Check out the latest from the Edmunds Editorial Team
Have you recently used your tax refund (or are you planning on using your tax refund) toward the payment of a new or used vehicle? If so, a reporter would like to talk to you. Please reach out to [email protected] by Tuesday, March 19 and the Edmunds PR team may connect you with the journalist.
Ford Explorer Sport Trac - IV
1789101113»
  • silverstsilverst Posts: 1
    The shimmy you describe will not go away with the change of tires. Mine has had 5 sets since 9/00 when I purchased it. The dealer has added a noise/vibration dampener, lateral shocks because the rear end jumps to the side when you go over bumps, changed the drive shaft, replaced parts in the rear end, changed a wheel assembly, turned and then replaced front rotors. The vibration would disappear for 2 weeks and then start all over again. The Ford Tech came down several times and their fancy machine points to the tires everytime. Even with Michelin's it still does it and now am in the process of a buyback because they can't resolve the problem. It has 26k miles on it in 8 months and the problems have been going on since 3k. The dealership is not the problem--Ford is--they say I will pay for the mileage over 12k which is about $4K. I love the truck--just wish Ford would stand behind it.
  • My truck is still stalling after my 3rd visit to the dealer. This time he adjusted the TP to 1.01 volts (up from 0.96 volts). So I went back to the dealership today and test drove anotheer ST that had the 5 speed. It also stalled when I came to a turn with my foot off the gas and pushed in the clutch as I turned. Pushing in the clutch when the RPM's are still around 2K allows the engine to drop far below idle speed then the power steering seems to add just enough pull to kill the engine. I tried a similar menuvure with an automatic and guess what, it stalled also. The service manager has since confided in me that it is obvious to him there is a problem with the IAC programming in the V6 engine. He is waiting to hear back from Ford about a fix...
  • tractiontraction Posts: 141
    Check with the fleet manager for his best lease price. You can easily do it over the phone with any hassle.
    Also, there is a lot more detailed info on the Sport Trac at http://www.mysporttrac.com/ than is on here.
    The August 01 Consumer Reports compares the ST to the 4 doors from Toyota, Nissan Frontier, Chevy and Dodge. The ST was rated number 1 and got an overall rating of Very Good. They rated the STs emergency handling highly. The Dodge was not recommended because of poor showing in reliability. The Nissan and Chevy were rated in last place, the Toyota rated as having a "terrible ride"
  • What does everyone think of the power sunroof option?
    Saprtan.....Everyone from this board has left for the following site:
    Check it out.
  • My husband just bought a 2001 FWD Sport Trac. Does anyone know where we can purchase an aftermarket tonneau cover and if so, how much?
  • You can find most Sport Trac info at the following link. Its a great site with tons of info on the Sport Trac.
  • guigsguigs Posts: 3
    I'm thinking of buying a 2001 ST leftover MSRP is 28,010 have a quote of 25,000. Is that good or bad? What about the reliability of the ST, anybody have anything that will help in my decision. Mike in PA
  • There aren't that many differences. They are adding some new colors: Zinc Yellow Clearcoat, Silver Birch Clearcoat Metallic, True Blue Clearcoat Metallic and Aspen Green Clearcoat Metallic.
    The gas tank will hold 23 gallons; up from the previous 20.5 gallon tank.
    A standard 16-inch cast aluminum wheel will replace the 15-inch wheel.
    Also, the Sport Trac will have an electrochromic rear view mirror.
    http://www.teamsporttrac.com
  • Guys and Gals, my lease is coming up on my 99 Expedition (was $2000 down and $325/month) and am now looking to purchase a Explorer Sport Trak. I've seen many deals in the paper, but am curious as what is possible. Looks like $100 over invoice and great financing. Pls share with me your successes in negoitiating a great price.
  • I've experienced the same thing, but mine is a 2001 with 5 speed auto. I've heard there is a TSB on 1999 with the SOHC, but I haven't looked it up yet.
    From what I've heard, it is a valve sticking, but I'm skeptical because this is a 1999 problem and I would think that the problem would have been solved on the SportTrac during manufacturing.
    I'll look it up (I have a buddy that has all the ALLDATA records, and if I find the TSB, I'll post it.
  • No luck on finding a TSB or with the dealer service department. I guess that I'll keep driving it until it quits completely or fixes itself. It does seem like it ikles a bit low when cold, and a buddy that has another 2001 says his seems to idle low too. Anyone experienced this?
  • I read your two entries with reference to your sport trac stalling. Are you still having this problem? I see the last entry you made was in june so what was the final result? I too have had this problem with a 2002 sport trac, manual transmission!!!!!!!!!
  • I'm thinking about buying the Sport Trac. I live in Colorado, one of the questions I have is, how does it handle going up mountains. Can it hold a reasonable speed going up those mountains. Other than that are you happy with yours.
  • I want to keep the rear window vented (open about 2 inches at top) during rain. Anyone know where I can find something to mount above and across the top of the vent window to prevent rain from coming in? Maybe I missed it in mysporttrac.com Thank you.
1789101113»
