New Sierra/Silverado 2500 & 3500
Yeah, I know all about engines getting loaded up, like a boat motor after trolling for long periods. For some reason I never thought about that being a problem with a car/truck. Probably because I never do leave a vehicle idling for long periods. Just wondering if there was something about big-rig diesels that made truckers want to leave them idling, and if the same would be fine for pickup diesels.
The PTO sounds neat though. Just that little bit higher RPM and load keeps the engine happy. Anyone have an idea how the cost of generators set to run off PTO compare to a typical independent Honda or other type? Who's the best manufacturer?
Ford will still offer a sub 6.0 engine...aka the 5.4.
Gm Only offered the 5.3 in a 2500 in 2WD....
- Tim
God help us all
- Tim
The Bottom (The part you sit on) folds forward then the back folds down..
PTO... GM asked Muncie and Chelsea to design complete PTO packages for the HDs.. GM did the right thing on this application without a doubt.. They also have a ONE step operation to turn on the PTO.. no levers to pull and handles to mess with, just a simple Factory mounted knob on the dash that adjusts engine Rpm from a set point to set point....
Steve
Have a Good Weekend.......I'm going hunting...
Good luck
- Tim
Good Luck & have a good one.....
I have 4 more weeks until I drop off radar with my German Shorthair and English Setter into the high desert after chukar, quail, and pheasant. I don't know if my wife will hear the "I want my new truck!" more or less from October 7 through January 31 because of chukar season. On the one hand, I will have something to put a smile on my face and take my mind off my truck order. On the other hand, I will be thinking how neat it would be to take off for the field in my new truck.
Be safe out there!
Oregon Upland Birds:
Dove- Sept 1-31
Grouse (& mountain quail??)- Sept. 1 - Dec. 31
Chukar, Huns, & Quail- Oct. 7 - Jan. 31
Pheasant- Oct. 14 - Dec. 10??
eaborg,
You from Nevada? Doesn't Nevada open a week earlier? I know Idaho opens before Oregon. I might get down south of Denio, Nevada during/after the Oregon opener for one day. This is going to be an epic season! Perfect nesting conditions.
I will admit that those mileage figures are a bit lower than I was expecting, but that was ONE test by one reviewer on NEW trucks. Certainly not 20% better than the 6.5L TD, as reported. We'll see what happens with more tests, and more miles on the engines. Still comparable to the Cummins/Powerstroke MPG while having more output, and beats the snot out of any gas engine.
I really don't get it reactions by SOME Cummins/Powerstroke people. After I get my Duramax, if the Powerstroke or Cummins advances and has better power/economy figures than the Duramax, I will be the first to say how great it is. Even if Dodge found a new automatic (either the Allison or the "Brut"?), and they can unleash the full power of the current Cummins, I will be raving about how great that rig is. It doesn't make the Duramax any less of an engine.
Sorry..
I also will add, the same combination as above with a 10,000 pond trailer in tow, Which would have a GCW of 17,000 TT tested it at 0-60 27.3 sec.. 40-70 pulling same load was 19.3 seconds..
They did a short test on a 2001 6 Speed Quad Cab 4x4 Cummins ISB 3.54 gear..
0-60 was 11.5 seconds..
1/4 mile was 18.6 sec@75 Mph..
Now back to the 2500HD and 3500s!!!..
- Tim
Dean
Find it!
- Tim
You can either download and save or play it from it's location...
http://uscom.com/~hoot/cars/duramax/psd_lost.mov
have fun!!
...BTW....I still can't get enough of that sound the Dodge makes as it stalls out!
LOL
Thanks again Oby
- Tim
Dean
LOL
- Tim
P>S you still haven't expalined why the GM in that tug of war never lost traction once, but it's compettitors did?
The Cummins is a great diesel engine, but the new Duramax appears to be downright better. Period. It hasn't yet proven its durability, but hey that takes time. GM is introducing a completely new Diesel engine and of course it is better than anything out there - there is not much point in bringing it out otherwise.
Dodge will put a new diesel in the 2003 HD Ram and I guarantee you now that it will have better hp, torque and fuel economy numbers than anything else out there - it may be an MB, it may be a Detroit Diesel or it may be a Cummins.
Until then the Duramax is the best performer out there - and I might just buy it over the 8.1 V8. This is a good thing, it is called progress and ultimately we all win.
in the video the GM even has less weight with a reg,cab...
whatever you wanna see....so be it...
I really don't care as I will never have need for a diesel....but like it knowing GM is at least in the race again...
are the Cummins and PS obsolete?....no....they just have more to worry about now...
(boob boob oob boo boo booo oobbb ooooo)
...that's the sound the Dodge makes as it stalls out!
...I can't get enough of that Video
- Tim
Cummins - 2 minutes 5 seconds at 48 mph top speed
Powerstroke - 1 minute, 53 seconds at 52 mph top speed
Duramax/Allison - 1 minute, 25 seconds at 60 mph top speed.
Note the Chevy was also ballasted with an additional 500# of sand bags in the bed, so that the GCWR of all 3 rigs would be EQUAL.
The article goes on to say they expected the Duramax with the 6 speed manual would be even FASTER!
I think its a no brainer as to who now has the ultimate towing monster!
quicktime is a must.....maybe windows media player?
- Tim
what did you buy?
the 2500 has been great for me....22K miles in 13 months and not a problem....
I'll be getting a 2002 HD LT .....just don't know if it'll be 6.0 or 8.1/Allison?....I really don't need the Allison.....we will see....they have a Burb with an 8.1...I may drive it soon?....
Then there is Crew cab VS Ext.cab....I have to see which has more floor space...
- Tim
Dean
- Tim
Ryan
On the new Vortect engines, they are designed to run at higher rpms than the older style motors, so don't worry about running over 3000 rpm. If you look back at some of your old Trailer Life mags, you'll see tests in there of both the 5.3 and 6.0 liter engines running well over 3500 rpm up long uphill grades.
I haven't received my current Trailer Life yet - looking forward to reading the article on the 8.1 and Duramax.
