Visitor Agreement.
Has anyone else heard of this problem?
I havent gone to the dealer yet, so I dont know what the problem is. Anyone elso got any info? :mad:
hope it helps
travel down the road, acts like engine dies, but engine is still running at an idle, hit gas pedal, no acceleration...shut key off, restart, truck acts normal, have replaced MAF sensor, TP sensor, possible transmission problems? Have checked fuel pressure, 35lbs. Not consistent, some days runs fine, others above problem occurs. Anybody else experiencing?
It is rather fortunate that pickup trucks retain good resale value. My suggestion to you is to give it one last try to force Ford to buy the truck back. If not, trade in on another brand pickup. You may do better than you think on trade.
I clean the air vains and the EGR valve this fixed the ploblem. PS do not run less than 91 Octane in ford V-8 engines. This clogs up the EGR valve.
Thanks in advance for any help
Mark
This did not correct anything but I decided to give the dealership the benefit of the doubt and test out the fixes. I understand that I am too close to the problem and could me extremely critical and mistake the vibration for the way the truck was driving.
After a few weeks the vibration had not changed - it was still there and making me physically sick by the time I got to work. I had a friend that is a driveline engineer test drive it to confirm my claim, he agreed that it was bad.
I took the truck in a second time to the dealer and asked that the service manager show me this damper - he flat out refused. Luckly someone walked by and offered to show me. Everyone was shocked when we found that this part was never installed. The service manager was also stupid enough to admit he never put it on. This story is more involved and luckly the sales person quit working there over my issues and has agreed to testify in court.
The dealership finally put on the damper and it did not even phase the vibration - it was still there. After all of the drama I took the time to think without emotion and contacted a lawyer. Through out this whole process I have asked for my money back (nothing more, nothing less) and have filed almost every bit of paper work I can.
I finally had to go to another dealership that is extremely out of my way - per my lawyers advise I cannot disclose anything about my case but I will say this. I WILL NOT GIVE UP UNTIL I GET MY MONEY OR A JUDGE GIVES ME A DECISION. To top it off I am having a problem with my trans, the 3-2 shift feels like a neutral slam and the truck is a dog. No power, and I baby that thing. The dealer says that the nature of the beast - I say that truck is junk. By the way, the vibration is still there.
After researching this problem for three months I have found;
This problem is very wide spread - I am starting to question the safty over a short peorid of time. Vibrations will cause other parts of the truck to fail.
I have met three independent owners stating that the rear axel will snap under stress within design parameters.
If you look under the rear left bumper, that is where the dampers are placed - its kinda funny how they know where to put them and the truck is already setup to have it installed.
I live in the south east Michigan area and intend to do everything in my power to inform the general public about this. Most importantly I am going to the press. Every side to an argument has a right to a defense so lets hear it. If you are reading this and would like to band together to get your money back and inform others please let me know at
F150help@hotmail.com
Power in numbers! Share you story and we can help each other.
kirstie_h
Roving Host
Host, Future Vehicles & Smart Shopper discussions
MODERATOR /ADMINISTRATOR
Review your vehicle
A friend of mine has a 2001 Ford F-250 super duty with a 7.3L diesel and automatic with overdrive. The problem is when it shifts from first to second you have to let off the throttle sometimes or it wont shift. A local transmission shop told his wife that it needs a new transmission. He drives truck so his wife took it to have it checked out. The truck has 52,000 miles on it and it doesnt do this everytime they drive it.
Please, Any help would be GREATLY appreciated!
Jake
Dealer's tech drove my truck, recognized the problem and pulled up the TSB for the steering wander. He adjusted the steering gear mesh torque and it was like getting a whole new truck. You can let go of the wheel and it will just keep tracking in straight line. It's been fine ever since.
I don't know what you mean when you say your "steering is cutting in and out." How many miles on your truck? Could it be your Ball Joints be wearing out? Ford cheaped out and didn't put the xerk fittings on them so they tend to wear out around the 75K mile range.
have a K&N air filter in it qwith a dual exhaust system (three into form the manifolds to 2 two and a quarter tail pipes form the magna flow muffler). goingo to a K&N cold air kit soon.
Anything would be helpful. things about the engine and the truck itslef that might help me in the futre. moved up from a 1997 Crown Victoria (knew everything about that car, don't know much about the truck...some, but not much)
But, the 5.4 is known for it's Oil Burn issues.
Did some research...I am almost positive it is called the Idle Air Control Valve.
ANd I don't think FORD has a FGault Code for that device either. That is why we could nerver get it. I guessed by reading through my Haines manual...called ford..and There it was.
switch to a synthetic motor oil too. That might halp you in the long run
have the alignment checked. tires out of alignment could worsen your milage too.
Jeannine Fallon
Corporate Communications
Edmunds.com
Review your vehicle
Darn thing will not wear out.
I got tired of waiting.
Last Friday I bought a new 2006 Lariat Super Crew.
It is very nice.
Can anyone help with suggesdtions?
Here are some the symptoms.
1) wild iddling
2)engine cuts-off after idling in a parking or very,very-low speed.
3) check engine light constantly on!
Try finding a competent mechanic who has a code reader and can understand fault codes, or take it to Autozone and have it done for free.
Also, while you are at AutoZone, have them check your battery and alternator....could be the problem.
2wd or 4wd?
I want a 4wd.
where did you buy it and if you don;t mind how much?
What is the reliability of these new Fords?
Has anyone else had this problem?
I was thinking it may be my glow plugs but it only has 85,000 miles on it.
Thanks in advance.
Ron
There are more radical solutions for getting cold diesels to start easily but for 47 degrees I don't think they apply here.
thanks, shakeyf250
Has anyone else had this problem fixed??
From talking to other people it is not uncommon, but the dealers couldn't fix the problems. My truck has been in the shop for three days now and they are clueless.
