-June 2024 Special Lease Deals-
Toyota Pickup (pre-Tacoma) issues
when the truck hits 2000 rpm it bogs right down till 400rpm then it hits like a power band.
I replaced TPS,spark plugs, spark plug wires, fuel filter. NOT sure what else to do?????
Anyone had this problem please HELP!!!!
Thanks cos289
I found a DEXON ATF but there are Dexon III, Dexon 2 and others...Does is make any difference?
And is it true that transmission fluid is used to fill the power steering fluid?
OALOHA :surprise:
I just got this 84 toyota pickup, turn signals don't work. I can hear the relay click but no light, unfortunately my Chiltons manual is useless, it explains the flasher is behind the instrument panel, now I have the panel all torn apart and no flasher, the only part in circuit I can find is, flasher/ relay below the fuse box.
Is there a fuse for the signals/hazard lights if so where.
i have a 1990 toyota pickup and i think the automatic transmissions is going bad. the truck has 164K miles and to the best of my knowledge the original trans. is this when they start going out? and how much does it cost to get a new trans?
Sincerely,
Chris H.
Im wondering if I take it in when the light isnt on if they can find what's wrong???? Any suggestions.
Thanks, Mark
COS289
HELP COS289
I kick on the a/c and it becomes two squeals.
I have had to lube the pulleys for the last few months when it would rain. That little bit of lube would work fine, but now it squeals loud all the time.
If anyone has had a similar problem that they were able to fix I would like to know. It just isn't right that my truck sounds like a POS.
Cheers.
Cheers.
Trashed Hi-Lux
thank you
Any thoughts would be greatly appreciated. I don't want the Toyota dealership to look at it, as it's not worth that kind of cost if there's no error code.
