Visitor Agreement.
Does anyone know if they sell a clutch fan for a 2004 Suzuki Grand Vitara XL-7?
Has anyone had problems with their factory radio going bad. 2000 Tracker with 51,000 miles. Radio doesn't work at all at first, then works intermittently, then works fine after it seems to "warm up". Anyone have a factory radio laying around that they don't need? Thanks!
You'll find some stuck drum posts over there, like this one:
alcan, "Stop here! Let's talk about brakes" #1087, 28 Jul 2005 8:40 pm
That's the pipe size?
What is this "Air/No air" about on the converter?
Is it an easy, clamp based, replacement of JUST the converter - or do I need to cut into the pipe ahead of it and weld?
(The joint between the converter and the last, short, section of pipe rusted out. Other than that joint, everything else looks fine.)
I've seen pictures, (at places like J.C. Whitney) - and it looks more like the C.C. than anything else.
Some pictures show a tube coming out of the side of the converter (and mention a cap to close it off). This, I think, is the "air/no air" they're talking about. I've never seen anything like it before.
My Chilton CD mentions very little about the exhaust, and nothing about the converter.
Thanks for the reply.
I think the C.C. end is way too far gone to weld anything to it (it looks like a slip joint, not a flange. There is possible a flange ahead of the C.C. that could be used for the repair, but only the short piece of pipe (in a slip joint) at the end.
I was surprised when I glanced under, at how clean and new the converter, and the pipe ahead of it, looked.
Perhaps there was an earlier repair of the middle section (bought used - 65K miles).
Where are you seeing pictures? That's one of the reasons I'm on this forum - can't find any good pictures.
I've seen C.C.s for under a hundred; still, money that could be used better elsewhere - like on food or gas.
If I were you (or your wife) I would buy a cheap, used gas saver to beat around delivering newspapers.
hahaha, tc
https://www.mygmlink.com/main/US/en/chevrolet/vehpage
This has pictures with it to assist you. :shades:
you did give me a great site to check out when I change the oil or put the water in the radiator from up under-neath..? lol, thank you so much, gotta laugh..."
sachetby2
Thanks SammiesDad
Leon Ramseur
Gastonia, NC
2001 White Tracker 4x4
Leon Ramseur
Gastonia, NC
Leon Ramseur
Gastonia, NC
Thanks for the reply. I had heard the Dealer could fix it for about $600.00..
Was that what you found ?? I was hoping there was a simple solution rather than a $600.00 expense..
Would you mind sharing what the dealer did to fix the problem..
Sammiesdad
http://www.puresuzuki.com/grand_vitara2.htm
here you go!
chris
:confuse:
It would be easier to jack up the radiator cap and put a new tracker under it.
