Mystery car pix
14674684704724731479
  • fintailfintail Member Posts: 58,879
    Lancia Gamma, late 70s
  • andys120andys120 Member Posts: 23,689
    Yup, it's actually a 1980 Lancia Gamma Coupe.
  • stephen987stephen987 Member Posts: 1,994
    Bristol 405?
    Yup, it's a Bristol 405,'53-'58. I think it's the last to use the Bristol/BMW six.
    Later cars used MoPar V8 power.
  • wgraferwgrafer Member Posts: 592
    Looks like a 1977 or 1978 Lincoln Versailles (I think the grill says '78). This was
    Ford's answer to GM's tendancy to upscale and charge for luxury (like the dressed
    up Cavalier known as the Cimmaron). In this case Ford 'upscaled' the Granada into both a Mercury Monarch and this strange looker.
    Close, it's an '80 Lincoln Versailles.
    ...have in common?>
    Little besides the name--Ford Fiesta.
    As for the Versailles, it was not an answer to the Cimarron (which was not introduced till 1982). It was instead an (inadequate) response, based on the US market Ford Granada, to the success of Cadillac's Nova-based 1976 Seville.
    The Versailles does have one feature of note, however--it was the first US automobile to use a basecoat/clearcoat paint process.
    Yup, the one with the Minilite wheels is a circa '78 Cologne-built Ford Fiesta Mk. I ('76-'83). The green car is the Ford of Europe-designed (Mexican-built) 2010 Fiesta. I sat in one recently and it appears to be a high quality car (which I don't think I'd say about the '78)
    Both are also FWD compacts, right?
    Keep in mind you have to judge by (very) different standards for 1976.
  • cooterbfdcooterbfd Member Posts: 2,770
    '78-82 Century.
    '78-82 Century
    Yup, although from that angle it could just as easily be a Cutlass Salon which tells you why GM eventually went bust. They forgot there's supposed to be a difference.
    Yeah, the wraparound taillights and slightly sloped nose are the only cues that this is the Buick version. Not enough differentiation.
    Wasn't that style actually dropped after MY 1980?
    I think the four door fastback only lasted thru '79, and the "formal" sedan (which looked like a cheaped-out Seville) replaced it.
  • michaellnomichaellno Member Posts: 4,120
    Ford Fairmont wagon .. no idea what year ... '79?
  • texasestexases Member Posts: 11,210
    Those single headlights were from '78 to '80. I remember the first Fairmont review in C&D, they thought it was just the greatest thing, with advanced lightweight construction, etc. Judging by how few I see still on the road (as in 0), maybe a bit too 'lightweight'. :sick:
    Andre, is that a 1979 New Yorker/Fifth Avenue next to the 1980 Lincoln Versailles? Looks like the same color as your ride.
    They had to make the Squaremont light enough to be powered by the Pinto four-cylinder as a base powerplant. It wasn't that bad with a manual transmission (the four-cylinder four-speed would outrun the six-cylinder three speed), but with an automatic it was bloody hopeless. Ford rigged the throttle linkage on both the four and the six to make them seem quicker--the six with automatic (driver's ed car for me in SC) seemed to leap off the line even though it probably wouldn't crack 14 seconds 0-60.
    With the 302 V8, on the other hand. . . actually it was still pretty lame, as the primitive emission controls choked it down to about 130 hp. Still, what a sleeper you could built out of a Fairmont Squire wagon with a modern crate motor. . .
    I believe Car & Driver built a "Boss Wagon" using a Fairmont as the starter vehicle.
  • stickguystickguy Member Posts: 54,323
    a friend had a 4 cyl AT 4 door. Not fast, but it got us around. Different expectations in those days I guess!
    I think that is the fox platform, right? So it was essentially a sedan version of the Mustang of that time (which also came with the anemic 4 cyl base engine way back when).
    SO, a nicely worked 302 with a 4 speed, and some bolt on brake and suspension tweaks from the mustang catalogue, and you could have quite the performance family sedan bargain!
    Hmm, light weight, RWD, roomy but compact performance sedan/wagon. Dang, wish they built that now! Sounds like (and frankly, would probably perform like) a 3 series from the mid-late 80s.
    I would reply to some of the messages, but the darned right side is covering up the right hand text - including the "reply" button.
    I had a '78 with the 302. I drove it in Germany during my tour there, and it kept up with the natives quite well. If you've driven there you know what that means...
    It was a good car, it lasted 13 years before the rust got to it.
    Put the number of the next message after the one with the wide picture into the GoToMessage box: #23858. Then the wide picture is skipped and you have the individual messages with their "reply" button!
    Did you do the engine swap? That would be fast. Later Fairmonts could be had with a 302, but not a HO.
  • bhill2bhill2 Member Posts: 2,639
    Man, that works like magic. Thanks. Now I will be able to read the 15 or so messages that always follow the picture in the displayed screen.
    >magic. Thanks.
    Thank you. Glad it worked for you this time.
    "Did you do the engine swap? That would be fast. Later Fairmonts could be had with a 302, but not a HO."
    No, it was stock. I think you mean quick, the Fairmont would do around 100 MPH.
    Easy, that's a Honda Nissan Toyota Dodge ... err, VW?
    Looks like a rebadged Ford Explorer SportTrac.
    Whatever it is, don't build it.
  • vchengvcheng Member Posts: 1,284
    I thought an Amorak was a type of hoodie. :D
    VW must have made a typo and substituted an M for the N and transposed a couple of vowels. Someone in the ad agency probably dropped the whiteboard when they were coming up with names.
    Parka that Amorak right here.
    Yet another silly name from VW. Touareg, Tiguan, Phaeton, what next? The Steauped?
    Yup, it's the Argentine-built '10 VW Amorak, a full frame Pickup; for some reason no US sales are planned.
    Are they nuts? :sick: :confuse: Even I would consider one if offered with a a diesel and DSG and I don't like picky-ups.
  • whitey9whitey9 Member Posts: 138
    As I understoood, some years ago ( 2? ), the new Bus AND the ground-up p/u were both nixed. I heard Porsche lost some $9B. Weren't they in talks to buy VW? This looks like a bold misstep.
    Maybe VW could risk a small diesel pickup (the old ones they once sold here are still much beloved), but anything else in the truck line for the USA would be, IMO, hari-kari.
    VW does not enjoy a reputation for...ahem...toughness....
    How many times during the last several decades have we seen the supposed VW ressurection only to see their crap quality and customer indifference sink their fleeting gains? Personally, I don't trust their product durability and reliability any more than Chrysler. I also don't understand this continuing worship of German engineering when VW, Audi, BMW and Mercedes all have lots of overpriced product with seemingly disportionate black dot ratings.
    If you drove a German product you might understand it a little. I'm not going to tell you a VW, Mercedes or any other German product will deliver appliance-like reliability but I'm of the opinion that, properly maintained (i.e. by the book), they will deliver good service and a superior driving experience. I like to tell people they can't understand how good German cars are until they drive one that's flipped the nines on the odo.
    My '00 BMW 528iA runs better at 121K miles than my MIL's '00 LeSabre at 42K miles (both have been maintained by the book).
    Don't tar all German cars with the same brush either, a number of different BMW, Audi, and even VW models are on CR's "recommended" list for 2009. Mercedes is not doing so well.
    1864 Dodge Polara 500. Nice.
    '65 Dodge Polara?
    A lot better looking than the emergency fix 63 and the bigger 65. The 64 coupe had that unique roofline. I liked the 65/66 Coronet better though.
    I like the little doggie dish hubcaps. What a far cry from today's 22" bling.
    Actually it is a 1964 Dodge Polara, the 1864s weren't very fast.;)
    The little old lady from Pasadena
    Go granny, go granny, go granny go
    Has a pretty little flower bed of white gardenias
    But parked in her rickety old garage
    Is a brand new shiny red Super Stock Dodge
    My typing is TERRIBLE...
    "AND EVERYBODY SAID THERE WAS NOBODY MEANER
    THAN THE LITTLE OLD LADY FROM PASADENA..."
