Mystery car pix
189909294951478
  • yoribe2yoribe2 Member Posts: 65
    the doomed Renault Safrane
  • navigator89navigator89 Member Posts: 1,080
    Sorry andy, Renault Laguna is wrong.
    yoribe gets it, it's a Renault Safrane. Why exactly was it doomed, could you explain?
  • Just noticed this thread... very entertaining :-)
    But I'm clueless about how to attach a file in here.
  • andys120andys120 Member Posts: 23,686
    Attach images by using the "Img" button at the bottom of the box for new posts. Simply copy the URL for the image you want, hit Img, paste the URL after
    "img src=" and close using the "Close All" button..
    Then post and you're in business.
  • acura_el2000acura_el2000 Member Posts: 19
    ooo i know, thats one of those fortune city cars right?
    I can't view the picture.
    Apologies, can you see this?
    Yes I can see it. Is it a 1970's Pontiac?
    Nope, not a Pontiac. Most '70s Ponchos had split front grillework.
  • subearusubearu Member Posts: 3,613
    Buick Skylark, probably '69 or '70
    -Brian
    Right, it's a '70 Skylark.
  • fintailfintail Member Posts: 58,818
    I can see it
    The cars beside it are Renaults, so I will guess it is a Renault too...late 50s
    I was gonna guess Olds 442, only the base model instead of the big engined one.
    Were they clones?
    -juice
    IIRC, the '70 442 had a 455ci V8 with something north of 350 hp, probably close to 500 lb/ft torque. I don't recall the Skylark having a 455ci V8 option, but I could be wrong.
    Other than that, GM did share that body amongst itself.
    -Brian
    The Buick Skylark and the Olds Cutlass shared the B-body platform in 1970 but they were not clones since GM Divisions had their own powertrains prior to the mid 70s.
    The Buick analog of the 442 was the Buick Gran Sport.
    Merecedes-Benz 350SL ca. mid 1970s. I'll leave it to Fintail to tell you it's a W--- ;)
    That's the non-US version with Euro style headlights, optional hardtop and Bundt Alloy wheels.
    Looks like a '65 or so Chevelle. That color doesn't look the greatest in that background.
    -Brian
    It's a '66, Brian.
    Um, where is the handle for the back door?
  • gsemikegsemike Member Posts: 2,457
    When you can't find a clean 2 door, what do you do? Weld the back door shut for an instant coupe!! I've seen that done a few times and never understood it. It's the silhouette that makes the 2 door sportier, so what do you get for the functionality that you give up?
    I remember seeing that treatment on an otherwise well executed 70 SS clone. I always thought that if you're going to get the SS hood, badges and stripes, you've got to make the effort to find a 2 door.
    According to the ad, the rear door handle was "shaved" in order to make the car resemble a two-door. It doesn't make any sense on a four-oor with the B-pillar and framed windows. :confuse:
    4658 is a W(R)107, of indeterminate model and year. I can tell its a UK spec car, but as the car changed hardly at all up til 86, and was made til 89, it's really impossible to narrow it down. If the wheels are stock, it's no older than the late 70s...I'll guess ca.early 80s, but as it is Euro it is likely a 280SL, as those are more common there I think. Could also be a 500SL or the more often seen 450SL if it is older.
    The Chevelle "2 door" is kind of lame, when you can see the rear door outline.
    Could you be any more specific? ;)
    -juice
    Is that an AC something or other?
    -juice
    Good guess, Juice. No doubt you are thinking of the similar and contemporaneous AC 428 with the Frua Spider body that was originally intended as a replacement for the Cobra>>
    Sorry that's not it :) Anybody else?
    Close it's really a 280SL, from the UK.
    Shoot, I should've remembered the 280SL, unknown in the USA after about '73 but much more common in Europe than it's V8 counterparts.
    on #4688 which has been up for over 24 hours. None of you figured out that it's an Intermeccanica Italia ca.
    1967.
    Intermeccanica of Turin was founded in the 60s by Frank Reisner a Canadian of Hungarian origin. His Italia and Torino were based on the TVR Griffith chassis and powered by Ford 302 V8s. You can't get much more international than that.
    Sounds very high for a car that was re-painted, without the right wheels, and with a replacement top. It's a driver, but not collectible.
    What do you think, Shifty?
    -juice
    Just a guess ... '57 Chevy?
    -juice
    It's a 58. The one in the pic is a 4 door, but I think that the 2 doors are really under rated cars. I loved the white one in American Grafitti.
    I'll guess that 58 is a Bel Air
    The Impala like the one in American Grafitti has quite a folllwing I think
    Mike is right it's a '58 Chevy Biscayne. I personally detest the '58s which have none of the nice lines that made the '55 thru '57 Chevies so attractive. IMO the '58 looks like a bloated version of the Tri-Chevies but I'll grant you that it's a bunch better looking than the '59s and 60s.
    The '58 Impala was a milestone car in that it combined the power of the Chevy small block with the amenities available on the full on luxury cars. IMO it was a significant step in the dismantling of the Sloan hierarchy of brands.
    The headlight clusters on the '58 Chevy were said to be inspired by the podded jet engines on the B-47 Stratojet.
  • firemanjackfiremanjack Member Posts: 123
    '58 Chevy Delray 4 door sedan..V-8..
    Hmmm good one..The big motor that year was the 348, I believe.
    Somewhere around a 68 Caddy..super long wheelbase, bulletproof, big runflat tired thing..
    That's Ronnie and Nancy's ride, I believe
    Caddy of course
    Caddy of course.
    Yep, it's the Reagan Presidential Limo, a 1984 Cadillac.
    Square headlights on a 68????
  • kyfdxkyfdx Moderator Posts: 271,858
    280C.. I'm going to guess '74... Euro model..
    You're probably right...its a Euro 230 or a 250 or a 280. I'll guess its in Switzerland based on the scenery.
    It's a 1973 250C, which was the most common variant here IIRC.
