2000 Ford F-250 Super Duty Problems and Solutions
Reply
I have a 2002 F-150, long bed with a tow package small V-8.I recently bought a car to help keep gas costs down and the truck sits for extended periods of time- only 200 miles this summer..I am having a great deal of trouble getting into 4 wheel drive.I don't want to force it ,but most of the time it won't go in,Any thoughts.Also the Service Engine Light is staying on and it is running VERY rough.Thanks
I've seen more stupid problems with vehicles suffering from lack of use than ones that are driven every day. My Mom had 15 year old Plymouth that only had 28K miles on it - we ended up junking it because every gasket, seal , and piece of rubber in it was randomly disintegrating and the car had become a too much of a liability for an old lady to drive.
As far as your truck goes: sounds like possibly the lubrication in the front hubs has gotten dry and stiff from lack of use. (Take it this is a manual 4wd, and not shift of the fly) Even though I bought my 4x4 for winter use, I still will engage it once every week or two during the summer. I either go on a straight stretch of road for a couple miles, or hit a gravel road that's nearby. Unfortunately, if it's the hubs, don't know what to do besides pulling them and re- lubing them. (Also have you been off roading or anything - check to see if any linkages have gotten bent.)
Is this the "check engine" light or maintenance indicator (not familiar w/ newer 150s) that's on. As far as the check engine and rough running, you could have a fuel problem. As gas sits for long periods, it tends to turn to "varnish" and gums things up. It could also be water in the fuel; if tank is only part way full and it sits for a while, water vapor can contaminate it.
If it's your check engine light on, it's throwing a service code - Autozone will scan your engine computer and report problems for free. That would be the best place to start.,
Odds are you probably need a fresh tank of gas. A replacement fuel filter, and maybe a dedicated cleaning of your fuel injectors by a mechanic with something a bit stronger than a bottle of STP injector cleaner.
The rear axle lubricant could have water in it or be in need of changing. You could try draining and refilling with a higher viscosity gear lube. Usually, however, once they start to howl the damage is done.
Good Luck.
Dusty
waiting 15-20 seconds for the engine to settle down doesn't seem like a long time to me provided the engine is cold. Are you in a cold environment? Does it do this when the engine is warm?
If anything, the problem lies not with your engine but with the automatic choke (my guess)
Any suggestions other than replacing it again? This is all but totally bankrupted me.. I can't work because I'm self employed so my ONLY alternative is to either replace and HOPE the dinky jack I have will lift the truck high enough or sell the basta....truck and get another...
I"m desparat and will try almost anything..
Thanks in advanced..
M
Say goodbye to your spark plug and perhaps the threads that come out with it!!! I've blown two plugs out and now my motor is trash, think the threads went down the cylinder and scored the wall. better make sure your plugs don't back out and that you torque them correctly or else you'll weaken the whimpy aluminum heads. I've got a real mess on my hands.
With all these problems I am reading and the nightmare stories of bad customer services , I'm starting to doubt my desire for a 05 FX4.
Also , Is there a place to find a Ford dealers customer service rating in my area ?
don't get discouraged on ford too much. remember, this is the problem board; not 'how much I like my truck board'. All cars/trucks have problems - if there's a make on Edmunds, then there's a board posting problems.
From what I read here, I haven't seen many re- occuring problems; at least not recently.
In your case you need an independent professional diagnosis of the problem, assuming that the dealer doesn't do the right thing when you return. Knowing that you're not going to quietly fade away will probably help them to do the right thing!
It could well be electrical, especially as it's a diesel, but more details would help narrow iy down.
Was this a 'premium' or a 'value' rebuild?
Did you do this work yourself? Was the block bored and new pistons fitted?
Is it an old starter?
When they get old, they will start to not turn well when hot. After cooling a bit, all is well until hot again...
Please help.:-(
My feeling would be to look for an electrical solution to this, from the key switch on down.
