uneasy about your car...I wouldn't even worry about it. You just happen to be one of the lucky ones (as the ones with the problem would put it).
What do you think about the cpu used in the genesis 3.8 to install in the Azera 3.8 to up the hp??? Don't know enough about the genesis engine internals as to capability and those of the azera to handle the genesis cpu....your thoughts..
101649
You have presented a very, very interesting idea. I guess you would need to do a little research to find out exactly what the differences are between the 3.8's found in the Azera and the Genesis. If all it takes is a CPU change to benefit from the added horsepower and keep the fuel ecomony the same...that would be a major boost.
Problem found to be dust covers on the shocks that are free floating thus causing the rumbling and clunk.
Dust covers secured by screwing to frame and they still do the job as intended.
Car now quieter than when delivered.
Dealer has sent a notice to Hyundai Canada of the fix.
What did you drop on the A6 you just bought??? $24-$27large??
I would sure like to try your "fix" on my ' :confuse: 06 Azera.
I'd researched the car pretty well and was not suprised to have this problem, the hairline crack forming over the passenger airbag, or any of the other quirks I'm experiencing. The two that I was not prepared for, though were the creak and the lumbar adjustment not working. The lumbar makes a noise when trying to retract, but nothing seems to happen when I try to increase support. I'll try to tinker and determine if it's a switch issue before having it serviced.
Thanks for all the good info... overall I'm a happy Azzy owner so far, but will make the final determination when I found out how the local dealerships handle the issues.
The hairline crack on your dash, that should be taken care of by the dealer with no problem. It's a documented issue with the Azera and your car is still under the factory warranty.
I realize this is a bit off-topic for this thread but didn't see another to put it in and figured I had at least one person paying attention in this thread: Another issue I'm noticing is fading and cracking along the rain gutter strip/molding. I've got the silver paint on an 06. Is this a known issue? I've searched the forums and the google-net and not come up with much.
The 10% is the max Ethanol in the worst case scenario, the actual blend would differ from refiner to refiner, day it was blended & price of Ethanol that day. Suffice to say that if you are close to Corn country, your Ethanol concentration would be close to the max 10%. If you are close to the refineries & gulf, your blend tends to have lower Ethanol. Unfortunately there's no way of telling.
Ethanol mandate is an immoral & harmful scam pulled on America by these corn states. To appease to the Corn mafia, our Engines are being harmed & environment harmed.
Honestly, I think our pockets and our engines are suffering more than the environment. It is claimed that ethanol is supposed to make the fuel burn off more completely, thus creating less harmful emission from the tail pipe. Like you, I believe it is a huge scam.
I'm led to believe with the decline of my fuel economy, that the stations here in the DC metro area are putting the full 10% in their fuels and it reeks!!! :sick:
Ethanol is not clean. The energy taken to create Ethanol would offset many times the (supposedly) clean burning of Ethanol.
If you look at some of Hyundai's service bulletins, there's one which says that if the Ethanol blend is more than 10%, the warranty is void. (Search in hmaservice.com in the Fuel section)
And now the mafia wants to mandate 15-20%!!
Are Americans really that stupid that they can't see a scam when they see one?? (Sorry, I'm very angry about Ethanol as I consider it to be immoral)
On a good note, I found a local BP station that doesn't have any "ethanol" stickers on their pumps. So, I filled up and I have noticed a bump up in my fuel economy.
10% ethanol murders fuel economy, 15-20% would simply obliterate it.
I fond some led strip lights that would make great halo lights for the Azera..They're 14 inches long and are flexible ....The only problem I have is that I can't get inside the headlight assembly...The light strips are flexible with a peel off backing....they come in red,blue and white ....I don't really want to install them on the outside of the headlight assembly...I'll let you know if I figure anything out...BTW, did you get everything taken care of on your '06 @ the dealer??? the forum has been quite lately...
I know about those LED strips you are talking about, only problem is...you will need more than the adhesive backing to keep them in place. If you want something that will be more durable and stay in place...KAI has something that works perfectly...
Azera Headlight LED Module
As far as getting inside the headlight housing, you have to take the whole housing out and bake it in an oven at like 250 degrees for a few minutes to soften the adhesive sealant. Here's a link to a tutorial that will show you exactly what to do:
Baking Headlight Open Tutorial
Thanks, but no thanks.......that's too much work I don't want to screw up the housing.....
Proximity to corn country no longer determines the amount of ethanol. I live in S.C. and a railroad and private oil company have formed a partnership to bring in up to 200 railroad tank cars of ethanol each week. It comes from Iowa right now. They are parked next to a major tank farm for several gas companies. The ethanol is added to the tank trucks as they leave to reach the "up to 10%" level.
Plans are to build holding tanks for ethanol and to "import" more.
I'm sure other locations in the nation have similar facilities. In fact, I believe this particular oil company was choosing between SC and New England when the railroad stepped forward to become a partner.
Google Greenville and Western Railroad or Lincoln Oil in Greenville SC for more information, but it is from their biased viewpoint.
And now the Ethanol mafia is plotting to raise the limit to 15 to 20%. And as usual, the public would be fleeced for the benefit of the few well-heeled mafia corporations.
Your congress & govt folks. The best form of government that money can buy. Dems or Repubs, they're all the same.
can i splice into the parking light harness and use a jumper to hook up the driving lights so they will be on with the parking lights....as you know, they only come on with the headlights
i guess if i did, i would have to keep the driving light switch in the off mode to keep from sending too much current to the bulbs when the headlights are on...your thoughts....
