Visitor Agreement.
...You too Red!
- Tim
Ryan
left front right front
spec range spec range
camber -0.3d 0.8d -0.3d 08.d
caster 3.3d 5.3d 3.8d 5.8d
toe -0.05d 0.15d -0.05d 0.15d
(note: d = degrees)
further for anyone interested, here are the definitions and implications of each of those terms (according to gm):
camber - the inward or outward tilt of the wheel; function: reduces stress on steering and suspension parts, minimizes road shock, helps straight ahead stability, and maintains optimum tire life; implication: improper camber will cause excess tire wear on the edge. it will also cause pull or drift.
caster - the forward or rearward tilt of the steering axis versus vertical; function: provides steering stability, steering returnability, and cornering ease; implications: improper caster can cause pull, shimmy, excessive road shock and steering effort.
individual toe - the angle between the plan of rotation of one wheel and the vehicle centerline; function: static toe angles are required to position the wheels parallel when the vehicle is in motion; implications: improper toe can cause major tire wear and increased fuel consumption. a saw tooth wear pattern is typical on front tires; a diagonal wear pattern is typical on rear tires
makes a lot more sense if you can see the diagrams...but you get the idea.
bco
bco
TS123? I'll email the distributor with that info and see what turns up. Figure can't hurt. Will post when I get a response.
jed1894
Glad to see you put Ryan's repair technique to work and it also worked for you...LOL!! Question: Is it more effective to perform the procedure when you are pissed at the noise or not?
Tim
I thought about it in between beers a couple of weeks ago. Then forgot about it when I grabbed my next beer. Something about alcohol amnesia. Glad you reminded me as I'll try to take some as soon as the snow lets up. LOL!!
Dean
John
http://www.premiermotoring.net/cgi-bin/webc.exe/st_main.html?catid=147&sid=5iRDJe01bJyb8jW
odenmeyer
my truck goes in tomorrow for the updated windows. We will see what's up with that....
Dean
matthew
Mark
Mark
OK....we are gonna solve all Ado problems.....all 1500 owners......your truck will be bought back....crushed...and you will be given a 2500!
LOL
hehehhehehehe
- Tim
Well my truck goes under the knife tomorrow
I doubt anything is wrong but i am getting the trans reprogrammed.
Dean - that trans reprogram will change the shift points and overdrive???? Just gathering more info before tomorrow thanks
Ryan
Can someone tell me what I can expect to pay for something like this? What kind of discounting off of MSRP can I expect?
Thank you in advance.
and...where DO you guys look for tsb info?
bco
QUARTER WINDOWS - I have had mine open alot. As a matter of fact had em open all day yesterday. Never had a problem except when i opened to dry underneath where it leakes i popped the black latch off and the window was hanging there. Luckily it snapped back together easily.
Ryan
BCO - let me know if that link doesnt work
http://www.nhtsa.com/cars/problems/
your best sources for pricing are sites like:
www.carwizard.com or here on edmunds
i preferred carwizard because it allows you to "option out" your selected vehicle and get a print out with invoice and msrp for each individual option. you can take this to your dealer and say..."i will give you 3% over invoice" or "the dealer down the street is giving me $500 over invoice...here is invoice...what can you do?"
some have stated that they simply fax a copy of the vehicle and desired options with the invoice price to several dealerships and say, "i've faxed this to x,y, and z dealerships. best price gets my service..."
bco
Another source is Helm's same people who put out the manuals. They have a quarterly updates that you could buy for $25 a pop.
Most owners have defective quarter windows and just don't know it. That's good cause if everyone went to the dealer for the same item, we would have a national backorder of 10 years...LOL!! Just the fact that the hinges are made out of plastic means its defective. Kevlar maybe, plastic hinge on a vehicle...no way!! I still wonder what moron was responsible for that design as its about as crappy as I ever seen. All you got to do is lean with one hand on the windows and watch those plastic hinges buckle. Now just imagine if you pushed on it....think it'll create an air leak...?
Dean
It has been very intermittent, sometimes months (or never) between occurences.
That puts it into the "Its normal - don't worry about it" category.
Mike L
Marl
When I had questioned about hearing road noise from my passenger door, the dealer had sent my truck to an autobody shop to see if it was the weatherstripping or misalignment on the door. Well turns out that it's the door and the hinges are welded making it almost impossible to align. Another way that GM saves money is on the bolts. Just that you can't adjust them doors. I know that the old C/K had the same problem and that GM had a TSB to replace the welds with bolts. They just haven't had a TSB for the 'rado as of yet. Maybe not enough people complaining.
Will post part number as will see the dealer in an hour or so...can't wait to get into that '00 Dodge Ram that is waiting for me....yeah right!
Dean
Ryan
what's up with moUlding, dean? huh??? LOL!!!
oden...i looked for the molding too. not sure what you're referring to. 'course, mine's an early '00 model (built 14 jan 00).
bco
After looking at my drivers side door, I'm sure it's out of alignment and from what you've said, it would probably be hard to fix. I need a few more days in the shop to qualify for lemon law (30 days during the first year in California) but at the rate they're going, I shouldn't have any problems.
It's a shame, my previous PU was a '95 GMC Ext Cab 4X4 and I only had it in for warranty work one time which was just a minor issue. My '00 Ext Cab 4X4 was the first four door in my town and it appears GM logged a bunch of problems with this new design and made some necessary modifications which they implemented when they adopted the new Z-71 sticker. I have a few friends with the later '00 PU and they have zero problems. Shame on GM for trying to sneak this through.
Mark
Mark
John
Randy
It is not the rubber seals around the front windshield. That's been taken care of.
Mentioned it during service visits but they have been unable to find the culprit. Any ideas?
I currently just turn up the radio.
Randy
Odenmeyer
Just as a test try stuffing the vents in the rear of the cab with towels. 100% cotton of course and take it for a spin on the highway. It should help to pinpoint the noise. Man that road noise is annoying.
ryan
with my luck, the vette would probably vibrate too...LOL!!
Well I'm three hours late to the dealer and counting must have something to do with my moulding...Hehehe
Dean
Mark
Ryan
My $.02.
Hey guys, don't forget to check the air in that spare tire, mine was down to 30 psi (must have been summer air) heheheheh LOL!
John
TSB number: 00-o12-jed1894.........LOL
John
Ryan
1- '00 Grand Cherokee
2- '00 Sedan de Ville
3- '01 Dakota Quad Cab
So I picked the ugliest but newest vehicle. Took it down to pick up a load of chemicals. Loaded 1200#'s in the bed and was impressed by the power, ride, and handling of the Quad cab. I'm sure though it has nothing to do with its name...
The 4.7 hemi is impressive even with the 1200 #s in the bed. Hmmm...I wonder if it's going to be a problem doing all that hauling since the truck has only 108 miles on it?
Odenmeyer- Looks like I have to wait till tomorrow and hopefully I'll get the part number. The service advisor said that the tech was supposed to get back to him on the TSB, but like everything elso....he forgot. Will post as soon as I get my hands on 'em.
Dean
For those who are wondering what the fuss is about, it was wind noise at highway speed and it sounded as if the rear windows were slightly open (which I guess they were because of the air pressure on the poor latch). The new frame apparently directs air flow away and it works--so far.
Al
