Ford Explorer Sport Trac - IV
Dont need anything really in depth. Just tell me what you all think about it.
MrGhos
I love the versitility and comfort of the ST. I have the factory tonneau cover which turns the bed into a big trunk. With the cover off, I have been able to carry everything I ever needed to.
The dealer has been great to work with. Make sure you ask your dealer if they are "Blue Oval Certified". That means they have met certain levels of customer satisfaction as measured by JD Powers.
As for price, I'd recommend calling and asking for the fleet manager and see how much above invoice they are going for. Its an easy, no hassle way of getting a feel for the pricing.
good luck
An earlier posting (343) mentioned a loaded Sprt Track lease offer of $325/mo. with $1000 down. That sounds great. Any suggestions on how to get a deal like that would be appreciated.
I have had the tires balanced and front end aligned three times at the dealership. They do not know how to fix this.
I recall that there was a service notice on this problem but I cannot find it - any help would be greatly appreciated.
I've had an aweful customer support experience with Ford and the dealership... and the kids are driving me nuts!!!
I order the ford hitch for my st and let me tell you that look really good. I putted myself and took me 2 hours. I recommend getting some help when installing. Price $125.00.
Also, there is a lot more detailed info on the Sport Trac at http://www.mysporttrac.com/ than is on here.
Check it out.
The gas tank will hold 23 gallons; up from the previous 20.5 gallon tank.
A standard 16-inch cast aluminum wheel will replace the 15-inch wheel.
Also, the Sport Trac will have an electrochromic rear view mirror.
http://www.teamsporttrac.com
From what I've heard, it is a valve sticking, but I'm skeptical because this is a 1999 problem and I would think that the problem would have been solved on the SportTrac during manufacturing.
I'll look it up (I have a buddy that has all the ALLDATA records, and if I find the TSB, I'll post it.
