Visitor Agreement.
If you are contemplating doing this, you need to get the factory (not Haynes) service manual for both cars (yours and the engine donor). If you are serious, you should do the research on how to do it and not ask a bunch of flakey internet people.
Any help would be great. :confuse:
What engine could fit a 94 toyota tercel
email me if you can thanks
duffy89@mchsi.com
Any help would be appreciate.
If you want to go all out and get a better suspension and brakes, along with the engine upgrade, find yourself a V-spec to trade for.
It will save you money now AND give you better resale value down the road.
sorry i don't have any info for you... simply because i plan on doing the same thing to my frontier when i get the money for it!
could you please let me know how it works/worked out for you? or if you've already received info on cost, time, kits, etc.. that would be much appreciated, too.
thanks! any info you have would be great...
-rommel
Greddy Turbo 10lbs (designed for 95 eclipse) $2,500.00
4G63 Re-built engine $1,800.00
Greddy Intercooler w/ pipes $650.00
Injen Cold Air Intake $200.00
There is more depending on what amount of horses your trying to run(my eclipse is going from GS---To GSX so I have to buy the upgrades + the Turbo ECU and Turbo Injectors and ect.)
If anyone has any advice for me ....I’m wanting to drop a turbo engine under $8000 .I was thinking of putting the 4g63 GSX Eclipse engine with a Greddy turbo? I’ve heard that the 4g63 engine swap will not last? That might be false information but I’m wanting to know if that would be the best fit and if not what could I put instead? I’m trying to hit 550Hp or + Any suggestions or advice would be great! Thanx
Suggestions and input appreciated.
Bryan
fdiggar,
VW doesn't want you messing with the tranny so they sealed them ! Only to be done by Stealerships or the like. Your better off letting them do it anyway. For 35 bucks call it money well spent, its a bit difficult for DIY'S with no lift. And you can get your motor-oil changed while your there. :shades:
Hope this helps u!,
DeFn1EaR---
Assuming you have a jetta/golf.
The VR was a good engine. I have a friend who tuned one to over 700hp and ran tens, but also consider the aspirated 1.8 Liter turbo 20 valve VW powerplant. With both motors having about the same availability and cost depending who you talk too & where you shop. Its lighter and you get almost the same horses as the 6. And they seem to be plentiful right now!
The driver and weight dispersment inevitably make the difference in this case, The hp ratio is so close.
Theres also now (if found) on the 2005s + 06s the 2.0 liter turbo on newer VWs. 200 hp stock. Then you can upgrade that. Cost will be a matter of luck and searching, but be ready to spend some ca$h. I have heard it all, from one buddy getting a vr6 for 200$ bucks to a $2500-$3500 crate 1.8 L motor. Another guy got a 20 Valve to get rid of the car for the owner. People wreck and destroy cars everyday even if there brand new. Do your homework & maybe you'll luck out on a donor.
Hope this helps,
DefN1EaR
And most importantly Have lots of Fun.
i have just a need to do this. :shades:
If when moving,
What attention did you pay to driveshaft balancing?
If at idle--which flywheel did you use?
When the engine was on the dyno, did you have accessories hooked up, with belts driven, etc...?
We had everything on the engine when it was on the dyno. We have removed everything as a test in the car and still have the vibration.
My next step is swapping the flywheel and the orgque converter but I feel like I am shooting in the dark. Don't mind doing the work but I don't want to do something that is not needed.
Thanks for any advice that you have
This might include different fan, different accessories, different flywheel, torque converter, whatever.
I'd say mucho homework before you even turn a wrench. if you have to fabricate a bell housing, well....good luck...
In theory, you can put any engine in any car, but time and money and skill are required in abundance.
Think it out first before you jump in. You might have to cruise the INternet to see if anyone has gone before you into this dark night.
The vibration is there when the transmission is in park or when it is in gear, under load and NOT under load. We even took off front "moving parts" except the harmonic balancer and still had the SAME vibration.
As far as I can tell, the only things that are moving now that were not on the dyno are the flywheel, the torque converter and the front transmission pumb.
One more thing, there are no signs of transmission or seal failure.
Again, thanks for your assistance.
