Mystery car pix
14724734754774781477
    Ah, one of my favorite MGs of the T series.
  • fintailfintail Member Posts: 58,763
    MGTF - 1954-5 or so. In front of it looks like a ca. 1965 Falcon.
    Fin, you're right on both counts, the photo was taken in '69 shortly after the photog bought the TF for $400. The caption explains that back then the TFs were especially cheap because many buyers preferred the classically upright styling of the MG-TC or the greater speed and handling of the MG-A.
    The TF has always been my personal favorite of those postwar MGs.
    TFs have a little more room for normal-size people, but yes, the smaller wheels are regrettable. TFs (later series) also had a larger engine than the TCs, a 1500, and looked a lot better than the dumpy TDs. A 1500 TF can just about match a TC on value right now, and I predict will surpass it as the years roll on.
    We have a winner. The Crew was a dedicated taxi model (hence the ungainly proportions) from that ruinous period in the '90s when Nissan thought it should do everything Toyota did. The RWD inline 6 layout lends itself nicely to GT-R transplants. :shades:
    If you guess the right year and the identity of the man in the picture>
  • stephen987stephen987 Member Posts: 1,994
    It's a 1961 Pontiac Tempest, and considering the size of the front tires, I sure hope it's the four-cylinder version. As for the guy next to it--hmm, is it Jim Wangers by any chance?
    Gee look at the price on the windshield. No wonder it didn't sell. :shades:
    Yep, it's a '61 Tempest. No it's not Jim Wangers. Hint: it's the guy who transnformed Pontiac from a dowdy old "Auntie" car to the dominant wide-track/split grille hot rod of the '60s. ;)
    Well, definitely a Holden, a panel truck based on the Ute, but as for the model name and year, I haven't a clue.
  • lostwrench1lostwrench1 Member Posts: 1,165
    Semon Knudsen?
  • texasestexases Member Posts: 11,177
    aka 'Bunkie'
  • rcinmdrcinmd Member Posts: 139
    The hint made me think immediately of Bunkie Knudson.
    We had a '62 Tempest wagon. Though not a split grille, I preferred it over the '61.
    Not exactly what it seems. It has a long drawn out name. Andre1969 will probably guess what it is in a New York second and tell us what is different about it.
    Some sort of Canadian Plodge?
    No, not a "Plodge."
    Yes indeed that's Bunkie Knudsen, the guy who put Pontiac on the map. He's not as well known as DeLorean or Wangers but he should be.
  • wgraferwgrafer Member Posts: 592
    Looks like a 1958 Chrysler Windsor. I think they called the 4-door hardtop a Newport :confuse:
    That's basically the Australian equivalent of the '70s surfer/party van, Holden Jackaroo or something.
    Yes, you both got the make but not quite the model --- it's a Holden Kingswood, which I think is a name also used in the USA for a station wagon.
    1958 1/2 Chrysler Windsor Dartline.
    Wolseley 1500?
    Correct! A Dodge chassis was now used under the 1958 Windsor's sheet metal. The car had typical Chrysler styling motifs, with the major change being that the front end sheet metal was capped-off with a chrome eyebrow running from side-to-side above the headlamps. The 1958 style grille was adapted to the Dodge-like front end. Side trim on the standard offering was a single molding, at mid-level, running horizontally from the rear to just aft of the front wheelhouse opening. In the spring, a Dartline package was introduced, which added some flair to the Windsor's styling. The Dartline package was an addition to the hardtop line. Besides additional trim on the front fender and a metal insert, this option included bright sill moldings, special roof trim and three slim moldings on each side of the rear deck license plate housing.
    Nope, not a Wolseley but you're in the right country at least.
    That is a Singer Hunter circa 1954/6 - and I think it is registered in New Zealand
    yes! A 1956 Singer Hunter, pleasingly patinated.
    USS Nimitz in drydock? :P
    No I think it's a small island atoll in the Pacific, but I can't recall the name. :P
    Looks like a 1973 Buick Centurion convertible.
    Yup, the other suggestions are understandable. ;)
    I actually think that would be a pretty cool car, in its own way.
    I could fit the entire boy scout troop in the back of that think for parade day! :D
    or play shuffleboard on the trunk lid!
    VW Quantum (a/k/a Passat wagon in Europe, a/k/a Santana in many other spots)?
    Yup, that's a VW Quantum Syncro ca. 1980s, AKA Passat/Santana/Carat/Corsair/B2.
    '70 Mustang Boss 302, with styling by Larry Shinoda.
    my my little mustang, how you've GROWN these past 5 years! :P
    Yup.
  • jwilliams2jwilliams2 Member Posts: 910
    1960 Chevy wagon, maybe a Nomad??
    I'll try the 1960 Chevy Kingswood.
    ...it looks quite plain to be a Kingswood. I'd say it's either a 1960 Chevrolet Parkwood or Brookwood.
    Looks like a definite 1960 Chevrolet Brookwood - no chrome strip=Brookwood.
    Brookwood it is, Lemko.
    This photo was taken in 1970. I recognize the stripped car in the foreground, do you?
    I don't quite recognize the little red sedan, is it a Mazda Luce? There's the back of a '65-''66ish Dodge Dart to the right and I think the car facing the red sedan is a late 50's Ambassador but something tells me it could be a Plymouth ca. early '60s.
    Whaddya think?
