You did, by quite a bit
I bet Lemko would like to beat whomever designed that car! :P From the old period reviews I've read, those shrunken Sevilles were much better in most respects than the bustlebacks they replaced. Handling and performance was much improved, and I think they were finally getting the kinks worked out of the 4.1. And later years they moved to the larger 4.5 and 4.9. But they just lacked presence. Compared to the FWD Continental that debuted around the same time, these Caddies just looked too diminutive. And the Continental was no great shakes itself, being derived from the Taurus.
I've never much cared for Caddies, but that one, in STS guise, was very restrained & flab-free for its time.
The 4.1 may have been junky, but somehow the aluminum block amplified the cool V8 growl.
That is after the redesign. Probably a '77 or so.
Looks like it's barely postwar.
Is it German? :confuse:
The length of the Seville was basically unchanged from 1986 through 1991 but the Eldorado was modified slighly for the 1989 model year.
But Cadillac really didn't do anything with the Eldorado/Seville until the 1992 redesign. I wonder if the reason was because that '92 redesign was just around the corner? Or, perhaps the 1992 model just showed up ahead of schedule, because the '86 era style was bombing so badly?
I imagine one of those final 1991 models, which I think had the 4.9 V-8 by then, would have been a pretty good performer. If not that exciting to look at. I wonder if anyone ever thought to put one of those 4.5/4.9's in an older Bustleback Seville?
The "bustleback" Seville and the third-generation model had different styles of front-wheel drive setups. The 2nd generation model was a longitudinal FWD while the 3rd (and 4th and 5th) generation was a transverse FWD setup. The 4.5L and 4.9L engines were never placed in cars longitudinally. I don't know if all of the necessary parts from the longitudinal 4.1 would make the transition possible...or if the effort would be worth it. Couldn't you just get the same or more power out of a 368cid Cadillac or 350cid gas Oldsmobile engine?
That's a pretty 2-tone green combination.
Yeah, you probably could. I think the 4.9 aluminum V-8 was coaxed up to 200 hp, while the 368 only had 140-150 depending on year, and the Olds 350 was around 160 hp in 1980. However, the 1979 version used in the Eldorado was around 170 hp I think, while the earlier fuel-injected one in the 1975-79 Sevilles was 180. I'm sure it wouldn't take much to build up one of those engines to meet or exceed the 4.9's output, though. And with the larger displacement, they were probably torquier from the get-go.
IIRC, the 425 and even the Caddy 500 were the same external size as a 368. So one of those could feasibly fit, I guess.
My guess is that the big Cadillac engine or the small Oldsmobile engine would be much easier (and cheaper) to build up than the small Cadillac engine, even if you were to start with the 200hp versions. I'd think that there are many more go-fast parts for the former engines rather than the latter.
Andre, you are a phenomenon, I can barely tell thre model yearson those, let alone the model.
Yep it's a '55 Chrysler New Yorker (Hemi).
You win that hand, it's a '69 Volvo 164. I'm surprised to see anything European wearing whitewalls that late in the game.
Yes indeed, that styling faux pas is a 1963 Ford Zephyr 4 MkII.
-Brian
