2000 Ford F-250 Super Duty Problems and Solutions
Here's a link to CNNs Ford FAQs: Fire FAQs
Here's a link to one of the many Ford fire stories on CNN: FloridaFordFire
Here's a link to Ford to check if your vehicle has been recalled (they're only recalling up to 2000 at the moment): Ford Recall
The Ford eng came and said the problem was the parking brake, it was replaced and lasted till I took a long drive about 100 miles, Ford eng is coming back, Meanwhile the BBB said they would like to have it resoved in 40 days.
All I can say is FORD LIES about their problems, They hope if they put you off enoughyou will go away...Sorry Ford not me.... :lemon: :lemon: :lemon: :lemon: :lemon:
Unfortunately, when I combine the posts here with first hand knowledge of the experiences of more than ten 'new F-150' owners, I have to say that I think there's something serious developing here.
Every owner of the 'new F-150' that I know personally, has a problem that's yet to be fixed. Virtually all have vibration problems, and a couple have transmission problems as well.
I'm so glad I didn't buy one (I wanted a 4X4 SuperCrew), and as a long time satisfied Ford owner that makes me sad.
I have exactly the same problem with my 98 F-150. Just like your problem, mine started on a cold morning of last winter. It started as an intermittent problem. It is now summer and this problem happens every time if I turn on the right turn signal fast. It seems to work ok if I turn it on slowly. Let me know if you found a solution to this problem.
My 2004 F-150 experienced a similar problem posed by lima1. As I was backing out of a parking space, I had to take the truck out of reverse and put it in drive to re-adjust... immediately after the truck was in drive and I let my foot off the brake, the truck surged forward. I tried one foot on the brake and then two, but the truck kept accelerating towards a chainlink fence and a busy 4-lane road. I was half way through the fence before I could put the truck in park to stop the motion.
The entire front of my truck now looks like the chainlink fence it ran through. Ford roadside assistance was helpful, but now the dealer is having a difficult time locating the problem (and believing the situation).
It appears that Explorers have had a few instances of this problem with injuries invlolved, and another website has a story where another 2004 F-150 rear-ended some one at a stop light due to this problem.
Can anyone else shed some light to this situation, especially in getting Ford to own up to their problem?
Any advice would be greatly appreciated.
I had the vehicle in for service twice and they were not able to fix the problem yet but now said they will order me 3 new tires and that the tires were probably the problem.
I will have the vehicle in for service on Monday, 6/27. Guess I will see if this fixes the problem. Other than this I love my truck, and I am hoping that the problem I am having isn't as bad as some are describing above.
Diablo_Dude mentions in passing "paying a premium for these trucks" which just isn't the case. A smaller Toyota with less power is going to cost 10K MORE up front than the F150 but have much more resale value. Speaking of resale, I'll bet that if you could identify the F150 wheelbase/body/drivetrain that is problematic, you could pick up a good deal on a used "04 w/0 that problem!
I'm pretty upset over this, as I have a '99 Ford Ranger that's been flawless (bought new and has 87k on it as of June 2005) and I LOVE its unbeatable comfortable interior and that of the '05 F-150. Damnit. Oh well. Not worth the unreliability risk.
The '05 or '06 RAM, TITAN and TUNDRA seem to be the three I'll be whittling it down to. Ram is coming out with a new XXXL crew cab around July or August 2005; I'll be test driving that one as well. PASS on the Chevy 1500. I tested one and the power, styling and interior doesn't seem to have been touched since what appears to be the late 1980s or early 1990s! The interior has the cheapest crap in it I've seen across the board. It's an insult to think the expect us to buy this thing when there are so many other trucks out there that trounce it in appearance and power. Seriously, pass on the Chevy 1500.
Too bad Mexico doesn't make a truck for the American market. Oh, wait...they do. Isn't it called a Ford?
--Mark in Seattle.
Having said that, I think that the Ford has far more features, more power, better ride, somewhat comparable mileage (these Tacos and Tundras are not great on gas, despite the image) and comparable dealer satisfaction as the Toyotas. (As the Toyota volume goes up their JD Power "satisfaction with dealer" ratings go down and now are comparable to Detroit.) The problem with Ford is reliabilty.
If you ever go through water that's as high as the floor of your truck bed, you need to change the differential fluid within a very few miles.
I am really starting to get frustrated. :mad:
I had 4 tires installed and it is still a problem. I have another appt at the dealer next week. This will be Apt #4.
Does Ford know they have this problem or are they attributing it to the road feel? For a $40,000 truck I don't want to feel the steering wheel move from side to side when I am cruising down a smooth road at 55 MPH or greater!
I think one or two people might have mentioned it to them. :shades:
http://www.intellidog.com/dieselmann/bulletin2.htm
then look for:
99/2000 F-series/Excursion, Gauges inop, flashing OD light, Fuse #19 Blown:
I have an 2001 F-150 supercrew, just turned 81k and this exact problem has arisen with me as well. It has only begun in the last 1k miles. I have to this point in trying to fix this:
replaced all of the spark plugs
checked all of the coils for spark
replaced the fuel filter
replaced the PCV valve
changed my fuel station
changed the oil, filter and air cleaner (this is normal maint on my part)
run a couple of bottles of injector cleaner thru it
I will next start exploring the fuel injection system, throttle body, Idle air control, etc.
Ford won't even look it for less than $100. They say they've never heard of this problem before. I am not going to give them anymore of my money as I've had many problems with this truck. I will go back to buying [non-permissible content removed] stuff from this point on . I gave them (american car makers) a chance and they blew it.
If I figure this out I'll post the solution, I'd appreciate the same from you.
Cheerz
Anything on this topic will be greatly appreciated
The randomness is the most confusing part.
I put "Lucas Transmission Fix" in, and it seemed to stop the slipping about 95% for 2 weeks. Then I took a 100 mile trip and it got really bad, slipping into "neutral" on the highway. I pulled off, shut her down, then drove home and it was fine again on the way home. Almost like it gets a good transmission "sync" sometimes, and other times it won't grab for nothing.?
I'm going to try more Lucas Fix, before I take it to a transmission shop. If the transmission fix is going to cost me more than $1,000 - I might just have to part this sucker out on Ebay! :confuse:
Thanks for any info, Runjim.
